Pirates of the Caribbean: Dead Man's Chest => bad SAR & DAR
WCVanHorne
Post by WCVanHorne »
I believe every one of the 100 or so blurays I have ripped to date have had an input aspect ratio SAR=1:1 and DAR=16:9. They display fine with the correct aspect ratio. However the mkv (using the latest makemkv 1.6.16) of 'Pirates of the Caribbean: Dead Man's Chest' reports a SAR=65509:45568 & DAR=2911:1139 (and a correct 1920x1080 size) and plays back vertically compressed as one might expect with these values. The MPEG4 track info seem reasonable in makemkv:
Track information
Type: Video
Codec: Mpeg4
Resolution: 1920x1080
Aspect ratio: 16:9
Frame rate: 23.976 (24000/1001)
Ideas?
WCVanHorne
Re: Pirates of the Caribbean: Dead Man's Chest => bad SAR &
Anyone?
crowfax
Post by crowfax »
Can you post the full output from mediaInfo for the created MKV file?
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
WCVanHorne
I don't immediately see anything amiss and have attached it last. It think it is in the stream rather than the container/headers.
On that note just below are a few frames of the ffdshow OSD, first normal:
;Input description: ;Input aspect ratio: ;Movie length: ;Input size and aspect ratio: ;Input bitrate: ;Decoder FPS: ;Output aspect ratio: ;Decoder: ;Movie FPS: ;CPU load: ;Accurate deblocking: ;Input size: ;Current frame: ;Encoder info: ;Remaining time: ;Frame type: ;IDCT(libavcodec):
;AVC1 (ffmpeg-mt h264);SAR: 1/1, DAR: 16/9;01:51:09;1920x1080, SAR: 1/1, DAR: 16/9;98 kbps;32.26;SAR: 1/1, DAR: 16/9;ffmpeg-mt h264;23.976 ;100%;yes;1920x1080;3;unknown;01:51:09;P	 QPEL;unknown
;AVC1 (ffmpeg-mt h264);SAR: 1/1, DAR: 16/9;01:51:09;1920x1080, SAR: 1/1, DAR: 16/9;80 kbps;21.28;SAR: 1/1, DAR: 16/9;ffmpeg-mt h264;23.976 ;100%;yes;1920x1080;4;unknown;01:51:09;P	 QPEL;unknown
Now Pirates 2:
;AVC1 (ffmpeg-mt h264);SAR: 65509/45568, DAR: 2911/1139;02:30:39;1920x1080, SAR: 65509/45568, DAR: 2911/1139;29047 kbps; 0.00;SAR: 1/1, DAR: 16/9;ffmpeg-mt h264;23.976 ;41%;yes;1920x1080;562;unknown;02:30:16;B	 QPEL;unknown
;AVC1 (ffmpeg-mt h264);SAR: 65509/45568, DAR: 2911/1139;02:30:39;1920x1080, SAR: 65509/45568, DAR: 2911/1139;29039 kbps;21.28;SAR: 1/1, DAR: 16/9;ffmpeg-mt h264;23.976 ;41%;yes;1920x1080;563;unknown;02:30:16;B	 QPEL;unknown
Mediainfo full output:
C:\Video\PIRATES2>mediainfo -f title00.mkv
General
Count                                    : 278
Count of stream of this kind             : 1
Kind of stream                           : General
Stream identifier                        : 0
Unique ID                                : 268135772112884239309277073386894740644
Unique ID                                : 268135772112884239309277073386894740644 (0xC9B9123E93E29EEA0670DBFF59A74CA4)
Count of video streams                   : 1
Count of audio streams                   : 1
Count of menu streams                    : 1
Video_Format_List                        : AVC
Video_Format_WithHint_List               : AVC
Codecs Video                             : AVC
Video_Language_List                      : English
Audio_Format_List                        : AC-3
Audio_Format_WithHint_List               : AC-3
Audio codecs                             : AC3
Audio_Language_List                      : English
Complete name                            : title00.mkv
File name                                : title00
File extension                           : mkv
Format/Url                               : http://packs.matroska.org/
Format/Extensions usually used           : mkv mk3d mka mks
Commercial name                          : Matroska
Format version                           : Version 2
Codec                                    : Matroska
Codec                                    : Matroska
Codec/Url                                : http://packs.matroska.org/
Codec/Extensions usually used            : mkv mk3d mka mks
File size                                : 22183033103
File size                                : 20.7 GiB
File size                                : 21 GiB
File size                                : 21 GiB
File size                                : 20.66 GiB
Duration                                 : 9039030
Duration                                 : 2h 30mn
Duration                                 : 2h 30mn 39s 30ms
Duration                                 : 2h 30mn
Duration                                 : 02:30:39.030
Overall bit rate                         : 19633109
Overall bit rate                         : 19.6 Mbps
Stream size                              : 441421870
Stream size                              : 421 MiB (2%)
Stream size                              : 421.0 MiB
Proportion of this stream                : 0.01990
Encoded date                             : UTC 2011-11-10 04:27:38
File creation date                       : UTC 2011-11-10 04:27:38.228
