List of DVD/BluRay that haven't worked
Re: List of DVD/BluRay that haven't worked
Bridal Wars is BD+
So for now it's unreadable.
Star Wars - A New Hope
Saving 1 titles into directory E://STAR_WARS_EPISODE_IV
LIBMKV_TRACE: Exception: MKV_ASSERT: frame->timecode>=cluster_timecode
Failed to save title 0 to file E://STAR_WARS_EPISODE_IV/title00.mkv
0 titles saved, 1 failed
I've a fair number of DVDs that have simliar errors.
This plays fine on the PC and if I rip it using DVDShrink/mergeMKV it works fine (though I can't get subtitles to rip correctly)
Dom
Dom
X-Men Origins: Wolverine
MakeMKV v1.4.7 beta win(x86-release) started
The blu-ray disc can't be opened by this BETA version. It contains the following unsupported feature: BD+
I don't have AnyDVD HD installed right now, debating on if I should buy it or not, but I don't have problems with BD+ usually when I run that.
Walk Hard The Dewey Cox Story - Blu-Ray
MakeMKV v1.4.7(beta)
Error Log -
Failed to save title 0 to file D:/Video/Walk_Hard_The_Dewey_Cox_Story/title00.mkv
Failed to save title 2 to file D:/Video/Walk_Hard_The_Dewey_Cox_Story/title02.mkv
Read error. File="<n/a>" Info=""
Failed to save title 4 to file D:/Video/Walk_Hard_The_Dewey_Cox_Story/title04.mkv
Failed to save title 5 to file D:/Video/Walk_Hard_The_Dewey_Cox_Story/title05.mkv
Failed to save title 11 to file D:/Video/Walk_Hard_The_Dewey_Cox_Story/title11.mkv
11 titles saved, 5 failed
Error Log -
*sigh* yet another failure, this is starting to get a bit old... I Love You Man, US Blu-ray
Debug log started at Tue Oct 6 23:14:28 2009 , written by MakeMKV v1.4.7 beta darwin(x86-release)
001014:000000:0000 MakeMKV v1.4.7 beta darwin(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as /Users/kevinbal/MakeMKV_log.txt
001012:000000:0020 FAILURE: Code 0 at @k"Y|1RBZ<R(D4*"t!~hJi "Y(L:121264878
003010:000000:0000 Using direct disc access mode
DISCID=2ACA52191701F23951679AC7513E7A0C57FA1F46
003316:000000:0000 Only extracting AC3 core audio from stream #1 of type 'DD True HD audio' in file 00001.m2ts
003313:000000:0000 File 00001.mpls was added as title #0
003020:000000:0000 Title #00002.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00003.mpls has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #01068.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #01066.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 01000.mpls was added as title #1
003313:000000:0000 File 01001.mpls was added as title #2
001011:000000:0020 LIBMKV_TRACE: No CC5 in 01072
001011:000000:0020 LIBMKV_TRACE: No CC5 in 01081
001011:000000:0020 LIBMKV_TRACE: No CC5 in 01087
003020:000000:0000 Title #00000.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00105.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00106.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00003.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00006.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00010.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00011.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00012.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00013.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00014.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00015.m2ts was added as title #3
003020:000000:0000 Title #00016.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00017.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00018.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00019.m2ts was added as title #4
003020:000000:0000 Title #00044.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00045.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00046.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00047.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00048.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00049.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00050.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00051.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00052.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00053.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00054.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00055.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00056.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00057.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00058.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00059.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00060.