I believe every one of the 100 or so blurays I have ripped to date have had an input aspect ratio SAR=1:1 and DAR=16:9. They display fine with the correct aspect ratio. However the mkv (using the latest makemkv 1.6.16) of 'Pirates of the Caribbean: Dead Man's Chest' reports a SAR=65509:45568 & DAR=2911:1139 (and a correct 1920x1080 size) and plays back vertically compressed as one might expect with these values. The MPEG4 track info seem reasonable in makemkv:
Track information
Type: Video
Codec: Mpeg4
Resolution: 1920x1080
Aspect ratio: 16:9
Frame rate: 23.976 (24000/1001)
Ideas?
Pirates of the Caribbean: Dead Man's Chest => bad SAR & DAR
WCVanHorne
WCVanHorne
Re: Pirates of the Caribbean: Dead Man's Chest => bad SAR &
Can you post the full output from mediaInfo for the created MKV file?
WCVanHorne
I don't immediately see anything amiss and have attached it last. It think it is in the stream rather than the container/headers.
On that note just below are a few frames of the ffdshow OSD, first normal:
Now Pirates 2:
Mediainfo full output:
;Input description: ;Input aspect ratio: ;Movie length: ;Input size and aspect ratio: ;Input bitrate: ;Decoder FPS: ;Output aspect ratio: ;Decoder: ;Movie FPS: ;CPU load: ;Accurate deblocking: ;Input size: ;Current frame: ;Encoder info: ;Remaining time: ;Frame type: ;IDCT(libavcodec):
;AVC1 (ffmpeg-mt h264);SAR: 1/1, DAR: 16/9;01:51:09;1920x1080, SAR: 1/1, DAR: 16/9;98 kbps;32.26;SAR: 1/1, DAR: 16/9;ffmpeg-mt h264;23.976 ;100%;yes;1920x1080;3;unknown;01:51:09;P QPEL;unknown
;AVC1 (ffmpeg-mt h264);SAR: 1/1, DAR: 16/9;01:51:09;1920x1080, SAR: 1/1, DAR: 16/9;80 kbps;21.28;SAR: 1/1, DAR: 16/9;ffmpeg-mt h264;23.976 ;100%;yes;1920x1080;4;unknown;01:51:09;P QPEL;unknownCode: Select all
;AVC1 (ffmpeg-mt h264);SAR: 65509/45568, DAR: 2911/1139;02:30:39;1920x1080, SAR: 65509/45568, DAR: 2911/1139;29047 kbps; 0.00;SAR: 1/1, DAR: 16/9;ffmpeg-mt h264;23.976 ;41%;yes;1920x1080;562;unknown;02:30:16;B QPEL;unknown
;AVC1 (ffmpeg-mt h264);SAR: 65509/45568, DAR: 2911/1139;02:30:39;1920x1080, SAR: 65509/45568, DAR: 2911/1139;29039 kbps;21.28;SAR: 1/1, DAR: 16/9;ffmpeg-mt h264;23.976 ;41%;yes;1920x1080;563;unknown;02:30:16;B QPEL;unknownCode: Select all
C:\Video\PIRATES2>mediainfo -f title00.mkv
General
Count : 278
Count of stream of this kind : 1
Kind of stream : General
Stream identifier : 0
Unique ID : 268135772112884239309277073386894740644
Unique ID : 268135772112884239309277073386894740644 (0xC9B9123E93E29EEA0670DBFF59A74CA4)
Count of video streams : 1
Count of audio streams : 1
Count of menu streams : 1
Video_Format_List : AVC
Video_Format_WithHint_List : AVC
Codecs Video : AVC
Video_Language_List : English
Audio_Format_List : AC-3
Audio_Format_WithHint_List : AC-3
Audio codecs : AC3
Audio_Language_List : English
Complete name : title00.mkv
File name : title00
File extension : mkv
Format : Matroska
Format : Matroska
Format/Url : http://packs.matroska.org/
Format/Extensions usually used : mkv mk3d mka mks
Commercial name : Matroska
Format version : Version 2
