Soo i did a mess up by accidently flashing BW-16D1X-U
LuciLcui
Post by LuciLcui » Fri Jan 24, 2025 2:03 am
I flashed by accident the BU40N BU10 on my BW-16D1X-U and i am now unable to change the flash .. would anyone know how i could make it back to factory default?
Re: Soo i did a mess up by accidently flashing BW-16D1X-U
Post by Billycar11 » Fri Jan 24, 2025 2:29 am
Do recovery select the bu10 fw then flash the Asus stuff.
Unplug the drive anytime your not trying to recover it seen these die when flashed wrong
LuciLcui
Post by LuciLcui » Fri Jan 24, 2025 2:38 am
Billycar11 wrote: Fri Jan 24, 2025 2:29 am Do recovery select the bu10 fw then flash the Asus stuff.
tried multiple time to flash but keep getting error, but i am able to flash to other BU.
LuciLcui
Post by LuciLcui » Fri Jan 24, 2025 3:34 am
Tried but it does not let me switch away from a BY , tried multiples and it does not let me switch back to an asus firmware : ASUS-BW-16D1H-U-A204-WM01001-211901041044.bin is the one i been trying to flash
LuciLcui
Post by LuciLcui » Fri Jan 24, 2025 4:09 am
Thanks ytou figured out the way ! problem fixed
MK1234Tfan
Post by MK1234Tfan » Fri Jan 24, 2025 1:42 pm
LuciLcui wrote: Fri Jan 24, 2025 4:09 am Thanks ytou figured out the way ! problem fixed
What did you do to fix it?
