using MakeMKV to intergrate with VLC to play blurays....
mopato4931
Post by mopato4931 »
using MakeMKV to integrate with VLC to play blurays still not working and getting an error message even when I select it through the integration menu
Re: using MakeMKV to intergrate with VLC to play blurays....
I don't really use MakeMKV's integration with VLC to play discs, but it seems to work for others. What error message do you get?
mopato4931
I get the erorr:
Your input can't be opened:
VLC is unable to open the MRL 'dvd:///E:/'. Check the log for details.
Any help would be appreicated. Doesnt work on Blu Rays or 4K Blu rays. I also have MakeMKV integrated with VLC just incase anyone needs to know that, still nothing.
