Disc disappearing half way through rip
mumrah
Post by mumrah » Fri Jan 17, 2025 3:09 am
I've ripped 4 BD so far with no issues. On my first UHD rip, I'm getting an error around half way through the rip
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00505.m2ts+00507.m2ts+00500.m2ts+00504.m2ts+00503.m2ts+00506.m2ts+00509.m2ts' at offset '26524778496'
001003:0020 DEBUG: Code 1073741830 at PG%TK;0&yG6+i331:213130559
002003:0000 Error 'Posix error - Device not configured' occurred while reading '/dev/rdisk9' at offset '26524778496'
DEBUG: Code 1073741830 at q3An)$5vw:?Ba+v4.5:29394896
001003:0020 DEBUG: Code 1073741830 at q3An)$5vw:?Ba+v4.5:213131502
It's like the disc just disappears?
I am using a Pioneer drive in an external Other World Computing enclosure (with external power). The OS sees this drive as a 5GB/s device, so I think the USB3.1 is being properly converted to USB-C by my adapter.
Any ideas what's causing this? I've ordered a dedicated USB 3.1 type B to USB-C cable to rule out adapter issues.
Edit: I noticed it happens at a different offset each time. On another attempt I got
Error 'Posix error - Device not configured' occurred while reading '/dev/rdisk5' at offset '26525958144'
which suggests that it is not specific to this disk, but rather a timing or power issue.
Re: Disc disappearing half way through rip
Post by Woodstock » Fri Jan 17, 2025 4:45 am
An issue can happen when the drive takes too long to decode data, and the OS decides to declare it "dead". This can happen when the drive reaches a speed that exceeds it's available power, common with USB devices. Your getting a higher-capability cable will likely help.
flojo
Post by flojo » Fri Jan 17, 2025 1:20 pm
You need only USB 2.0 speeds. Also type C defines the mating form, not the speed.
Try a USB cable with thicker wires/lower AWG. You also want a power supply that can deliver >= 2 amps. If you're stuck with type C, a "charging" cable might be your best bet since they seemingly have thicker wires and meet the USB 2.0 (4 conductor) spec.
Type C "data" cables typically use higher AWG since there has to be at least 9 conductors inside the sheath I believe. The higher the AWG, the thinner the wires, so this is bad for the purpose you're attempting or any other power related applications. They make special type C "PD" data cables specifically to overcome the higher AWG problem.
https://en.wikipedia.org/wiki/Blu-ray#Drive_speeds
https://en.wikipedia.org/wiki/USB#Conne ... _reference
mumrah
Post by mumrah » Fri Jan 17, 2025 1:47 pm
This is the cable I ordered https://www.amazon.com/gp/product/B00UXKTJE0
Right now I am using a short USB-C to USB-A adapter. It has worked fine for other BD discs, just not this large UHD one.
Are there any OS settings I can tweak to prevent the drive from being detected as dead?
According to System Information, the drive is not asking for any additional power from the OS.
Mercury Pro Optical:
  Product ID:	0xde2c
  Vendor ID:	0x1e91
  Version:	1.00
  Serial Number:	230924880EC5
  Speed:	Up to 5 Gb/s
  Manufacturer:	Other World Computing
  Location ID:	0x00200000 / 1
  Current Available (mA):	900
  Current Required (mA):	0
  Extra Operating Current (mA):	0
The power supply that came with the external enclosure is 12V 3A
flojo
Post by flojo » Fri Jan 17, 2025 3:52 pm
I don't have that enclosure or use MacOS for anything block device related, but I will say that it seems like you have good enough hardware, so it might be a software problem. Can your drive read UHD discs? I don't know how to interpret "Device not configured".
mumrah
Post by mumrah » Fri Jan 17, 2025 5:09 pm
I'm not sure how to tell. MakeMKV can load the track list.
MakeMKV v1.17.8 darwin(arm64-release) started
Debug logging enabled, log will be saved as /Users/davidarthur/MakeMKV_log.txt
Optical drive "BD-RE PIONEER BD-RW BDR-S13U 1.03 DIDL302009UCd" opened in OS access mode.
