PM is coming in a few minutes.Ravsky wrote: Mon Jan 20, 2025 9:50 am Hi, Is this drive has update?
OS device name: H:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.11
Serial number: ...
Firmware date: 2023-04-20
Firmware version: ID22
ASUS SBW-06D2X-U
Re: ASUS SBW-06D2X-U
plust
Hi Coopervid,
I'm trying to enable LibreDrive.
Could you please do me a PM too?
Manufacturer: ASUS
Revision: 1.10
Serial number: ************
Firmware date: 2017-04-18
Thanks for your help
Manufacturer: ASUS
Revision: 1.10
PM sent.plust wrote: Wed Jan 22, 2025 6:18 am Hi Coopervid,
Manufacturer: ASUS
Revision: 1.10
plust
Thank you, Coopervid, for the information via PM.
Please see the following error message in red.
[color=#FF0000]Drive and firmware hardware types don't match.[/color]
[attachment=1]2025-01-23 (1).png[/attachment]
Would this be a case of using Force flash, or may there be another explanation?
[attachment=0]2025-01-23 (2).png[/attachment]
I await your advice.
Warm regards
Warm regards
Check the force flash box.plust wrote: Thu Jan 23, 2025 6:00 am Thank you, Coopervid, for the information via PM.
Warm regards
You didn't follow the tutorial. Shame on you!plust wrote: Thu Jan 23, 2025 6:00 am Thank you, Coopervid, for the information via PM.
Warm regards
Yethidran
yup, you have got to "Tick" the force flash box for it to work its magic.
plust
Ah!
Thank you, MartyMcNuts, Coopervid and Yethidran.
I just went back to the tutorial!
The results are amazing.
Best regards
Best regards
Tigerroll002
Hi Coopervid,
I have the following drive:
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Can you please help me out as well?
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
PM sent.Tigerroll002 wrote: Fri Jan 31, 2025 2:25 pm Hi Coopervid,
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Tigerroll002
Yes,
Please send next PM.
(EDIT)
PP Sent
(EDIT)
PP Sent
MrMustardsMayhem
Hello! If I could get help on making this UHD rip compatible that would be great. I'm on Mac but also have access to a pc
OS device name: /dev/rdisk7
Current profile: CD-ROM
Manufacturer: ASUS
Revision: A102
Serial number: [redacted]
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
Disc Information
Data capacity: 0.32 Gb
Manufacturer: ASUS
Revision: A102
Disc Information
Your drive is a LG. So follow the guide.MrMustardsMayhem wrote: Sun Feb 02, 2025 10:42 pm Hello! If I could get help on making this UHD rip compatible that would be great. I'm on Mac but also have access to a pc
Manufacturer: ASUS
Revision: A102
Disc Information
viewtopic.php?f=16&t=19634
MrMustardsMayhem
I'm following the guide but my Mac won't open any of the files I downloaded
zittrig
The SDFTool is for Windows (10 and higher) only.
