Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested & Makemkv Discount Code
dellsam34
Re: Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested & Makemkv Discount Code
#931 Post by dellsam34 » Wed Jan 22, 2025 10:46 am
The main rip guide thread lists 3 speeds for ripping BD100, 1hr, 1hr 5min and 1hr 35min, out of the 3 which one is 4x?
#932 Post by Billycar11 » Wed Jan 22, 2025 10:57 am
dellsam34 wrote: Wed Jan 22, 2025 10:46 am The main rip guide thread lists 3 speeds for ripping BD100, 1hr, 1hr 5min and 1hr 35min, out of the 3 which one is 4x?
nah guide says it right 1H for BD66 1HR 30M for BD100
dellsam34
#933 Post by dellsam34 » Wed Jan 22, 2025 11:09 am
This is a copy paste:
All of these drives will need to be flashed to unlock UHD Reading/Ripping
Speed testes done by Asmcom and Billy
BP60NB10 NB10/12, UHD Official External Slim 9.5mm USB 2.0 | Rip speed 6x BD 66 ~45 mins BD 100 ~1 hour 5mins
BP50NB40 NB50/52, NB72 is not supported UHD Officialish External Slim 9.5mm USB 2.0 | Rip speed 6x BD 66 ~45 mins BD 100 ~1 hour 5mins
LG WH16NS60, UHD Official Internal 5.25 sata | Rip speed 8x BD 66 ~45 mins BD 100 ~1 hour
LG BU40N, UHD Official Internal Slim Sata 9.5mm | Rip speed 6x BD 66 ~45 mins BD 100 ~1 hour 5mins
LG WH14NS40, UHD Friendly Internal 5.25 sata | Rip speed 8x BD 66 ~45 mins BD 100 ~1 hour if flashed properly other wise 6x rips speed and slower then BU40N
LG WH16NS40, UHD Friendly Internal 5.25 sata | Rip speed 8x BD 66 ~45 mins BD 100 ~1 hour if flashed properly other wise 6x rips speed and slower then BU40N
ASUS BW-16D1HT, UHD Friendly Internal 5.25 sata | Rip speed 8x BD 66 ~45 mins BD 100 ~1 hour
ASUS BW-16D1HT Pro, UHD Friendly Internal 5.25 sata | Rip speed 8x BD 66 ~45 mins BD 100 ~1 hour
LG BH16NS55, UHD Friendly Internal 5.25 sata | Rip speed 8x BD 66 ~45 mins BD 100 ~1 hour if flashed properly other wise 6x rip speed and slower then BU40N
Buffalo BRUHD-PU3-BK, UHD Official, External Slim 9.5mm USB 3.0 LG BU40N inside| Rip speed 6x BD 66 ~45 mins BD 100 ~1 hour 5mins
Archgon MD-8107S-U3-UHD, UHD Official, External Slim 9.5mm LG BU40N inside USB 3.0-Marty| Rip speed 6x BD 66 ~45 mins BD 100 ~1 hour 5mins
#934 Post by Billycar11 » Wed Jan 22, 2025 11:54 am
dellsam34 wrote: Wed Jan 22, 2025 11:09 am This is a copy paste:
so is this...
Billycar11 wrote: Mon May 27, 2019 5:20 am
BDR-XD08UMB-S Slim top load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-XD07UHD Slim top load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-XD06JUHD Slim top load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-S12UHT Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-XS07UHD Slim Slot load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-212UBK Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-211UBK Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-UD04 Slim 9.5mm tray load slim sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-S13U-X Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-S13UBK Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
please tell me more if you have a pioneer UHD drive and it works i will add it to the list
ionblue
#935 Post by ionblue » Wed Jan 22, 2025 5:16 pm
Ordered a BDR-S13UBK to replace yet another drive that went tits up and so far so good. I put it into an OWC case with slight modification and it happily ripped a known good UHD disc without issue. Honestly have to say I’ve never in all my years of working with computers heard a drive this quiet. If it wasn’t for the light on the front and the progress bar in MakeMKV, I wouldn’t know it was active! It isn’t the speediest thing, but as long as this thing is more reliable than my other drives, I’ll be a happy camper.
Thanks Billy!
dellsam34
#936 Post by dellsam34 » Thu Jan 23, 2025 8:00 am
Billycar11 wrote: Wed Jan 22, 2025 11:54 am
so is this...
