Merc1985 wrote: Wed Apr 03, 2024 5:09 pm Hi,
I've had this drive for some time and just decided to try MKV. Is it possible to read/rip with this drive or do I need to purchase another?
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: ...
Firmware date: 2017-04-18
Highest AACS version: 68
Firmware version: ID22
ASUS SBW-06D2X-U
r00kiemistake
Re: ASUS SBW-06D2X-U
Hello! I have the exact same drive. I am still very new to this and I am trying to figure out my next steps without a whole lot of luck.
PM sent.dagobert-0815 wrote: Mon Dec 30, 2024 9:56 pmThat's not a problem. I have a dual boot system.Coopervid wrote: Mon Dec 30, 2024 7:29 pmYou need to have access to a Windows PC.dagobert-0815 wrote: Sun Dec 29, 2024 3:44 pm Hello everyone,
I also have an SBW-06D2X-U from Asus. Can someone please help me to make the device UHDfriendly? I am fit on the command line, but I have no idea how to flash a Blu-Ray drive without bricking it.
I'm using a Linux OS and here is the drive information:
OS device name: /dev/sr0
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
Bus encryption markings: 1B
Highest AACS version: 75
Many thanks in advance and best regards
dagobert-0815
Hello Coopervod,Coopervid wrote: Tue Dec 31, 2024 11:27 amPM sent.
it worked great. Thank you very much for your help.
Best regards
mkvuser123
Hi Coopervid,
Hoping you can help with my drive also?
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
Thanks in advance!
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
Thanks in advance!
musece
Would you be able to help me with my drive as well please?
Please see the details below
OS device name: H:
Current profile: DVD-ROM
Manufacturer: ASUS
Revision: A102
Serial number: .1.2.3.45.6.7
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
Highest AACS version: 58
Kind Regards
OS device name: H:
Manufacturer: ASUS
Revision: A102
Kind Regards
PM sent.mkvuser123 wrote: Fri Jan 03, 2025 1:24 pm Hi Coopervid,
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
Thanks in advance!
You have a LG drive not a Pioneer. You should flash to BU40N 1.03 MK.musece wrote: Sun Jan 12, 2025 10:26 pm Hi,
OS device name: H:
Manufacturer: ASUS
Revision: A102
Kind Regards
See here:
viewtopic.php?f=16&t=19634
mkvuser123
Many thanks! Seems to have applied perfectlyCoopervid wrote: Mon Jan 13, 2025 10:37 amPM sent.mkvuser123 wrote: Fri Jan 03, 2025 1:24 pm Hi Coopervid,
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
Thanks in advance!
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: ...
Firmware date: 2020-06-15
Highest AACS version: 61
Drive platform: RS8A10
Firmware version: 1.14
musece
Thank you very much, that worked!Coopervid wrote: Mon Jan 13, 2025 10:40 amYou have a LG drive not a Pioneer. You should flash to BU40N 1.03 MK.musece wrote: Sun Jan 12, 2025 10:26 pm Hi,
OS device name: H:
Manufacturer: ASUS
Revision: A102
Kind Regards
See here:
ghostly
Hi, i have this drive, can i get the update? Thanks
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
Highest AACS version: 63
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
PM is comingghostly wrote: Sun Jan 19, 2025 5:53 pm Hi, i have this drive, can i get the update? Thanks
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
ghostly
Thank you a lot, it worked.Coopervid wrote: Sun Jan 19, 2025 6:24 pmPM is comingghostly wrote: Sun Jan 19, 2025 5:53 pm Hi, i have this drive, can i get the update? Thanks
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
One question, with this drive i'm still stuck at having 2x speed, i already followed the guide at: "viewtopic.php?t=22689" and set it to 0=99 but no luck, what can i do? thanks
Completely unplug the drive form USB. Reboot. Plug back in. You might also check "device capabilities" in BDRFlash and set the fastest mode. Not sure if it has any effects with your drive.ghostly wrote: Sun Jan 19, 2025 6:39 pmThank you a lot, it worked.Coopervid wrote: Sun Jan 19, 2025 6:24 pmPM is comingghostly wrote: Sun Jan 19, 2025 5:53 pm Hi, i have this drive, can i get the update? Thanks
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
Ravsky
Hi, Is this drive has update?
OS device name: H:
Manufacturer: ASUS
Revision: 1.11
Serial number: ...
Firmware date: 2023-04-20
OS device name: H:
Manufacturer: ASUS
Revision: 1.11
Serial number: ...
You have a PM.Ravsky wrote: Mon Jan 20, 2025 9:50 am Hi, Is this drive has update?
OS device name: H:
Manufacturer: ASUS
Revision: 1.11
Serial number: ...
