Soo i did a mess up by accidently flashing BW-16D1X-U
LuciLcui
I flashed by accident the BU40N BU10 on my BW-16D1X-U and i am now unable to change the flash .. would anyone know how i could make it back to factory default?
Re: Soo i did a mess up by accidently flashing BW-16D1X-U
Do recovery select the bu10 fw then flash the Asus stuff.
Unplug the drive anytime your not trying to recover it seen these die when flashed wrong
LuciLcui
tried multiple time to flash but keep getting error, but i am able to flash to other BU.Billycar11 wrote: Fri Jan 24, 2025 2:29 am Do recovery select the bu10 fw then flash the Asus stuff.
LuciLcui
Tried but it does not let me switch away from a BY , tried multiples and it does not let me switch back to an asus firmware : ASUS-BW-16D1H-U-A204-WM01001-211901041044.bin is the one i been trying to flash
LuciLcui
Thanks ytou figured out the way ! problem fixed
MK1234Tfan
What did you do to fix it?
