ASUS BW-16D1X-U - Flashable?
Re: ASUS BW-16D1X-U - Flashable?
#61 Post by Coopervid » Mon Jan 20, 2025 7:35 pm
zootzoot wrote: Sun Jan 19, 2025 2:50 pm Hi!
Seeing as though there seems to be a lot of drives that is capable of flashing to a 4k-ripping capable state, I figured I'd try my luck as well. My hopes are low seeing as there's hardly any mentions of this exact drive, but I'd like to be sure that I'm not missing anything. This is my drive:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E104
Firmware date: 2017-06-14
Highest AACS version: 31
Drive platform: RS8600
Firmware version: E104/ID71
If there is any way to get this 4k-ripping capable I would really apreciate the help!
You have another PM.
#62 Post by Coopervid » Mon Jan 20, 2025 8:02 pm
zootzoot wrote: Mon Jan 20, 2025 7:06 pm
Coopervid wrote: Sun Jan 19, 2025 9:53 pm
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E104
PM sent
Since I can't answer your PM's I'll answer here; I've done what you asked.
PM with instructions sent. Sometimes there are delays with PMs.
zootzoot
#63 Post by zootzoot » Tue Jan 21, 2025 4:40 pm
Coopervid wrote: Mon Jan 20, 2025 8:02 pm
PM sent
It works like a charm, thank you very much for the help!
hamak
#64 Post by hamak » Wed Jan 22, 2025 7:56 pm
Hello there
I also have this ASUS BW-16D1X-U but it only hangs when i try both DVD and Bluray. The first time i started it hung on downloading sdf for about 15 minutes so I tried to download it and place it in the .MakeMKV folder but still it is hanging
here is the drive info i got when putting in a cd
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
Firmware date: 2020-07-21
Firmware version: ID76
can someone help me please?
#65 Post by Coopervid » Thu Jan 23, 2025 11:19 am
hamak wrote: Wed Jan 22, 2025 7:56 pm Hello there
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
You should show us the information Makemkv shows when you insert a disc.
hamak
#66 Post by hamak » Thu Jan 23, 2025 11:30 am
Here is from MakeMKV
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
Disc Information
Label: Arn2_Hyr
Timestamp: 2008-10-22 15:05:19
Protection: CSS/CPPM
Data capacity: 7.42 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (PTP)
#67 Post by Coopervid » Thu Jan 23, 2025 4:21 pm
hamak wrote: Thu Jan 23, 2025 11:30 am Here is from MakeMKV
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
Disc Information
Label: Arn2_Hyr
Disc type: DVD-ROM
Disc size: 120mm
Not that but what it shows in the bottom part after inserting a disc. Please copy & paste it and add it to your next post.
hamak
#68 Post by hamak » Thu Jan 23, 2025 7:03 pm
Here is short video of problem but there is not information when it hangs
simplescreenrecorder-2025-01-23_20.00.31.mp4
(2.3 MiB) Downloaded 1904 times
#69 Post by Coopervid » Thu Jan 23, 2025 7:45 pm
Does the disc appear in Windows Explorer? Just insert disc without starting Makemkv. If not there is a hardware problem. Either the cables or the drive itself. If it appears, please reinstall Makemkv and try again. If it still doesn't work we should communicate via PM if you are all set to do so.
hamak
#70 Post by hamak » Thu Jan 23, 2025 7:51 pm
I run MX Linux but yes it appears in filemanager and i can see the files but they are locked. I can install windows 10 or 11 if you want to test there? and yes PM is good i think. I have never tried this. This is my first time on this forum and I have never done PM. maybe it is better to do anydesk og teamviewer so you can see my desktop?
Here is from windows 10 Pro and makemkv when i start it
MakeMKV v1.17.8 win(x64-release) started
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
Saved FW dump file as C:\Users\Knut/.MakeMKV/dump_FW_A68B73ABA85B9EE2D388.tgz
Please send the file "C:\Users\Knut/.MakeMKV/dump_FW_A68B73ABA85B9EE2D388.tgz" to support@makemkv.com
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading 'BD-RE ASUS BW-16D1X-U E113 DCDL107630WL' at offset '524288'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading 'BD-RE ASUS BW-16D1X-U E113 DCDL107630WL' at offset '1048576'
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE ASUS BW-16D1X-U E113 DCDL107630WL' at offset '32768'
#71 Post by Coopervid » Thu Jan 23, 2025 8:00 pm
hamak wrote: Thu Jan 23, 2025 7:51 pm I run MX Linux but yes it appears in filemanager and i can see the files but they are locked. I can install windows 10 or 11 if you want to test there? and yes PM is good i think. I have never tried this. This is my first time on this forum and I have never done PM. maybe it is better to do anydesk og teamviewer so you can see my desktop?
Read your PM. You need to do this in Windows.
hamak
#72 Post by hamak » Fri Jan 24, 2025 4:34 am
SOLVED by Coopervid !!!
This FW-upgrade worked PERFECT!
Thank you very very very much Coopervid !!
Now I am ripping in Bluray with no problem and no hanging anymore :-)
Both windows and Linux is Ripping like a dream
I have attached the screenshots in your PM from after upgrade and from makeMKV in windows and Linux and the logfiles from both and as you see it is PERFECT !!! :-)
Thank you again you saved my day! :-)
ShadowSorcery
#73 Post by ShadowSorcery » Fri Jan 24, 2025 11:06 am
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
Saved FW dump file as C:\Users\/.MakeMKV/dump_FW_A68B73ABA85B9EE2D388.tgz
Please send the file "C:\Users\/.MakeMKV/dump_FW_A68B73ABA85B9EE2D388.tgz" to support@makemkv.com
is it good for flashing?
#74 Post by Coopervid » Sat Jan 25, 2025 8:46 pm
ShadowSorcery wrote: Fri Jan 24, 2025 11:06 am Drive Information
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
PM sent.
ShadowSorcery
#75 Post by ShadowSorcery » Sun Jan 26, 2025 1:32 pm
now im getting this error Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00146.m2ts' at offset '0
