Post by Billycar11 » Sun Jan 19, 2025 1:21 am
charly700 wrote: Sat Jan 18, 2025 10:34 pm
Laufwerksinformation
OS-Gerätename: D:
Produzent: HL-DT-ST
Produkt: BD-RE BE16NU50
Revision: 1.00
Serienummer:
Firmware-Datum: 2116-03-17 13:36
Markierungen der Bus-Verschlüsselung: 17
Highest AACS version: 76
Firmware version: 1.00
Keine Disk eingelegt
Hello, is there a better firmware for my recorder (UHD friendly, sleep bug)? If so, which one should I flash? Thank you.
Yeah wh16ns60 1.00 or 1.02mk
charly700
Post by charly700 » Sun Jan 19, 2025 1:39 am
Thank you.
zprewitt
Post by zprewitt » Sun Jan 19, 2025 5:48 pm
I'm trying to flash an LG BP60NB10 drive. This is my first attempt at a flash, so go easy on me.
Here's the drive info:
OS device name: /dev/rdisk5
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM04OAGE4325
Firmware date: 2121-07-08 15:56
Hardware support: Yes
Firmware support: No
Firmware version: 1.02
I'm following the steps for Mac. When I tried to flash to the firmware provided in the all-you-need pack, I got this:
Drive "/IOBDServices/D5D25996" not found
After rechecking the guide, I saw that the drive was using encrypted firmware, so I grabbed the MK version but got the same result.
Obviously, I'm missing something. Could someone point me in the right direction?
Post by Billycar11 » Sun Jan 19, 2025 5:58 pm
zprewitt wrote: Sun Jan 19, 2025 5:48 pm I'm trying to flash an LG BP60NB10 drive. This is my first attempt at a flash, so go easy on me.
Revision: 1.02
See steps 6
You need to use your ID not the example
zprewitt
Post by zprewitt » Sun Jan 19, 2025 6:01 pm
Billycar11 wrote: Sun Jan 19, 2025 5:58 pm
Revision: 1.02
See steps 6
Oop, I forgot to mention that. When I type in the command in Step 6, I see this
Found 1 drives(s)
00:
  HL-DT-ST_BD-RE_BP60NB10_1.02_212107081556_SIM04OAGE4325
Shouldn't it also be showing me the ID as well?
zprewitt
Post by zprewitt » Sun Jan 19, 2025 8:53 pm
zprewitt wrote: Sun Jan 19, 2025 6:01 pm
Revision: 1.02
See steps 6
Found 1 drives(s)
00:
Solved. For anyone else having the same issue: Just make sure your drive is connected directly to your mac and not a USB bank.
thelapperdapper
Important
Post by thelapperdapper » Tue Jan 21, 2025 3:20 pm
The latest version as of now (1.17.8) is unable to flash firmware, at least on linux.
The steps to do this on linux is
1. Install the latest version of makemkv
2. Copy the needed libraries to a temporary dir
mkdir ~/Downloads && cp /usr/lib/libmakemkv.so.1 /usr/lib/libdriveio.so.0 ~/Downloads
3. Uninstall makemkv (E.g sudo pacman -R makemkv)
4. Download makemkv-1.17.6.tar.gz (https://www.makemkv.com/download/old/ma ... 7.6.tar.gz)
5. Extract it to a certain location (for example Downloads):
cd ~/Downloads && tar -xzf makemkv-bin-1.17.6.tar.gz
6. Install it
cd makemkv-bin-1.17.6 && sudo make install
7. DONE. Flashing should now work again.
In order to install a newer version run
sudo rm /usr/bin/makemkvcon /usr/bin/sdftool /usr/share/MakeMKV/* /usr/lib/libdriveio.so.0 /usr/lib/libmakemkv.so.1
ThatGuyName
Post by ThatGuyName » Wed Jan 22, 2025 4:47 pm
I keep trying this and it always gives me the same response when I go to flash:
"Input file not found -- /HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935
Internal error 0x83000001"
I've tried it bothe ways: "enc" and "main"
whats the problem here?
I'm using the LG slim BP60NB10 btw.
jayman89
Post by jayman89 » Thu Jan 23, 2025 5:07 pm
Thanks for the guide and firmware. I successfully flashed a WH16NS40 just purchased of Amazon.
https://www.amazon.com/dp/B00E7B08MS
Post by Coopervid » Fri Jan 24, 2025 5:45 pm
ThatGuyName wrote: Wed Jan 22, 2025 4:47 pm I keep trying this and it always gives me the same response when I go to flash:
Show your command line and make sure the bin file is available and named right.
ThatGuyName
Post by ThatGuyName » Fri Jan 24, 2025 5:54 pm
Coopervid wrote: Fri Jan 24, 2025 5:45 pm
I ended up fixing it! dcoke22 helped me.
spamtom
Post by spamtom » Sun Jan 26, 2025 3:33 pm
Hi, new to this so appologies. Having read most of the guides and the firs5 post i am still missing some basics and want to check what i think is correct. If i purchased a new BDR-XS07TUHD from Amazon this will not work with makemkv as the firmware is going to be unpatchable. Instead I need to find one for sale that’s older. Do these drives ever get patched as in are people working on patching them/finding exploits? Do any new external drives work straight off the shelf
Post by MartyMcNuts » Sun Jan 26, 2025 11:29 pm
spamtom wrote: Sun Jan 26, 2025 3:33 pm Hi, new to this so appologies. Having read most of the guides and the firs5 post i am still missing some basics and want to check what i think is correct. If i purchased a new BDR-XS07TUHD from Amazon this will not work with makemkv as the firmware is going to be unpatchable. Instead I need to find one for sale that’s older. Do these drives ever get patched as in are people working on patching them/finding exploits? Do any new external drives work straight off the shelf
No new Pioneer external drives work for UHD at all. They all have post 11/2022 unpatchable firmware. This has been worked on for 2+ years now without success. It's not looking good.
The only external drive that still currently works OOTB is the Verbatim 43888 (Pioneer BDR-UD04 version). The Verbatim 43888 (LG BU40N version can be flashed).
dellsam34
Post by dellsam34 » Mon Jan 27, 2025 3:15 am
Is buying the makemkv license required to make a rip?
Post by d00zah » Mon Jan 27, 2025 3:28 am
dellsam34 wrote: Mon Jan 27, 2025 3:15 am Is buying the makemkv license required to make a rip?
