Yeah wh16ns60 1.00 or 1.02mkcharly700 wrote: Sat Jan 18, 2025 10:34 pmHello, is there a better firmware for my recorder (UHD friendly, sleep bug)? If so, which one should I flash? Thank you.Code: Select all
Laufwerksinformation OS-Gerätename: D: Produzent: HL-DT-ST Produkt: BD-RE BE16NU50 Revision: 1.00 Serienummer: Firmware-Datum: 2116-03-17 13:36 Markierungen der Bus-Verschlüsselung: 17 Highest AACS version: 76 LibreDrive Information Status: Enabled Drive platform: MT1959 Firmware type: Original (unpatched) Firmware version: 1.00 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes Keine Disk eingelegt
I'm trying to flash an LG BP60NB10 drive. This is my first attempt at a flash, so go easy on me.
Here's the drive info:
I'm following the steps for Mac. When I tried to flash to the firmware provided in the all-you-need pack, I got this:
After rechecking the guide, I saw that the drive was using encrypted firmware, so I grabbed the MK version but got the same result.
Obviously, I'm missing something. Could someone point me in the right direction?
OS device name: /dev/rdisk5
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM04OAGE4325
Firmware date: 2121-07-08 15:56
Hardware support: Yes
Firmware support: No
Firmware version: 1.02
Unrestricted read speed: Possible (with patched firmware)Code: Select all
Drive "/IOBDServices/D5D25996" not foundObviously, I'm missing something. Could someone point me in the right direction?
See steps 6zprewitt wrote: Sun Jan 19, 2025 5:48 pm I'm trying to flash an LG BP60NB10 drive. This is my first attempt at a flash, so go easy on me.
I'm following the steps for Mac. When I tried to flash to the firmware provided in the all-you-need pack, I got this:Code: Select all
Drive Information OS device name: /dev/rdisk5 Current profile: BD-ROM Manufacturer: HL-DT-ST Product: BD-RE BP60NB10 Revision: 1.02 Serial number: SIM04OAGE4325 Firmware date: 2121-07-08 15:56 Bus encryption flags: 17 Highest AACS version: 76 LibreDrive Information Status: Possible (with patched firmware) Drive platform: MT1959 Hardware support: Yes Firmware support: No Firmware type: Original (patched version available) Firmware version: 1.02 DVD all regions: Possible (with patched firmware) BD raw data read: Possible (with patched firmware) BD raw metadata read: Possible (with patched firmware) Unrestricted read speed: Possible (with patched firmware)
After rechecking the guide, I saw that the drive was using encrypted firmware, so I grabbed the MK version but got the same result.Code: Select all
You need to use your ID not the example
Oop, I forgot to mention that. When I type in the command in Step 6, I see thisBillycar11 wrote: Sun Jan 19, 2025 5:58 pmSee steps 6zprewitt wrote: Sun Jan 19, 2025 5:48 pm I'm trying to flash an LG BP60NB10 drive. This is my first attempt at a flash, so go easy on me.
Found 1 drives(s)
00:
HL-DT-ST_BD-RE_BP60NB10_1.02_212107081556_SIM04OAGE4325Re: Ultimate UHD Drives Flashing Guide Updated 2025
Solved. For anyone else having the same issue: Just make sure your drive is connected directly to your mac and not a USB bank.zprewitt wrote: Sun Jan 19, 2025 6:01 pmOop, I forgot to mention that. When I type in the command in Step 6, I see thisBillycar11 wrote: Sun Jan 19, 2025 5:58 pmSee steps 6zprewitt wrote: Sun Jan 19, 2025 5:48 pm I'm trying to flash an LG BP60NB10 drive. This is my first attempt at a flash, so go easy on me.
Shouldn't it also be showing me the ID as well?Code: Select all
Found 1 drives(s) 00: HL-DT-ST_BD-RE_BP60NB10_1.02_212107081556_SIM04OAGE4325
thelapperdapper
Important
The latest version as of now (1.17.
is unable to flash firmware, at least on linux.
The steps to do this on linux is
1. Install the latest version of makemkv
2. Copy the needed libraries to a temporary dir
3. Uninstall makemkv (E.g sudo pacman -R makemkv)
4. Download makemkv-1.17.6.tar.gz (https://www.makemkv.com/download/old/ma ... 7.6.tar.gz)
5. Extract it to a certain location (for example Downloads):
6. Install it
7. DONE. Flashing should now work again.
In order to install a newer version run
mkdir ~/Downloads && cp /usr/lib/libmakemkv.so.1 /usr/lib/libdriveio.so.0 ~/Downloads
cd ~/Downloads && tar -xzf makemkv-bin-1.17.6.tar.gz
cd makemkv-bin-1.17.6 && sudo make install
sudo rm /usr/bin/makemkvcon /usr/bin/sdftool /usr/share/MakeMKV/* /usr/lib/libdriveio.so.0 /usr/lib/libmakemkv.so.1
ThatGuyName
I keep trying this and it always gives me the same response when I go to flash:
"Input file not found -- /HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935
Internal error 0x83000001"
I've tried it bothe ways: "enc" and "main"
whats the problem here?
I'm using the LG slim BP60NB10 btw.
Thanks for the guide and firmware. I successfully flashed a WH16NS40 just purchased of Amazon.
https://www.amazon.com/dp/B00E7B08MS
Show your command line and make sure the bin file is available and named right.ThatGuyName wrote: Wed Jan 22, 2025 4:47 pm I keep trying this and it always gives me the same response when I go to flash:
ThatGuyName
I ended up fixing it! dcoke22 helped me.Coopervid wrote: Fri Jan 24, 2025 5:45 pmShow your command line and make sure the bin file is available and named right.ThatGuyName wrote: Wed Jan 22, 2025 4:47 pm I keep trying this and it always gives me the same response when I go to flash:
Hi, new to this so appologies. Having read most of the guides and the firs5 post i am still missing some basics and want to check what i think is correct. If i purchased a new BDR-XS07TUHD from Amazon this will not work with makemkv as the firmware is going to be unpatchable. Instead I need to find one for sale that’s older. Do these drives ever get patched as in are people working on patching them/finding exploits? Do any new external drives work straight off the shelf
No new Pioneer external drives work for UHD at all. They all have post 11/2022 unpatchable firmware. This has been worked on for 2+ years now without success. It's not looking good.spamtom wrote: Sun Jan 26, 2025 3:33 pm Hi, new to this so appologies. Having read most of the guides and the firs5 post i am still missing some basics and want to check what i think is correct. If i purchased a new BDR-XS07TUHD from Amazon this will not work with makemkv as the firmware is going to be unpatchable. Instead I need to find one for sale that’s older. Do these drives ever get patched as in are people working on patching them/finding exploits? Do any new external drives work straight off the shelf
The only external drive that still currently works OOTB is the Verbatim 43888 (Pioneer BDR-UD04 version). The Verbatim 43888 (LG BU40N version can be flashed).
Is buying the makemkv license required to make a rip?