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00061.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00062.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00063.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00064.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00065.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00066.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00067.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00068.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00070.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00071.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00072.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00073.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00074.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00079.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00080.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00081.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00082.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00083.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00084.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00085.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00086.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00087.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00088.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00089.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00090.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00091.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00092.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00093.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00094.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00095.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00096.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00097.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00098.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00099.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00100.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00101.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00102.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00103.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00104.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00115.m2ts has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00116.m2ts was added as title #5
003313:000000:0000 File 00117.m2ts was added as title #6
003313:000000:0000 File 00118.m2ts was added as title #7
003313:000000:0000 File 00119.m2ts was added as title #8
003020:000000:0000 Title #00120.m2ts has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00121.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00122.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00123.m2ts has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00124.m2ts was added as title #9
003020:000000:0000 Title #00125.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00126.m2ts was added as title #10
003313:000000:0000 File 00127.m2ts was added as title #11
003020:000000:0000 Title #00128.m2ts has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00129.m2ts has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00130.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00131.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00132.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00133.m2ts was added as title #12
005011:000000:0000 Operation sucessfully completed
005014:000000:0000 Saving 1 titles into directory /Users/kevinbal/Desktop
001012:000000:0020 FAILURE: Code 2 at Y9C_i,'00:Q9N.:_:213135251
SD=ZeNorYGBmqL69gI8BCESZGODgVr77pCmxDAyMUL5Mgfskg0QGhv9AEPLYHCzmAaQBhC0OZQ==
001012:000000:0020 FAILURE: Code 4294967276 at 9I?E?1w8x3Y1*] ,:121267270
SD=ZeNorYGBhqP6uwMcABC5yDHBwK9990pRYBgZGKF+mwH2SQSIDw38gCHlsDhbzANIAfP8OTQ==
SD=ZeNorYGBmqP75gI8BCESZGODgVr77pCmxDAyMUL5Mgfskg0QGhv9AEPLYHCzmAaQBmZcOww==
SD=ZeNorYGBhqP75gI8BCFzkGODgVr77pCmxDAyMUL5Mgfskg0QGhv9AEPLYHCzmAaQBqPUPDw==
SD=ZeNr7wMDMUOfxgI8BCARZGeDgVr77pCmxDAyMUL5Mgfskg0QGhv9AEPLYHCzmAaQBkUkOlA==
SD=ZeNr7wMDMUOezgI8BCARZGeDgVr77pCmxDAyMUL5Mgfskg0QGhv9AEPLYHCzmAaQBg7UOWA==
SD=ZeNr7wMDM0NbQwMcABIKsDHBwK9990pRYBgZGKF+mwH2SQSIDw38gCHlsDhbzANIAilEOdA==
SD=ZeNr7wMDM0Na2gI8BCARZGeDgVr77pCmxDAyMUL5Mgfskg0QGhv9AEPLYHCzmAaQBkvMOmg==
SD=ZeNorYGBmaGtbwMcABKJMDHBwK9990pRYBgZGKF+mwH2SQSIDw38gCHlsDhbzANIAcyoOGw==