File creation date (local)               : 2011-11-09 21:27:38.228
File last modification date              : UTC 2011-11-10 05:08:25.572
File last modification date (local)      : 2011-11-09 22:08:25.572
Writing application                      : MakeMKV v1.6.16 win(x86-release)
Writing library                          : libmakemkv v1.6.16 (1.2.0/1.1.0) win(x86-release)
Video
Count                                    : 205
Kind of stream                           : Video
Unique ID                                : 1
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format/Url                               : http://developers.videolan.org/x264.html
Commercial name                          : AVC
Format profile                           : High@L4.1
Format settings                          : CABAC / 3 Ref Frames
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 3
Format settings, ReFrames                : 3 frames
Format settings, GOP                     : M=3, N=24
Internet media type                      : video/H264
Codec ID                                 : V_MPEG4/ISO/AVC
Codec ID/Url                             : http://ffdshow-tryout.sourceforge.net/
Codec                                    : V_MPEG4/ISO/AVC
Codec                                    : AVC
Codec/Family                             : AVC
Codec/Info                               : Advanced Video Codec
Codec/Url                                : http://ffdshow-tryout.sourceforge.net/
Codec profile                            : High@L4.1
Codec settings                           : CABAC / 3 Ref Frames
Codec settings, CABAC                    : Yes
Codec_Settings_RefFrames                 : 3
Duration                                 : 9039039
Duration                                 : 2h 30mn
Duration                                 : 2h 30mn 39s 39ms
Duration                                 : 2h 30mn
Duration                                 : 02:30:39.039
Bit rate                                 : 18602410
Bit rate                                 : 18.6 Mbps
Width                                    : 1920
Width                                    : 1 920 pixels
Height                                   : 1080
Height                                   : 1 080 pixels
Pixel aspect ratio                       : 1.000
Display aspect ratio                     : 1.778
Frame rate                               : 23.976
Frame rate                               : 23.976 fps
Frame count                              : 216720
Resolution                               : 8
Resolution                               : 8 bits
Colorimetry                              : 4:2:0
Chroma subsampling                       : 4:2:0
Bit depth                                : 8
Bit depth                                : 8 bits
Scan type                                : Progressive
Interlacement                            : PPF
Interlacement                            : Progressive
Bits/(Pixel*Frame)                       : 0.374
Delay                                    : 0
Delay                                    : 00:00:00.000
Delay, origin                            : Container
Stream size                              : 21018488833
Stream size                              : 19.6 GiB (95%)
Stream size                              : 20 GiB
Stream size                              : 19.57 GiB
Proportion of this stream                : 0.94750
Language                                 : en
Language                                 : en
Language                                 : eng
Language                                 : en
Audio
Count                                    : 201
Kind of stream                           : Audio
Unique ID                                : 2
Commercial name                          : AC-3
Mode extension                           : CM (complete main)
Codec ID                                 : A_AC3
Codec                                    : AC3
Codec                                    : AC3
Codec/Family                             : AC3
Codec/Info                               : Dolby AC3
Duration                                 : 9039030
Duration                                 : 2h 30mn
Duration                                 : 2h 30mn
Bit rate mode                            : CBR
Bit rate                                 : 640000
Bit rate                                 : 640 Kbps
Channel(s)                               : 6
Channel positions                        : Front: L C R, Side: L R, LFE
Channel positions                        : 3/2/0.1
Sampling rate                            : 48000
Sampling rate                            : 48.0 KHz
Samples count                            : 433873440
Resolution                               : 16
Resolution                               : 16 bits
