Destruction pictures of my Verbatim 43888 (Pioneer UD04)
Yethidran
Re: Destruction pictures of my Verbatim 43888 (Pioneer UD04)
Post by Yethidran » Sun Jan 19, 2025 4:55 pm
oh yes i bought both these drives Late November 2024.
MK1234Tfan
Post by MK1234Tfan » Mon Jan 20, 2025 3:42 am
Coopervid wrote: Sun Jan 19, 2025 3:24 pm And no, there is no firmware chip on this board. The firmware chip is inside the drive itself.
There very well may be a firmware chip inside the drive itself. And I'm not trying to be rude or anything, but this right here is definitely a sop8 spi flash chip. There's some type of firmware on that little PCB. These slimline models may not have enough space inside the drive itself to include the chip and would explain why it would be on a separate PCB outside of the drive, but still in the enclosure.
I've flashed and dumped a lot of them in the past. The part number will confirm this in the datasheet.
I'm going to see if I can buy one of these for parts somewhere to see if I can dump what's on that chip.
Yethidran
Post by Yethidran » Mon Jan 20, 2025 4:07 am
Yethidran
Post by Yethidran » Mon Jan 20, 2025 4:08 am
Yethidran
Post by Yethidran » Mon Jan 20, 2025 4:14 am
i tried my very best to get the pictures as clear as possible.
but i believe what Coopervid said is the truth.
The chip located within each and every drive is located within the drive itself,
And not on the thin green strip of that usb board. (i believe that green board is just for the usb signal transfer)
MK1234Tfan
Post by MK1234Tfan » Mon Jan 20, 2025 4:22 am
Unfortunately it's not clear enough to see the part number. It looks like GD (GigaDevice) which does make SPI NOR Flash memory chips. Oh well..
Post by Billycar11 » Mon Jan 20, 2025 9:02 am
MK1234Tfan wrote: Mon Jan 20, 2025 3:42 am There very well may be a firmware chip inside the drive itself. And I'm not trying to be rude or anything, but this right here is definitely a sop8 spi flash chip. There's some type of firmware on that little PCB. These slimline models may not have enough space inside the drive itself to include the chip and would explain why it would be on a separate PCB outside of the drive, but still in the enclosure.
that may be a flash chip but its not the drives firmware as the UD04 works direct sata/slim sata so thats not the drive FW
MK1234Tfan
Post by MK1234Tfan » Mon Jan 20, 2025 2:04 pm
Billycar11 wrote: Mon Jan 20, 2025 9:02 am
Right, I agree and that's what I was saying previously. There very well may be a firmware chip inside the drive itself, but I was curious to see what firmware might have been on that PCB chip.
Post by Coopervid » Mon Jan 20, 2025 3:07 pm
Most likely for the USB->SATA controller. I once had to update the firmware of such a JMicron controller because it always lost connection.
Yethidran
Post by Yethidran » Mon Jan 20, 2025 4:01 pm
yup, that should definitely be correct
kaister
Post by kaister » Fri Feb 07, 2025 12:43 am
Is it possible to remove the drive without dismantling the entire thing?
I wanted to test the drive out in a laptop with removable dvd drive. However, I would like to be able to put it back together.
Yethidran
Post by Yethidran » Fri Feb 07, 2025 1:53 am
i had no success with any easy option other than destroying the verbatim casing. i bought a cheap plastic external casing for it after i destroyed the aluminium verbatim casing. there are 2 very tiny holes at the sides of the casing on both sides which i tried to push in to slide front or back and up and down, but nothing worked.
kaister
Post by kaister » Tue Feb 11, 2025 7:20 am
Yethidran wrote: Fri Feb 07, 2025 1:53 am i had no success with any easy option other than destroying the verbatim casing. i bought a cheap plastic external casing for it after i destroyed the aluminium verbatim casing. there are 2 very tiny holes at the sides of the casing on both sides which i tried to push in to slide front or back and up and down, but nothing worked.
Yea that sucks. Verbatim doesn't have the nicest case. Are they any good quality external slimline enclosure? I can't see to find any beside cheap no brand ones.
Yethidran
Post by Yethidran » Tue Feb 11, 2025 8:09 am
i ordered from "AliExpress" the link is attached below. i ordered the 3rd option with usb a + usb c cabling.
https://www.aliexpress.com/item/1005007 ... 1802xAOQ2n
Yethidran
Post by Yethidran » Tue Feb 11, 2025 8:14 am
To me this casing is much more easier to handle and dismantle if u wish too. and you do not even have to dismantle it actually. just slide in the "Raw Drive and make sure you give a hard push into the casing so that it connects properly with the mini sata connector at the back of the enclosure.
