UHD Drive recomended
JAH73
Post by JAH73 » Wed Jan 22, 2025 9:49 am
Good morning
I want to buy a new UHD drive for Blu-ray and I don't know which one to choose or which one is the most compatible with 'MakeMKV'. Please could you recommend a model that I can buy, preferably on Amazon, to make copies of my Blu-rays and 4K Blu-rays?
Re: UHD Drive recomended
Post by Woodstock » Wed Jan 22, 2025 2:03 pm
Is there a problem with the Ultimate UHD Drives Flashing Guide Updated 2025 topic that makes it inaccessible to you?
Post by dcoke22 » Wed Jan 22, 2025 4:50 pm
Pioneer drives are considered the best, but they pretty much all come with new firmware that is incompatible. The sellers on this forum have some Pioneer drives with older, compatible firmware.
If you live in Europe, you could buy a Verbatim 43888 which will probably come with an older Pioneer drive inside it (although not always) that will work with MakeMKV out of the box. This drive isn't quite as good a newer full sized Pioneer drive, but it is cheaper and potentially easier to get.
There are potentially other specialty Pioneer drives that can be flashed to work with MakeMKV. I don't have any experience with them, but look for posts from Coopervid.
After the Pioneer drives, the slim LG drives are probably the best. The BU40N or some of the newer variants. Before we had access to the Pioneer drives, these were considered the best. They all have to be flashed, but they're probably relatively easy to come by. With any of the slim drives, the key is making sure they get plenty of power from high powered USB ports.
The LG/ASUS full sized internal drives are probably ranked at the bottom of the list. These drives have to be flashed. You might get one that works well, but the quality of these drives has gone down in recent years. The possibility of a DOA drive is relatively high and there are lots of reports of these drives suffering an early death. If you find yourself buying one of these drives, buy the cheapest one you can find from a place with a good return policy. Despite whatever branding is on the box, they're all the same inside and all made by LG.
EvilJim
Post by EvilJim » Fri Sep 12, 2025 1:06 am
Yes there is, your butt.
zittrig
Post by zittrig » Fri Sep 12, 2025 6:17 am
:roll:
You weren't even the addressee of Woodstocks post.
But very adult and socially competent behavior towards someone who has helped you in another thread.
You can keep the irony.
