Re: SDFtool Flasher
#1201 Post by Coopervid » Fri Jan 17, 2025 10:28 pm
corefunctions wrote: Fri Jan 17, 2025 6:24 pm
MartyMcNuts wrote: Wed Jan 15, 2025 11:05 pm
corefunctions wrote: Wed Jan 15, 2025 8:07 am I am trying to flash my LG BP60NB10 and when I have my SDFtool open and ready to choose drive and firmware, then drop down menu of drive will not display my drive. Anyone got any tips for this?
Please and thank you.
Do you have MakeMKV installed and in the default location?
I have MakeMKV set up on my Mac but it's not able to open SDFTool so I used my friends PC to try and upload the software, but he doesn't have MakeMKV downloaded. This is what I see and my Player is connected and being read by the laptop.
SDFFlasher is just a GUI and needs Makemkv to be installed.
Dunebuggydrew
Re: SDFtool Flasher
#1202 Post by Dunebuggydrew » Sun Jan 19, 2025 3:03 pm
Let me send you some money, brother. You saved me from a big headache. Great tool
Re: SDFtool Flasher
#1203 Post by MartyMcNuts » Sun Jan 19, 2025 10:20 pm
Dunebuggydrew wrote: Sun Jan 19, 2025 3:03 pm Let me send you some money, brother. You saved me from a big headache. Great tool
Sure thing. My Paypal is MartyMcNuts@outlook.com
wbread99
Re: SDFtool Flasher
#1204 Post by wbread99 » Tue Jan 28, 2025 4:11 pm
Hello. I'm a bit of a noob when it comes to this stuff, but I have a HTPC (a nuk) hooked to a 4K TV, and I liked the idea of having a reflashed Blu Ray DVD drive hooked up to it to play UHD DVDs vs buy "yet another" DVD player. I found and followed this site for instructions on how to reflash an ASUS BR drive to play UHD content, but am having an issue that I have not seen replicated here -- apologies if it has, and I missed it.
I have a brand new ASUS BW-16D1HT drive that started its short life in a Vantec NST-536S3-BK enclosure. Once I realized that enclosure might not work for flashing (it may not have), I purchased Vantec DX3 NST-540S3-BK enclosure and put the drive in that.
I used the latest SDF tool 1.3.5
I used the "all you need" firmware pack, used the software for ASUS 3.10
Using both an ancient Win10 laptop and my NUC computer, I ran the flash tool as an administrator on drive in the unsupported enclosure:
- Got an error "command produced error code 0x86062900
- Repeated, got no errors
Drive (or computer specifically) will recognize UHD disk titles just as video shows. Both VLC player and MakeMPV says "missing keys, cannot continue" with UHD disks
Installed drive into the new (supported) enclosure, repeated steps, got the same error. This thread says "dont sweat the error code, it happens". Did this twice. Drive plays normal DVDs just fine.
What am I missing? Did I brick the thing? Apologies in advance!
Re: SDFtool Flasher
#1205 Post by MartyMcNuts » Wed Jan 29, 2025 5:54 am
wbread99 wrote: Tue Jan 28, 2025 4:11 pm Hello. I'm a bit of a noob when it comes to this stuff, but I have a HTPC (a nuk) hooked to a 4K TV, and I liked the idea of having a reflashed Blu Ray DVD drive hooked up to it to play UHD DVDs vs buy "yet another" DVD player. I found and followed this site for instructions on how to reflash an ASUS BR drive to play UHD content, but am having an issue that I have not seen replicated here -- apologies if it has, and I missed it.
Show us your MakeMKV drive info / Libredrive info sections.
wbread99
Re: SDFtool Flasher
#1206 Post by wbread99 » Sun Feb 02, 2025 11:00 pm
MartyMcNuts wrote: Wed Jan 29, 2025 5:54 am
Sorry I was at work...
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: ...
Bus encryption flags: 1F
Highest AACS version: 72
Firmware version: 3.10
Disc Information
Data capacity: 62.8 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Re: SDFtool Flasher
#1207 Post by MartyMcNuts » Mon Feb 03, 2025 1:57 am
wbread99 wrote: Sun Feb 02, 2025 11:00 pm
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: ...
Disc Information
Number of layers: 2
Your drive looks fine.
MakeMKV needs internet access to download the hashed key database for UHD discs. When you try to rip a UHD disc, does the log window say anything about "HK download failed"??
Have you integrated VLC and other players into MakeMKV via preferences?
TechNikephoros
Re: SDFtool Flasher
#1208 Post by TechNikephoros » Mon Feb 10, 2025 5:35 pm
I'm running into an issue trying to update the 4K drive I just bought. I've heard from others on here that they were able to update it, but I'm getting the following error:
Has anyone seen this and know of a solution?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.FormatException: Input string was not in a correct format.
