ASUS SBW-06D2X-U
Re: ASUS SBW-06D2X-U
Ravsky wrote: Mon Jan 20, 2025 9:50 am Hi, Is this drive has update?
OS device name: H:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.11
Serial number: ...
Firmware date: 2023-04-20
Firmware version: ID22
PM is coming in a few minutes.
plust
Post by plust »
Hi Coopervid,
I'm trying to enable LibreDrive.
Could you please do me a PM too?
Manufacturer: ASUS
Revision: 1.10
Serial number: ************
Firmware date: 2017-04-18
Thanks for your help
plust wrote: Wed Jan 22, 2025 6:18 am Hi Coopervid,
Manufacturer: ASUS
Revision: 1.10
PM sent.
plust
Post by plust »
Thank you, Coopervid, for the information via PM.
Please see the following error message in red.
[color=#FF0000]Drive and firmware hardware types don't match.[/color]
[attachment=1]2025-01-23 (1).png[/attachment]
Would this be a case of using Force flash, or may there be another explanation?
[attachment=0]2025-01-23 (2).png[/attachment]
I await your advice.
Warm regards
MakeMKV BETA screenshot
2025-01-23 (2).png (32.02 KiB) Viewed 14851 times
BDRFlash screenshot
BDRFlash screenshot
2025-01-23 (1).png (15.47 KiB) Viewed 14851 times
plust wrote: Thu Jan 23, 2025 6:00 am Thank you, Coopervid, for the information via PM.
Warm regards
Check the force flash box.
Warm regards
You didn't follow the tutorial. Shame on you!
Yethidran
Post by Yethidran »
yup, you have got to "Tick" the force flash box for it to work its magic.
plust
Post by plust »
Ah!
Thank you, MartyMcNuts, Coopervid and Yethidran.
I just went back to the tutorial!
The results are amazing.
BDRFlash screenshot
BDRFlash screenshot
2025-01-24 (1).png (15.74 KiB) Viewed 14786 times
MakeMKV REGISTERED screenshot
2025-01-24 (2).png (34.54 KiB) Viewed 14786 times
Best regards
Tigerroll002
Post by Tigerroll002 »
Hi Coopervid,
I have the following drive:
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Can you please help me out as well?
Tigerroll002 wrote: Fri Jan 31, 2025 2:25 pm Hi Coopervid,
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
PM sent.
Tigerroll002
Yes,
Please send next PM.
(EDIT)
PP Sent
MrMustardsMayhem
Post by MrMustardsMayhem »
Hello! If I could get help on making this UHD rip compatible that would be great. I'm on Mac but also have access to a pc
OS device name: /dev/rdisk7
Current profile: CD-ROM
Manufacturer: ASUS
Revision: A102
Serial number: [redacted]
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
Disc Information
Data capacity: 0.32 Gb
MrMustardsMayhem wrote: Sun Feb 02, 2025 10:42 pm Hello! If I could get help on making this UHD rip compatible that would be great. I'm on Mac but also have access to a pc
Manufacturer: ASUS
Revision: A102
Disc Information
Your drive is a LG. So follow the guide.
viewtopic.php?f=16&t=19634
MrMustardsMayhem
I'm following the guide but my Mac won't open any of the files I downloaded
zittrig
Post by zittrig »
The SDFTool is for Windows (10 and higher) only.