Help me understand you, Are you saying that you have only drives that rip BD100 @ 1hr 35min? or are you saying that there is no drive that can rip BD100 faster than 1hr 35min? From one of your previous posts you wrote:
all RIP UHD at 4X max
When I asked you what 4x translates to in terms of time and gave you 3 speeds for ripping BD100, your answer was more confusing, you said:
about yeah first one for BD66 second for BD100
I'm just doing my homework to buy the fastest player for ripping, Sorry if I sound more persistent.
#937 Post by MartyMcNuts » Thu Jan 23, 2025 9:43 am
dellsam34 wrote: Thu Jan 23, 2025 8:00 am
so is this...
All Pioneer drives rip UHD at max 4x speed. LG external slim drives rip UHD at max 6x speed. Some LG desktop drives that are flashed to WH16NS60 firmware can reach speeds of 8x for UHD but they do not maintain this speed for very long. Most of a rip would be between 4x - 6x with some short increases to 8x.
Be aware that for UHD, Pioneer drives are recommended as they read slower (which is better for UHD, means much greater chance of a successful rip) and are far more reliable than any LG/ASUS drive.
Ripping UHD at 4x, for BD100 discs, expect around 1hr15mins to 1hr40mins depending on the amount of data on the disc. BD66 are usually around 50mins - 65mins, again depending on the amount of data on the disc.
dellsam34
#938 Post by dellsam34 » Thu Jan 23, 2025 9:51 am
Thanks MartyMcNuts, it's more clear now. So will be looking for a Pioneer desktop unit as I like to have the tray closed from the computer.
#939 Post by MartyMcNuts » Thu Jan 23, 2025 10:38 pm
dellsam34 wrote: Thu Jan 23, 2025 9:51 am Thanks MartyMcNuts, it's more clear now. So will be looking for a Pioneer desktop unit as I like to have the tray closed from the computer.
You cannot buy new Pioneer drives from a store as they will have the incompatible firmware (post 11/2022) that is not downgradable. Really, the only way to get a UHD compatible one is from a seller here. The exception is the BDR-212V and BDR-212DBK as these still have older firmware and can be flashed. Just contact Billycar11 if you get one of these.
dellsam34
#940 Post by dellsam34 » Fri Jan 24, 2025 7:35 am
No, I'm not looking to buy a virgin drive, looking for a modified one, Looks like the Pioneer BDR-S13UBK SATA 5.25 is what I will go for.
Dagwood
#941 Post by Dagwood » Fri Jan 24, 2025 3:38 pm
Got my BDR-2213 from Billycar11 yesterday. Delivered quickly via USPS and works great. Tested on 4k, Blu-ray, DVD and CD.
I put it in an OWC enclosure that my failed LG WH16NS40 was in. It fits perfectly with no modification (bending) of the mounts required. It is nearly flush on the front with perhaps 1mm sticking out.
This enclosure was purchased with the drive in 2016 but should be physically identical to the one they sell now. Their website says they updated the enclosure in 2021 but I’m guessing they only refreshed the controller.
#942 Post by Billycar11 » Sat Jan 25, 2025 3:54 am
Dagwood wrote: Fri Jan 24, 2025 3:38 pm Got my BDR-2213 from Billycar11 yesterday. Delivered quickly via USPS and works great. Tested on 4k, Blu-ray, DVD and CD.
thanks for the review
but i can confirm the new one does not fit pioneers with out slotting the holes or bending them i had a old one too where it barley sticks out
the new pcb in the back is bigger so drive cant slide back more
Untitled
#943 Post by Untitled » Sat Jan 25, 2025 5:47 pm
Hey, was wondering if you planned on restocking your BDR-S13UBK drives?
#944 Post by Billycar11 » Sun Jan 26, 2025 1:55 am
Untitled wrote: Sat Jan 25, 2025 5:47 pm Hey, was wondering if you planned on restocking your BDR-S13UBK drives?
yeah email me i got 12 today working on them now
Tom899
#945 Post by Tom899 » Mon Jan 27, 2025 12:37 pm
Hello Billy, I have a Pioneer drive from you, plus purchased your flashing service for another drive. All working great!
I have a total of (4) drives working, two internal and two external. My two external drives are in Vantec NST-536S3-BK NexStar DX USB 3.0 External Enclosures.
I just noticed your warranty, about not honoring drives in Vantec enclosures. This to me implies there is something seriously wrong with Vantec enclosures? Please explain?
Should I swap out my two Vantec enclosures for your suggested OWC enclosures?
Tom