Using LibreDrive mode (v01.0 id=DFE22909F92F)
Using Java runtime from /Library/Java/JavaVirtualMachines/jdk-21.jdk/Contents/Home/bin/java
Title #00001.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.mpls has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.mpls has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.mpls has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00706.mpls was added as title #0
File 00823.mpls was added as title #1
File 00824.mpls was added as title #2
File 00016.mpls was added as title #3
File 00027.mpls was added as title #4
File 00030.mpls was added as title #5
File 00032.mpls was added as title #6
File 00038.mpls was added as title #7
File 00041.mpls was added as title #8
File 00043.mpls was added as title #9
File 00047.mpls was added as title #10
File 00048.mpls was added as title #11
File 00061.mpls was added as title #12
File 00062.mpls was added as title #13
File 00067.mpls was added as title #14
File 00071.mpls was added as title #15
File 00072.mpls was added as title #16
File 00073.mpls was added as title #17
File 00074.mpls was added as title #18
File 00078.mpls was added as title #19
File 00081.mpls was added as title #20
File 00084.mpls was added as title #21
File 00085.mpls was added as title #22
File 00086.mpls was added as title #23
File 00090.mpls was added as title #24
File 00091.mpls was added as title #25
File 00095.mpls was added as title #26
File 00099.mpls was added as title #27
File 00100.mpls was added as title #28
File 00103.mpls was added as title #29
File 00106.mpls was added as title #30
File 00109.mpls was added as title #31
File 00113.mpls was added as title #32
File 00131.mpls was added as title #33
File 00136.mpls was added as title #34
File 00143.mpls was added as title #35
File 00144.mpls was added as title #36
File 00146.mpls was added as title #37
File 00151.mpls was added as title #38
File 00152.mpls was added as title #39
File 00154.mpls was added as title #40
File 00155.mpls was added as title #41
File 00162.mpls was added as title #42
Title 00167.mpls is equal to title 00067.mpls and was skipped
File 00175.mpls was added as title #43
File 00178.mpls was added as title #44
File 00186.mpls was added as title #45
Title 00187.mpls is equal to title 00113.mpls and was skipped
File 00195.mpls was added as title #46
File 00199.mpls was added as title #47
File 00210.mpls was added as title #48
File 00230.mpls was added as title #49
File 00232.mpls was added as title #50
Title 00233.mpls is equal to title 00151.mpls and was skipped
File 00239.mpls was added as title #51
File 00252.mpls was added as title #52
File 00255.mpls was added as title #53
Title 00256.mpls is equal to title 00091.mpls and was skipped
File 00257.mpls was added as title #54
File 00260.mpls was added as title #55
File 00266.mpls was added as title #56
File 00267.mpls was added as title #57
File 00273.mpls was added as title #58
File 00287.mpls was added as title #59
File 00292.mpls was added as title #60
File 00297.mpls was added as title #61
File 00299.mpls was added as title #62
File 00300.mpls was added as title #63
File 00302.mpls was added as title #64
File 00307.mpls was added as title #65
File 00308.mpls was added as title #66
File 00310.mpls was added as title #67
File 00319.mpls was added as title #68
File 00321.mpls was added as title #69
File 00325.mpls was added as title #70
File 00329.mpls was added as title #71
File 00334.mpls was added as title #72
File 00338.mpls was added as title #73
Title 00341.mpls is equal to title 00074.mpls and was skipped
File 00342.mpls was added as title #74
File 00343.mpls was added as title #75
File 00346.mpls was added as title #76
Title 00351.mpls is equal to title 00030.mpls and was skipped
File 00352.mpls was added as title #77
File 00364.mpls was added as title #78
File 00365.mpls was added as title #79
File 00371.mpls was added as title #80
File 00380.mpls was added as title #81
File 00390.mpls was added as title #82
File 00395.mpls was added as title #83
File 00396.mpls was added as title #84
File 00397.mpls was added as title #85
File 00398.mpls was added as title #86
File 00404.mpls was added as title #87
File 00410.mpls was added as title #88
Title 00413.mpls is equal to title 00257.mpls and was skipped
File 00415.mpls was added as title #89
File 00427.mpls was added as title #90
File 00431.mpls was added as title #91
File 00432.mpls was added as title #92
File 00435.mpls was added as title #93
File 00437.mpls was added as title #94
File 00439.mpls was added as title #95
File 00444.mpls was added as title #96
Title 00446.mpls is equal to title 00032.mpls and was skipped
File 00454.mpls was added as title #97
Title 00456.mpls is equal to title 00043.mpls and was skipped
File 00459.mpls was added as title #98
File 00462.mpls was added as title #99
Title 00469.mpls is equal to title 00103.mpls and was skipped
File 00476.mpls was added as title #100
File 00479.mpls was added as title #101
File 00483.mpls was added as title #102
File 00485.mpls was added as title #103
File 00490.mpls was added as title #104
File 00507.mpls was added as title #105
File 00508.mpls was added as title #106
File 00512.mpls was added as title #107
File 00513.mpls was added as title #108
Title 00514.mpls is equal to title 00162.mpls and was skipped
Title 00523.mpls is equal to title 00410.mpls and was skipped
File 00526.mpls was added as title #109
File 00529.mpls was added as title #110
File 00531.mpls was added as title #111
File 00544.mpls was added as title #112
File 00580.mpls was added as title #113
File 00587.mpls was added as title #114
File 00596.mpls was added as title #115