Codec : Matroska
Codec : Matroska
Codec/Url : http://packs.matroska.org/
Codec/Extensions usually used : mkv mk3d mka mks
File size : 22183033103
File size : 20.7 GiB
File size : 21 GiB
File size : 21 GiB
File size : 20.66 GiB
Duration : 9039030
Duration : 2h 30mn
Duration : 2h 30mn 39s 30ms
Duration : 2h 30mn
Duration : 02:30:39.030
Overall bit rate : 19633109
Overall bit rate : 19.6 Mbps
Stream size : 441421870
Stream size : 421 MiB (2%)
Stream size : 421.0 MiB
Proportion of this stream : 0.01990
Encoded date : UTC 2011-11-10 04:27:38
File creation date : UTC 2011-11-10 04:27:38.228
File creation date (local) : 2011-11-09 21:27:38.228
File last modification date : UTC 2011-11-10 05:08:25.572
File last modification date (local) : 2011-11-09 22:08:25.572
Writing application : MakeMKV v1.6.16 win(x86-release)
Writing library : libmakemkv v1.6.16 (1.2.0/1.1.0) win(x86-release)
Video
Count : 205
Kind of stream : Video
Unique ID : 1
Format : AVC
Format/Info : Advanced Video Codec
Format/Url : http://developers.videolan.org/x264.html
Commercial name : AVC
Format profile : High@L4.1
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 3
Format settings, ReFrames : 3 frames
Format settings, GOP : M=3, N=24
Internet media type : video/H264
Codec ID : V_MPEG4/ISO/AVC
Codec ID/Url : http://ffdshow-tryout.sourceforge.net/
Codec : V_MPEG4/ISO/AVC
Codec : AVC
Codec/Family : AVC
Codec/Info : Advanced Video Codec
Codec/Url : http://ffdshow-tryout.sourceforge.net/
Codec profile : High@L4.1
Codec settings : CABAC / 3 Ref Frames
Codec settings, CABAC : Yes
Codec_Settings_RefFrames : 3
Duration : 9039039
Duration : 2h 30mn
Duration : 2h 30mn 39s 39ms
Duration : 2h 30mn
Duration : 02:30:39.039
Bit rate : 18602410
Bit rate : 18.6 Mbps
Width : 1920
Width : 1 920 pixels
Height : 1080
Height : 1 080 pixels
Pixel aspect ratio : 1.000
Display aspect ratio : 1.778
Display aspect ratio : 16:9
Frame rate : 23.976
Frame rate : 23.976 fps
Frame count : 216720
Resolution : 8
Resolution : 8 bits
Colorimetry : 4:2:0
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8
Bit depth : 8 bits
Scan type : Progressive
Interlacement : PPF
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.374
Delay : 0
Delay : 00:00:00.000
Delay, origin : Container
Stream size : 21018488833
Stream size : 19.6 GiB (95%)
Stream size : 20 GiB
Stream size : 19.57 GiB
Proportion of this stream : 0.94750
Language : en
Language : English
Language : English
Language : en
Language : eng
Language : en
Default : Yes
Default : Yes
Forced : No
Forced : No
Audio
Count : 201
Kind of stream : Audio
Unique ID : 2
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : AC-3
Mode extension : CM (complete main)
Codec ID : A_AC3
Codec : AC3
Codec : AC3
Codec/Family : AC3
Codec/Info : Dolby AC3
Duration : 9039030
Duration : 2h 30mn
Duration : 2h 30mn
Bit rate mode : CBR
Bit rate mode : Constant
Bit rate : 640000
Bit rate : 640 Kbps
Channel(s) : 6
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Channel positions : 3/2/0.1
Sampling rate : 48000
