Help With Dune Part 2 MakeMKV Error
turtledude
Post by turtledude »
Hello, I am able to watch the movie on the same ripping PC and was able to rip the movie in the past (hard drive went bad), but now I am getting fail on each rip attempt.
I tried cleaning the disc, but still getting failed rip. The disc was purchased new last year May 2024 and was only ripped to PC once before my many attempts now.
Is this just a random case of disc going bad?
MakeMKV v1.17.8 win(x64-release) started
Using LibreDrive mode (v06.3 id=E064BA3E3F81)
Evaluation version, 22 day(s) out of 30 remaining
This disc requires Java runtime (JRE), but none was found. Certain functions will fail, please install Java. See http://www.makemkv.com/bdjava/ for details.
File 00009.mpls was added as title #0
Title #00010.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.mpls has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #1
Title #00000.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00008.m2ts was added as title #2
Title #00009.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00059.m2ts was added as title #3
Title #00068.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00074.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00075.m2ts was added as title #4
File 00076.m2ts was added as title #5
File 00077.m2ts was added as title #6
File 00078.m2ts was added as title #7
File 00079.m2ts was added as title #8
File 00080.m2ts was added as title #9
File 00081.m2ts was added as title #10
File 00082.m2ts was added as title #11
File 00083.m2ts was added as title #12
Saving 1 titles into directory C:/Video/Dune- Part Two
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00075.m2ts' at offset '43012915200'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '43012915200'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00075.m2ts' at offset '43012915200'
Failed to save title 1 to file C:/Video/Dune- Part Two/Dune- Part Two_t01.mkv
Encountered 17 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Re: Help With Dune Part 2 MakeMKV Error
I wouldn't expect a disc as new as Dune Part 2 to 'go bad'. It might be dirty. Certainly the drive is having trouble reading a spot on the disc.
It might also be that the optics on your drive are dirty. They could be gently cleaned with a Q-Tip and isopropyl alcohol along with a microfiber towel to wipe it dry (don't let it air dry). Some drives are easier than others to get access to the drive optics.
If you have another drive, or maybe a friend or family member has a drive you can use, giving it a try wouldn't hurt. In my experience the same disc in a different drive will often, although not always, produce different results.
