Coopervid wrote: Sun Jan 19, 2025 10:18 amPM sent.alpensiedler wrote: Sun Jan 19, 2025 4:11 am hi coopervid, would you happen to have a uhd firmware that would work for my 43890:
many thanks in advance and have a great weekend!Code: Select all
Laufwerksinformation OS-Gerätename: E: Produzent: PIONEER Produkt: BD-RW BDR-UD03 Revision: 1.14 Serienummer: ... Firmware-Datum: 2020-06-15 Markierungen der Bus-Verschlüsselung: 1B Highest AACS version: 76 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
I too am having the same issue with my 43890. Any chance I could get that firmware too?
PM sent.cskibbe63 wrote: Tue Jan 21, 2025 12:16 pm I too am having the same issue with my 43890. Any chance I could get that firmware too?Coopervid wrote: Sun Jan 19, 2025 10:18 amPM sent.alpensiedler wrote: Sun Jan 19, 2025 4:11 am hi coopervid, would you happen to have a uhd firmware that would work for my 43890:
Fantastic! Read and sent.
PM with package is coming.cskibbe63 wrote: Tue Jan 21, 2025 12:16 pm I too am having the same issue with my 43890. Any chance I could get that firmware too?Coopervid wrote: Sun Jan 19, 2025 10:18 amPM sent.alpensiedler wrote: Sun Jan 19, 2025 4:11 am hi coopervid, would you happen to have a uhd firmware that would work for my 43890:
Orderlydinosaur
Hey Cooper, would I be able to get that FW as well?
Is device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ...
Firmware date: 2020-06-15
Hignest AAOS version: 76
Drive platform: R83511
DVD al regions: Yes
Read your PM.Orderlydinosaur wrote: Wed Jan 22, 2025 8:56 amHey Cooper, would I be able to get that FW as well?
Is device name: E:
Revision: 1.14
Serial number: ...
DVD al regions: Yes
gundelpfanne
Hello i have a Problem with my BDR Pioneer.
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.14
Serienummer: ...
Can i have the modded Firmware.
Thank You
mfg gundelpfanne
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.14
Serienummer: ...
Thank You
mfg gundelpfanne
Hi, Coopervid,Coopervid wrote: Wed Jan 08, 2025 9:03 pmPM is coming.juanan wrote: Wed Jan 08, 2025 4:08 pm HI!
I have the same problem. After several weeks using Verbatim 43890 to play/record Blurays with success,
I´ve just tried to read a UHD disks with this Makemkv result:
Información de unidad de disco
Nombre del SO del dispositivo: H:
Fabricante: PIONEER
Producto: BD-RW BDR-UD03
Revisión: 1.14
Número de serie: BDDLXXXXXXWL
Fecha del firmware: 2020-06-15
Marcas de cifrado bus: 1B
Highest AACS version: 17
LibreDrive InformationB
SO, would you please help me to flash my drive?
Thanks in advance
Thanks a lot for your P.M. Now I can read/write UHD disks and my firmware is PIONEER BDR-UD04.
Thanks again, you´re my hero...!
PM sent.gundelpfanne wrote: Sun Jan 26, 2025 10:56 am Hello i have a Problem with my BDR Pioneer.
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.14
Serienummer: ...
Thank You
mfg gundelpfanne
Could my drive also be done from this information?
Revision: 1.14
Serial number: ...
Highest AACS version: 42
Hello, I just got this drive and I have the same issue:
Could I get that custom firmware as well?
OS device name: /dev/sr0
Current profile: DVD-ROM
Revision: 1.14
Serial number: *****
Unrestricted read speed: YesRe: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Hi Coopervid,
can i get the firmware too for my 43890 ?
thanks
thanks
Looking for the same on my 43890:
OS device name: I:
Revision: 1.14
Serial number: ...
Highest AACS version: 81
OS device name: I:
Revision: 1.14
Serial number: ...
spacegodzilla11
I just purchased this external blu-ray drive and I am looking to rip UHD 4k.
Email me your makemkv drive info sectionspacegodzilla11 wrote: Fri Jan 31, 2025 3:54 pm I just purchased this external blu-ray drive and I am looking to rip UHD 4k.
See email below