Sampling rate : 48.0 KHz
Samples count : 433873440
Resolution : 16
Resolution : 16 bits
Bit depth : 16
Bit depth : 16 bits
Compression mode : Lossy
Delay : 0
Delay relative to video : 0
Video0 delay : 0
Stream size : 723122400
Stream size : 690 MiB (3%)
Stream size : 689.6 MiB
Proportion of this stream : 0.03260
Title : 3/2+1
Language : en
Language : English
Language : English
Language : en
Language : eng
Language : en
Default : Yes
Default : Yes
Forced : No
Forced : No
dialnorm : -31
dialnorm/String : -31 dB
compr : 6.02
compr/String : 6.02 dB
dynrng : 1.02
dynrng/String : 1.02 dB
bsid : 8
dialnorm_Average : -31
dialnorm_Average/String : -31 dB
dialnorm_Minimum : -31
dialnorm_Minimum/String : -31 dB
dialnorm_Maximum : -31
dialnorm_Maximum/String : -31 dB
dialnorm_Count : 2
compr_Average : 6.02
compr_Average/String : 6.02 dB
compr_Minimum : 6.02
compr_Minimum/String : 6.02 dB
compr_Maximum : 6.02
compr_Maximum/String : 6.02 dB
compr_Count : 2
dynrng_Average : 1.02
dynrng_Average/String : 1.02 dB
dynrng_Minimum : 1.02
dynrng_Minimum/String : 1.02 dB
dynrng_Maximum : 1.02
dynrng_Maximum/String : 1.02 dB
dynrng_Count : 2
Menu
Count : 100
Kind of stream : Menu
Chapters_Pos_Begin : 72
Chapters_Pos_End : 100
00:00:00.000 : en:Chapter 00
00:04:18.925 : en:Chapter 01
00:09:53.009 : en:Chapter 02
00:12:13.441 : en:Chapter 03
00:19:09.064 : en:Chapter 04
00:23:53.473 : en:Chapter 05
00:30:15.480 : en:Chapter 06
00:35:29.418 : en:Chapter 07
00:40:32.930 : en:Chapter 08
00:46:28.035 : en:Chapter 09
00:50:25.564 : en:Chapter 10
00:56:18.625 : en:Chapter 11
00:59:52.380 : en:Chapter 12
01:05:45.191 : en:Chapter 13
01:11:55.853 : en:Chapter 14
01:17:04.327 : en:Chapter 15
01:22:10.258 : en:Chapter 16
01:30:36.639 : en:Chapter 17
01:34:38.172 : en:Chapter 18
01:39:21.830 : en:Chapter 19
01:44:52.410 : en:Chapter 20
01:49:14.714 : en:Chapter 21
01:54:55.805 : en:Chapter 22
01:59:36.043 : en:Chapter 23
02:04:59.908 : en:Chapter 24
02:10:27.194 : en:Chapter 25
02:16:20.630 : en:Chapter 26
02:21:04.789 : en:Chapter 27
- Contact:
Looks like a bug in MakeMKV. Can you please make a testdump for that title? http://www.makemkv.com/onlinehelp/testdump.htmlWCVanHorne wrote:I believe every one of the 100 or so blurays I have ripped to date have had an input aspect ratio SAR=1:1 and DAR=16:9. They display fine with the correct aspect ratio. However the mkv (using the latest makemkv 1.6.16) of 'Pirates of the Caribbean: Dead Man's Chest' reports a SAR=65509:45568 & DAR=2911:1139 (and a correct 1920x1080 size) and plays back vertically compressed as one might expect with these values. The MPEG4 track info seem reasonable in makemkv:
Track information
Type: Video
Codec: Mpeg4
Aspect ratio: 16:9
Ideas?
WCVanHorne
Sent download link to support@makemkv.com . Please confirm you have received it.
WCVanHorne
Bumping this thread because I've heard nothing and now run across yet another Blu-ray with the *exact* same issue: 'Fantastic Four - Rise of the Silver Surfer'.
Surely I can't be the only one seeing this issue?