File 00598.mpls was added as title #116
File 00600.mpls was added as title #117
File 00601.mpls was added as title #118
File 00602.mpls was added as title #119
File 00604.mpls was added as title #120
File 00605.mpls was added as title #121
File 00606.mpls was added as title #122
File 00607.mpls was added as title #123
File 00613.mpls was added as title #124
File 00615.mpls was added as title #125
File 00629.mpls was added as title #126
File 00631.mpls was added as title #127
File 00645.mpls was added as title #128
File 00671.mpls was added as title #129
File 00672.mpls was added as title #130
File 00675.mpls was added as title #131
File 00676.mpls was added as title #132
Title 00696.mpls is equal to title 00508.mpls and was skipped
File 00698.mpls was added as title #133
Title 00699.mpls is equal to title 00544.mpls and was skipped
File 00703.mpls was added as title #134
Title 00704.mpls is equal to title 00325.mpls and was skipped
File 00709.mpls was added as title #135
File 00715.mpls was added as title #136
File 00722.mpls was added as title #137
File 00724.mpls was added as title #138
File 00725.mpls was added as title #139
File 00730.mpls was added as title #140
File 00732.mpls was added as title #141
File 00743.mpls was added as title #142
File 00751.mpls was added as title #143
File 00755.mpls was added as title #144
File 00757.mpls was added as title #145
Title 00765.mpls is equal to title 00676.mpls and was skipped
Title 00767.mpls is equal to title 00629.mpls and was skipped
File 00775.mpls was added as title #146
Title 00778.mpls is equal to title 00703.mpls and was skipped
Title 00791.mpls is equal to title 00338.mpls and was skipped
File 00792.mpls was added as title #147
File 00795.mpls was added as title #148
File 00799.mpls was added as title #149
File 00800.mpls was added as title #150
Title 00801.mpls is equal to title 00103.mpls and was skipped
File 00827.mpls was added as title #151
Title 00829.mpls is equal to title 00091.mpls and was skipped
File 00830.mpls was added as title #152
File 00833.mpls was added as title #153
Title 00839.mpls is equal to title 00041.mpls and was skipped
File 00857.mpls was added as title #154
File 00861.mpls was added as title #155
File 00862.mpls was added as title #156
File 00865.mpls was added as title #157
File 00874.mpls was added as title #158
File 00885.mpls was added as title #159
Title 00886.mpls is equal to title 00410.mpls and was skipped
File 00895.mpls was added as title #160
File 00896.mpls was added as title #161
File 00903.mpls was added as title #162
File 00906.mpls was added as title #163
File 00909.mpls was added as title #164
File 00910.mpls was added as title #165
File 00915.mpls was added as title #166
File 00925.mpls was added as title #167
File 00927.mpls was added as title #168
File 00933.mpls was added as title #169
Title 00935.mpls is equal to title 00146.mpls and was skipped
File 00939.mpls was added as title #170
Title 00943.mpls is equal to title 00895.mpls and was skipped
File 00947.mpls was added as title #171
Title 00950.mpls is equal to title 00027.mpls and was skipped
File 00953.mpls was added as title #172
File 00955.mpls was added as title #173
File 00966.mpls was added as title #174
File 00968.mpls was added as title #175
File 00975.mpls was added as title #176
File 00976.mpls was added as title #177
File 00978.mpls was added as title #178
File 00979.mpls was added as title #179
File 00983.mpls was added as title #180
File 00987.mpls was added as title #181
File 00992.mpls was added as title #182
File 00999.mpls was added as title #183
Title #00002.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00276.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00277.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00279.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00280.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00500.m2ts was added as title #184
Title #00501.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00502.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00503.m2ts was added as title #185
Title #00504.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00505.m2ts was added as title #186
Title #00506.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00507.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00508.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00509.m2ts was added as title #187
Title #01984.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
I do notice that the track listing is a bit weird.
Screenshot 2025-01-17 at 12.06.52 PM.jpg (858.46 KiB) Viewed 10597 times
How can I check if the drive supports UHD? It's a Pioneer BDR-S13U
mumrah
Post by mumrah » Sun Jan 19, 2025 11:17 pm
No luck after using a new cord. I guess this is an OS issue :-/
Has anyone had luck with this drive and ripping UHD on Mac OS?
Post by dcoke22 » Wed Jan 22, 2025 7:15 am
mumrah wrote: Sun Jan 19, 2025 11:17 pm No luck after using a new cord. I guess this is an OS issue :-/
I rip on macOS all the time. My Pioneer drives are in Vantec cases instead of the OWC cases, although I have two non-Pioneer drives in OWC cases. Either case should be fine.
Are you sure you want to rip dozens of copies of the movie?
Does it work if you make a decrypted backup of the disc? (click the icon of the yellow folder with the green arrow on the first screen of MakeMKV) Once a backup is made, you can open that backup with MakeMKV and create .mkv files without having to read from the optical disc again.
mumrah
Post by mumrah » Mon Jan 27, 2025 10:13 pm
Turns out this was a damaged disc. I have since tried other UHD discs and was able to rip with no problems.
