MakeMKV fails with disc 'wanted' (australia)
marshalleq
#1 Post by marshalleq » Tue Oct 06, 2009 5:56 am
First off, I created an ISO from this disk using dd. So I'm working from that.
I get the same error and circumstance on windows, so it's not a linux only thing.
Situation is, copies about 8GB then refuses to go further (has about 25GB in total to do).
If debug is enabled, makemkv crashes during scanning of the disk and you cannot click the makemkv button. Again, this is all the same, windows or linux. Using MakeMKV 1.4.7 on both Windows 7 and Sabayon linux.
Log file attached.
marshalleq
Re: MakeMKV fails with disc 'wanted' (australia)
#2 Post by marshalleq » Tue Oct 06, 2009 5:58 am
Should probably have mentioned, it's blu ray :)
marshalleq
#3 Post by marshalleq » Tue Oct 06, 2009 6:00 am
Ooops, one more point. It deletes the 8GB file in both circumstances when it stops.
#4 Post by mike admin » Wed Oct 07, 2009 10:23 am
I do not see a log file. what happens if you run command-line "makemkvcon info iso:pathtoyourfile.iso" ? In all cases iso image is not sufficient, you'll need either disc volume ID or disc volume key ( or original disc for makemkv to read this information).
marshalleq
#5 Post by marshalleq » Fri Oct 09, 2009 7:03 am
Yeah, I didn't see the attachment on your page either, just assumed it became private after I downloaded it. Will try it again and also your suggestion.
marshalleq
#6 Post by marshalleq » Fri Oct 09, 2009 7:07 am
OK I see the problem, it says it will not allow the extension .txt or .log or no extension either. Hmmmm. Using firefox on KDE 4.3. Will try some other browsers etc after dinner :)
marshalleq
#7 Post by marshalleq » Fri Oct 09, 2009 8:53 pm
Nope I can't attach anything. And when I try to paste a very long error log directly into the window it says I pasted too FEW characters. I'm sure your system doesn't know sarcasm so I guess someone put 'few' where 'many' was supposed to be? :)
marshalleq
#8 Post by marshalleq » Fri Oct 09, 2009 8:54 pm
Pasting just part of the log as last resort:
Debug log started at Tue Oct 6 08:00:04 2009 , written by MakeMKV v1.4.7 beta linux(x86-release)
001014:000000:0000 MakeMKV v1.4.7 beta linux(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as /home/quentinj/MakeMKV_log.txt
001012:000000:0020 FAILURE: Code 0 at z.mP(Z%YkR^x(7,CLs9*:213130099
001012:000000:0020 FAILURE: Code 135 at .,r$N|jFt5:z<K6(O:29394643
001012:000000:0020 FAILURE: Code 136 at .,r$N|jFt5:z<K6(O:29394643
001012:000000:0020 FAILURE: Code 1 at Q.@5AyTlpfk"1fm7hn:29393953
001012:000000:0020 FAILURE: Code 4 at .,r$N|jFt5:z<K6(O:29394643
001012:000000:0020 FAILURE: Code 4294967286 at #t<mGdvxCnd#(-9^?b:29394068
001012:000000:0020 FAILURE: Code 4294967286 at #t<mGdvxCnd#(-9^?b:121262601
001012:000000:0020 FAILURE: Code 4294967286 at #t<mGdvxCnd#(-9^?b:29394597
003010:000000:0000 Using direct disc access mode
DISCID=DEBA3F2C04DA1E18F8A6C9B8CF3D9307BF870320
marshalleq
#9 Post by marshalleq » Fri Oct 09, 2009 9:00 pm
Unfortunately, while there is lots of output with the command you asked me to run, I cannot upload it or paste it. Let me know if there's anything further I can do, but your site insists it does not support upload of txt.
marshalleq
#10 Post by marshalleq » Fri Oct 09, 2009 9:19 pm
Still same behaviour in makemkv 1.4.8.
#11 Post by mike admin » Sat Oct 10, 2009 10:39 am
your log contains random failures, so it looks memory is corrupted. Please try attaching txt files again, i've changed board settings.
