Joker- Folie à Deux ILLEGAL REQUEST:INVALID FIELD IN CDB
Stubborn5228
#1 Post by Stubborn5228 » Thu Jan 23, 2025 12:31 am
Currently trying to backup this movie and hitting a new hurdle for me. Searching has turned up some topics on the error, but not something that I'm understanding as pointing toward a solution. Really hoping for some help. Thanks!
Product: BD-RE WH16NS60
Revision: 1.03
Serial number: ...
Firmware date: 2120-05-08 10:10
Highest AACS version: 77
Firmware version: 1.03
Disc Information
Label: JOKER_FOLIE_À_DEUX
Timestamp: 2024-10-28 15:50:49
Protection: AACS2.0/C v77
Data capacity: 87.96 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
MakeMKV v1.17.8 win(x64-release) started
Using LibreDrive mode (v06.3 id=4083C4CCDB14)
This disc requires Java runtime (JRE), but none was found. Certain functions will fail, please install Java. See http://www.makemkv.com/bdjava/ for details.
File 00009.mpls was added as title #0
Title #00010.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.mpls has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #1
File 00133.mpls was added as title #2
Title #00809.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00008.m2ts was added as title #3
Title #00009.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00059.m2ts was added as title #4
Title #00068.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00074.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00075.m2ts was added as title #5
File 00086.m2ts was added as title #6
File 00102.m2ts was added as title #7
File 00103.m2ts was added as title #8
File 00104.m2ts was added as title #9
File 00105.m2ts was added as title #10
File 00106.m2ts was added as title #11
File 00107.m2ts was added as title #12
File 00108.m2ts was added as title #13
Title #00109.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 13 titles into directory I:/Video/Joker- Folie à Deux
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00075.m2ts' at offset '27438084096'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '27438084096'
Failed to save title 1 to file I:/Video/Joker- Folie à Deux/Joker- Folie à Deux_t01.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00086.m2ts' at offset '0'
Failed to save title 2 to file I:/Video/Joker- Folie à Deux/Joker- Folie à Deux_t02.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '0'
Failed to save title 3 to file I:/Video/Joker- Folie à Deux/Joker- Folie à Deux_t03.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00059.m2ts' at offset '0'
Failed to save title 4 to file I:/Video/Joker- Folie à Deux/Joker- Folie à Deux_t04.mkv
Failed to save title 6 to file I:/Video/Joker- Folie à Deux/Joker- Folie à Deux_t06.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00102.m2ts' at offset '0'
Failed to save title 7 to file I:/Video/Joker- Folie à Deux/Joker- Folie à Deux_t07.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00103.m2ts' at offset '0'
Failed to save title 8 to file I:/Video/Joker- Folie à Deux/Joker- Folie à Deux_t08.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00104.m2ts' at offset '0'
Failed to save title 9 to file I:/Video/Joker- Folie à Deux/Joker- Folie à Deux_t09.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00105.m2ts' at offset '0'
Failed to save title 10 to file I:/Video/Joker- Folie à Deux/Joker- Folie à Deux_t10.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '0'
Failed to save title 11 to file I:/Video/Joker- Folie à Deux/Joker- Folie à Deux_t11.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00107.m2ts' at offset '0'
Failed to save title 12 to file I:/Video/Joker- Folie à Deux/Joker- Folie à Deux_t12.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00108.m2ts' at offset '0'
Failed to save title 13 to file I:/Video/Joker- Folie à Deux/Joker- Folie à Deux_t13.mkv
Encountered 1 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
1 titles saved, 12 failed
