LG WH16NS60 'no disc', but DVDs read fine
hamlet101
#1 Post by hamlet101 » Wed Jan 22, 2025 10:04 pm
My LG has done over 400 blu-ray rips, but now MKV says 'no-disc' when I put a bluray in, and Windows 11 won't recognize the bluray either. It still reads DVDs fine though.
Does this mean game over and the bluray laser must have died? Or anything worth trying before I replace? I did try cleaning it with one of those discs with brushes on (just because they don't cost much so I thought it worth a try).
Re: LG WH16NS60 'no disc', but DVDs read fine
#2 Post by Coopervid » Wed Jan 22, 2025 10:05 pm
hamlet101 wrote: Wed Jan 22, 2025 10:04 pm My LG has done over 400 blu-ray rips, but now MKV says 'no-disc' when I put a bluray in, and Windows 11 won't recognize the bluray either. It still reads DVDs fine though.
Most likely dead laser. My first drive died after a year.
zittrig
#3 Post by zittrig » Fri Jan 24, 2025 9:02 am
hamlet101 wrote: Wed Jan 22, 2025 10:04 pm .... I did try cleaning it with one of those discs with brushes on (just because they don't cost much so I thought it worth a try).
You can try opening the drive (disconnect any cable before) and clean the laser with q-tip and alcohol. Dry immediately with a lint-free soft cloth or dry q-tip. Do it twice.
If the drive doesn't read BD after this you can assume that the laser is dead.
