Ok, so I posted earlier that i can get everything to download and open up in my mac but, I cannot get the sdf tool to open or do anything.
are there any applications to help with this for a Mac mini, or is there a manual way to do this without the sdf tool. I rather do it the easy way and get the tool to open, but at this point i will take suggestions.
mac mini can't open sdftool
newriderca11
Re: mac mini can't open sdftool
The easy way flash using same tool under a computer or laptop using Windows. Don't you have a windows system?
SDFtool is a Windows only tool. If you have ready access to a Windows computer, it is perfectly fine to flash a drive on Windows and use it on a Mac.
The Ultimate UHD Drives Flashing Guide has a section: How To Flash Videos and commands:
In there are examples of the command line commands you can use in Terminal to flash your drive on your Mac.