Bit depth                                : 16
Bit depth                                : 16 bits
Delay                                    : 0
Delay relative to video                  : 0
Video0 delay                             : 0
Stream size                              : 723122400
Stream size                              : 690 MiB (3%)
Stream size                              : 689.6 MiB
Proportion of this stream                : 0.03260
Title                                    : 3/2+1
Language                                 : en
Language                                 : en
Language                                 : eng
Language                                 : en
dialnorm                                 : -31
dialnorm/String                          : -31 dB
compr                                    : 6.02
compr/String                             : 6.02 dB
dynrng                                   : 1.02
dynrng/String                            : 1.02 dB
bsid                                     : 8
dialnorm_Average                         : -31
dialnorm_Average/String                  : -31 dB
dialnorm_Minimum                         : -31
dialnorm_Minimum/String                  : -31 dB
dialnorm_Maximum                         : -31
dialnorm_Maximum/String                  : -31 dB
dialnorm_Count                           : 2
compr_Average                            : 6.02
compr_Average/String                     : 6.02 dB
compr_Minimum                            : 6.02
compr_Minimum/String                     : 6.02 dB
compr_Maximum                            : 6.02
compr_Maximum/String                     : 6.02 dB
compr_Count                              : 2
dynrng_Average                           : 1.02
dynrng_Average/String                    : 1.02 dB
dynrng_Minimum                           : 1.02
dynrng_Minimum/String                    : 1.02 dB
dynrng_Maximum                           : 1.02
dynrng_Maximum/String                    : 1.02 dB
dynrng_Count                             : 2
Menu
Count                                    : 100
Kind of stream                           : Menu
Chapters_Pos_Begin                       : 72
Chapters_Pos_End                         : 100
00:00:00.000                             : en:Chapter 00
00:04:18.925                             : en:Chapter 01
00:09:53.009                             : en:Chapter 02
00:12:13.441                             : en:Chapter 03
00:19:09.064                             : en:Chapter 04
00:23:53.473                             : en:Chapter 05
00:30:15.480                             : en:Chapter 06
00:35:29.418                             : en:Chapter 07
00:40:32.930                             : en:Chapter 08
00:46:28.035                             : en:Chapter 09
00:50:25.564                             : en:Chapter 10
00:56:18.625                             : en:Chapter 11
00:59:52.380                             : en:Chapter 12
01:05:45.191                             : en:Chapter 13
01:11:55.853                             : en:Chapter 14
01:17:04.327                             : en:Chapter 15
01:22:10.258                             : en:Chapter 16
01:30:36.639                             : en:Chapter 17
01:34:38.172                             : en:Chapter 18
01:39:21.830                             : en:Chapter 19
01:44:52.410                             : en:Chapter 20
01:49:14.714                             : en:Chapter 21
01:54:55.805                             : en:Chapter 22
01:59:36.043                             : en:Chapter 23
02:04:59.908                             : en:Chapter 24
02:10:27.194                             : en:Chapter 25
02:16:20.630                             : en:Chapter 26
02:21:04.789                             : en:Chapter 27
Post by mike admin »
WCVanHorne wrote:I believe every one of the 100 or so blurays I have ripped to date have had an input aspect ratio SAR=1:1 and DAR=16:9. They display fine with the correct aspect ratio. However the mkv (using the latest makemkv 1.6.16) of 'Pirates of the Caribbean: Dead Man's Chest' reports a SAR=65509:45568 & DAR=2911:1139 (and a correct 1920x1080 size) and plays back vertically compressed as one might expect with these values. The MPEG4 track info seem reasonable in makemkv:
Track information
Type: Video
Codec: Mpeg4
Aspect ratio: 16:9
Ideas?
Looks like a bug in MakeMKV. Can you please make a testdump for that title? http://www.makemkv.com/onlinehelp/testdump.html
WCVanHorne
Sent download link to support@makemkv.com . Please confirm you have received it.
WCVanHorne
Bumping this thread because I've heard nothing and now run across yet another Blu-ray with the *exact* same issue: 'Fantastic Four - Rise of the Silver Surfer'.
Surely I can't be the only one seeing this issue?