SD=ZeNorYGBhaGtbwMcABC5yDHBwK9990pRYBgZGKF+mwH2SQSIDw38gCHlsDhbzANIAgogOZw==
001012:000000:0020 FAILURE: Code 0 at 9I?E?1w8x3Y1*] ,:213134837
001012:000000:0020 FAILURE: Code 4294967276 at `Q=v#ES:l"+)IS$k1,:29394068
SD=ZeNr7wMDM0Na9gI8BCARZGeDgVr77pCmxDAyMUL5Mgfskg0QGhv9AEPLYHCzmAaQBlBoOnw==
SD=ZeNorYGBhaOtewMcABC5yDHBwK9990pRYBgZGKF+mwH2SQSIDw38gCHlsDhbzANIAg68ObA==
SD=ZeNorYGBmaOtewMcABKJMDHBwK9990pRYBgZGKF+mwH2SQSIDw38gCHlsDhbzANIAdFEOIA==
SD=ZeNr7wMDM0NZzgI8BCARZGeDgVr77pCmxDAyMUL5Mgfskg0QGhv9AEPLYHCzmAaQBm5UOwA==
SD=ZeNr7wMDM0DZhAR8DEAiyMsDBrXz3SVNiGRgYoXyZAvdJBokMDP+BIOSxOVjMA0gDAJVBDqQ=
SD=ZeNr7wMDM0DbxAB8DEAiyMsDBrXz3SVNiGRgYoXyZAvdJBokMDP+BIOSxOVjMA0gDAJy8DsU=
SD=ZeNr7wMDM0DbpAR8DEAiyMsDBrXz3SVNiGRgYoXyZAvdJBokMDP+BIOSxOVjMA0gDAKQ3DuY=
SD=ZeNr7wMDM0DbtAB8DEAiyMsDBrXz3SVNiGRgYoXyZAvdJBokMDP+BIOSxOVjMA0gDAJ3jDso=
SD=ZeNr7wMDM0Db9AR8DEAiyMsDBrXz3SVNiGRgYoXyZAvdJBokMDP+BIOSxOVjMA0gDAKVeDus=
SD=ZeNr7wMDM0DaTgY8BCARZGeDgVr77pCmxDAyMUL5Mgfskg0QGhv9AEPLYHCzmAaQBcxQODQ==
SD=ZeNr7wMDM0DZLgY8BCARZGeDgVr77pCmxDAyMUL5Mgfskg0QGhv9AEPLYHCzmAaQBeo8OLg==
SD=ZeNr7wMDM0LbAgY8BCARZGeDgVr77pCmxDAyMUL5Mgfskg0QGhv9AEPLYHCzmAaQBgzEOVA==
SD=ZeNr7wMDM0HY2gY8BCARZGeDgVr77pCmxDAyMUL5Mgfskg0QGhv9AEPLYHCzmAaQBlNAOoQ==
SD=ZeNr7wMDM0Hb7AR8DEAiyMsDBrXz3SVNiGRgYoXyZAvdJBokMDP+BIOSxOVjMA0gDALUKDy8=
SD=ZeNr7wMDM0HZPgY8BCARZGeDgVr77pCmxDAyMUL5Mgfskg0QGhv9AEPLYHCzmAaQBijsOcg==
SD=ZeNr7wMDM0Pa6gY8BCARZGeDgVr77pCmxDAyMUL5Mgfskg0QGhv9AEPLYHCzmAaQBovoO3w==
SD=ZeNr7wMDM0PZmAR8DEAiyMsDBrXz3SVNiGRgYoXyZAvdJBokMDP+BIOSxOVjMA0gDAKp1DwA=
SD=ZeNr7wMDM0PZxAR8DEAiyMsDBrXz3SVNiGRgYoXyZAvdJBokMDP+BIOSxOVjMA0gDAKucDwU=
001012:000000:0020 FAILURE: Code 4294967276 at `Q=v#ES:l"+)IS$k1,:121262601
001012:000000:0020 FAILURE: Code 4294967276 at `Q=v#ES:l"+)IS$k1,:29394597
002007:000000:0000 Read error. File="<n/a>" Info=""
001012:000000:0020 FAILURE: Code 0 at ~ZXQ\[&~_O~+9{Nee*+~:121262509
001012:000000:0020 FAILURE: Code 0 at <3{lK9N""s< w^o)YOpA:121262049
001012:000000:0020 FAILURE: Code 0 at ~ZXQ\[&~_O~+9{Nee*+~:121262164
001012:000000:0020 FAILURE: Code 4026208 at ~ZXQ\[&~_O~+9{Nee*+~:213129639
- Contact:
Your disc is fine, your drive is not. The log contains following sense codes returned by your drive:kevinbal wrote:*sigh* yet another failure, this is starting to get a bit old... I Love You Man, US Blu-ray
15 02 POSITIONING ERROR DETECTED BY READ OF MEDIUM
11 05 L-EC UNCORRECTABLE ERROR
44 1E INTERNAL TARGET FAILURE
But this is a good point. makemkv should print these in debug log.
Not to split hairs, Mike, but I don't think it was my drive. I tried 3 times, all failures. I upgraded to 1.4.8 and it suddenly worked. My guess is that in 1.4.8, you also increased what level of MKB... maybe up to MKBv12 or 14 now?
Can't wait to test out the BD+ support.
The Dam Busters - Blu-ray
Video OK, Sound is just noise (LCPM 2/0)
Friday "New Line Platinum Series" DVD. It reads a few tracks none of which are the movie.
The US "Enemy Mine" DVD begins reading and then MakeMKV crashes and quits. Not sure what is causing the crash.
Andie wrote:Friday "New Line Platinum Series" DVD. It reads a few tracks none of which are the movie.
Memoirs Of A Geisha "2 Disc Widescreen Special Edition" DVD. The error I get is: CellWallk algorithm failed (structure protection is too though?) Trying CellTrim algorithm. Then a pop up window: Fatal error occurred , programm will now exit.
Galapagos Blu-Ray
Galapagos [Blu-Ray]
Rips fine but only plays back sound and no video. Happens in VLC as well as PLEX. First Disc that has ever done this.
DVD: James Bond, The World is Not Enough, Region 2
Problem: Gives audio discontinuities when converted to mkv. Errors seen during debug.
Thread About This: http://www.makemkv.com/forum2/viewtopic.php?f=1&t=618
These are the DVDs that have given me FATAL ERRORs and shutsdown MakeMKV:
Predator 2 (2 Disc Special Edition)
Star Wars - Episode 1: The Phantom Menace
Star Wars - Episode 2: Attack of the Clones
Star Wars - Episode 3: Revenge of the Sith
Star Wars - Episode 4: A New Hope
Star Wars - Episode 5: The Empire Strikes Back
Star Wars - Episode 6: Return of the Jedi
I'm backing up all my DVDs for my HTPC, I will post more as I go along.
Carbon Copy & A Cry In The Dark NTSC DVDs don't show the available audio track(s). There's only a "Video" section when you expand the Title for the main movie. The resulting MKV plays okay, and you can mux in the audio once you've extracted it via another means.
