Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
#496 Post by Coopervid » Sat Jan 18, 2025 9:45 pm
Furiosa_NAS wrote: Sat Jan 18, 2025 5:31 pm The disc drive in my Zappiti/R_volution NAS seems to be on strike, so I am trying to use my external blu-ray drive but need UHD enabled.
Any and all help appreciated:
OS device name: /dev/rdisk7
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ...
Firmware date: 2020-06-15
Highest AACS version: 70
Drive platform: RS8511
Firmware version: 1.14
PM sent.
kirlax09
#497 Post by kirlax09 » Sun Jan 19, 2025 6:29 am
Hi, I just purchased this drive. Is it possible to update it so that it works with UHD discs?
Revision: 1.14
Serial number: **********
Highest AACS version: 23
Thank You!
Furiosa_NAS
#498 Post by Furiosa_NAS » Sun Jan 19, 2025 8:29 am
Many thanks Coopevid--please PM the mail address--all is well again :-)
#499 Post by Coopervid » Mon Jan 20, 2025 11:27 am
kirlax09 wrote: Sun Jan 19, 2025 6:29 am Hi, I just purchased this drive. Is it possible to update it so that it works with UHD discs?
Revision: 1.14
Thank You!
PM sent
#500 Post by Coopervid » Mon Jan 20, 2025 3:05 pm
Furiosa_NAS wrote: Sun Jan 19, 2025 8:29 am Many thanks Coopevid--please PM the mail address--all is well again :-)
Thanks buddy! Highly appreciated!
#501 Post by Coopervid » Tue Jan 21, 2025 10:19 am
Revision: 1.14
Thank You!
PM sent.
kirlax09
#502 Post by kirlax09 » Tue Jan 21, 2025 11:28 am
Thank you coopervid, flash worked great!
Yethidran
#503 Post by Yethidran » Tue Jan 21, 2025 11:30 am
With Coopervid's unending help, i have successfully flashed 2 sets of BDR-UD03 to become 2 sets of BDR-UD04.
Attached below was the "Original UD03 firmware readout via MakeMKV just for info purposes. 1 set was a BDR-UD03 and the other was a BDR-UD03"D".
Thanks Buddy Coopervid!! Cheer's!!!
OS device name: F:
Revision: 1.03
Serial number: ...
Firmware date: 2015-05-14
Highest AACS version: 68
Drive platform: RS8510
Firmware version: 1.03/ID19
OS device name: I:
Product: BD-RW BDR-UD03D
Revision: 1.00
Serial number: ...
Firmware date: 2014-05-14
Firmware version: 1.00/ID84
Yethidran
#504 Post by Yethidran » Tue Jan 21, 2025 11:32 am
And now its a BDR-UD04. Yahoo!!!!!
OS device name: J:
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: ...
Drive platform: RS8A10
Jasonfortheworld
#505 Post by Jasonfortheworld » Fri Jan 24, 2025 10:31 pm
Howdy Coopervid! if you can, are you able to help out with these two drives I have?
Drive #1
OS device name: H:
Revision: 1.14
Serial number: ...
Highest AACS version: 77
Drive #2
OS device name: O:
Revision: 1.14
Serial number: ...
#506 Post by Coopervid » Sat Jan 25, 2025 10:56 am
Jasonfortheworld wrote: Fri Jan 24, 2025 10:31 pm Howdy Coopervid! if you can, are you able to help out with these two drives I have?
Drive #1
OS device name: H:
Revision: 1.14
Serial number: ...
Drive #2
OS device name: O:
Revision: 1.14
Serial number: ...
PM sent.
d00bster
#507 Post by d00bster » Sat Jan 25, 2025 2:42 pm
Hello. I wonder, if this drive can be patched to support UHD:
Laufwerksinformation
OS-Gerätename: /dev/sr0
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: <REDACTED>
Firmware-Datum: 2020-06-15
Highest AACS version: 81
Thanks.
#508 Post by Coopervid » Sat Jan 25, 2025 3:06 pm
d00bster wrote: Sat Jan 25, 2025 2:42 pm Hello. I wonder, if this drive can be patched to support UHD:
Produzent: PIONEER
Revision: 1.14
Thanks.
PM sent.
Eisbaerle
#509 Post by Eisbaerle » Sat Jan 25, 2025 11:13 pm
my drive is
OS-Gerätename: \Device\CdRom0
Produzent: ASUS
Produkt: SBW-06D5H-U
Revision: E101
Serienummer: xxxxxxxxxxxxx
Firmware-Datum: 2018-08-22
Firmware version: E101/ID26
it seems not to read UHD disks as of now. Is it able to at all?
#510 Post by Coopervid » Sun Jan 26, 2025 11:16 am
Eisbaerle wrote: Sat Jan 25, 2025 11:13 pm Hi,
my drive is
Produzent: ASUS
Revision: E101
PM sent.