   at System.Number.ThrowOverflowOrFormatException(ParsingStatus status, TypeCode type)
   at System.Int32.Parse(String s)
   at SDFtool_Flasher_Updated.Form1.comboBox_DriveList_SelectedIndexChanged(Object sender, EventArgs e)
   at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
   at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m)
   at System.Windows.Forms.ComboBox.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
System.Private.CoreLib
    Assembly Version: 6.0.0.0
    Win32 Version: n/a
    CodeBase:
    Assembly Version: 1.3.5.0
    Win32 Version: n/a
    CodeBase:
System.Runtime
    Win32 Version: n/a
    CodeBase:
    Assembly Version: 6.0.2.0
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing.Primitives
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing.Common
    Win32 Version: n/a
    CodeBase:
System.Threading
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections
    Win32 Version: n/a
    CodeBase:
System.Diagnostics.Process
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.Primitives
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Threading.Thread
    Win32 Version: n/a
    CodeBase:
Accessibility
    Assembly Version: 4.0.0.0
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Numerics.Vectors
    Win32 Version: n/a
    CodeBase:
System.Memory
    Win32 Version: n/a
    CodeBase:
System.ComponentModel
    Win32 Version: n/a
    CodeBase:
System.Resources.Extensions
    Win32 Version: n/a
    CodeBase:
System.Drawing
    Win32 Version: n/a
    CodeBase:
System.ObjectModel
    Win32 Version: n/a
    CodeBase:
System.Linq
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections.Concurrent
    Win32 Version: n/a
    CodeBase:
mscorlib
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.SystemEvents
    Win32 Version: n/a
    CodeBase:
System.Collections.NonGeneric
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Uri
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Xml.ReaderWriter
    Win32 Version: n/a
    CodeBase:
System.Private.Xml
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Net.WebClient
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Xml.XmlSerializer
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.Registry
    Win32 Version: n/a
    CodeBase:
System.Runtime.CompilerServices.Unsafe
    Win32 Version: n/a
    CodeBase:
System.Runtime.Loader
    Win32 Version: n/a
    CodeBase:
System.Diagnostics.StackTrace
    Win32 Version: n/a
    CodeBase:
System.Reflection.Metadata
    Win32 Version: n/a
    CodeBase:
System.Collections.Immutable
    Win32 Version: n/a
    CodeBase:
************** JIT Debugging **************
This is my drive info:
OS device name: E:
Manufacturer: hp HLDS
Product: BDRE BU40N
Revision: BW43
Serial number: 7MEQVHAKKH81KD
Firmware date: 2120-11-02 14:15
Highest AACS version: 81
Re: SDFtool Flasher
#1209 Post by MartyMcNuts » Mon Feb 10, 2025 8:33 pm
TechNikephoros wrote: Mon Feb 10, 2025 5:35 pm I'm running into an issue trying to update the 4K drive I just bought. I've heard from others on here that they were able to update it, but I'm getting the following error: SDFlasher_Error.png.
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Runtime
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Threading
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
Accessibility
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Memory
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing
    Win32 Version: n/a
    CodeBase:
System.ObjectModel
    Win32 Version: n/a
    CodeBase:
System.Linq
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
mscorlib
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Uri
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Xml
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
OS device name: E:
Product: BDRE BU40N
Revision: BW43
The string is incorrect because it has hp in it. This is the first time I have ever seen a HLDS drive have hp in front of it. I will see if I can update SDFtool flasher. Give me a few hours.
If you are in a hurry, you can use the MakeMKV command line to get it done. It's not hard.
TechNikephoros
Re: SDFtool Flasher
#1210 Post by TechNikephoros » Mon Feb 10, 2025 9:10 pm
MartyMcNuts wrote: Mon Feb 10, 2025 8:33 pm
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Runtime
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Threading
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
Accessibility
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Memory
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing
    Win32 Version: n/a
    CodeBase:
System.ObjectModel
    Win32 Version: n/a
    CodeBase:
System.Linq
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
mscorlib
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Uri
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Xml
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
OS device name: E:
Product: BDRE BU40N
Revision: BW43
I will wait for the newer version of SDFTool, thank you!!
TechNikephoros
Re: SDFtool Flasher
#1211 Post by TechNikephoros » Tue Feb 11, 2025 4:47 pm
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Runtime
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Threading
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
Accessibility
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Memory
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing
    Win32 Version: n/a
    CodeBase:
System.ObjectModel
    Win32 Version: n/a
    CodeBase:
System.Linq
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
mscorlib
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Uri
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Xml
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
OS device name: E:
Product: BDRE BU40N
Revision: BW43
I'm attempting to find some documentation on using the MakeMKVcon command line in windows to rename the device. Has anyone done this before? I see the command for listing the drives, but not updating the drive names.
Re: SDFtool Flasher
#1212 Post by MartyMcNuts » Tue Feb 11, 2025 10:08 pm
TechNikephoros wrote: Tue Feb 11, 2025 4:47 pm
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Runtime
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Threading
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
Accessibility
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Memory
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing
    Win32 Version: n/a
    CodeBase:
System.ObjectModel
    Win32 Version: n/a
    CodeBase:
System.Linq
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
mscorlib
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Uri
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Xml
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
Not possible.
Did you try the updated SDFtool flasher I sent you?? It should work.
TechNikephoros
Re: SDFtool Flasher
#1213 Post by TechNikephoros » Wed Feb 12, 2025 5:02 pm
The latest version works great, thank you!!
Re: SDFtool Flasher
#1214 Post by MartyMcNuts » Thu Feb 13, 2025 12:01 am
TechNikephoros wrote: Wed Feb 12, 2025 5:02 pm The latest version works great, thank you!!
Thanks for letting me know. Just to see after the flash, can you now show your MakeMKV drive/libredrive info sections?
xxpickles
Re: SDFtool Flasher
#1215 Post by xxpickles » Fri Feb 14, 2025 5:03 am
I have an LG Slim WP50NB40-NB50 that I decided to take the plunge and flash. I read several discussions with people with this same drive and went through the steps. I was able to use SDFlasher v1.3.5, and it said that it was successful. MakeMKV drive information also looks correct based on what I have seen others post:
OS device name: H:
Product: BD-RE BP50NB40
Revision: 1.00
Serial number: ********************
Firmware date: 2114-09-03 17:32
Firmware version: 1.00
However, the drive no longer opens or reads the disc (when manually forcing the drawer open). Is there a step I missed somehow?
