Hot Tub Time Machine backup won't play
bird333
Post by bird333 »
I made a decrypted backup and burned the backup to a blu-ray rewritable disc as a test. It played fine in VLC on my computer. However, when I put it in a real blu-ray player (Sony) it complains about the player needing an update. It's got BD+ 2010.5. Anyway to fix?
Re: Hot Tub Time Machine backup won't play
For a regular blu-ray player to work, one usually has to use imgburn to turn the MakeMKV backup into the proper filesystem (UDF 2.5) the player is expecting and then burn the resulting .ISO onto a disc.
Are you sure you really want to burn discs? It is rarely the right answer these days.
bird333
Post by bird333 »
Yes. How do you do that? Other copies haven't done that on the player.
bird333
Post by bird333 »
The backup is using UDF 2.5. Does anyone know what is happening here and how to fix it?
