Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
#481 Post by Coopervid » Wed Jan 08, 2025 10:50 am
gyazomember wrote: Mon Jan 06, 2025 2:34 pm Hello, is this firmware flashable as well? Kind regards
OS device name: E:
Current profile: DVD+R
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.10
Serial number: [redacted]
Firmware date: 2017-04-18
Drive platform: RS8511
Firmware version: 1.10
PM sent.
#482 Post by Coopervid » Wed Jan 08, 2025 10:52 am
urbanhym wrote: Wed Jan 08, 2025 12:52 am Same here:
Product: BD-RW BDR-UD03D
Revision: 1.00
Serial number: ...
Firmware date: 2014-05-14
Drive platform: RS8510
Firmware version: 1.00/ID84
PM sent.
#483 Post by Coopervid » Wed Jan 08, 2025 10:54 am
futuremon wrote: Wed Jan 08, 2025 1:04 am Hiya everyone,
It appears I'm also in the realm of the Pioneer BDR-UD03 drive not having the proper flashed update. What's the best way to flash the drive to enable reading of UHD 4K?
Many thanks! This forum has been super helpful!
Revision: 1.14
Firmware date: 2020-06-15
Highest AACS version: 66
Firmware version: 1.14
PM sent.
futuremon
#484 Post by futuremon » Thu Jan 09, 2025 4:37 am
Coopervid wrote: Thu Jan 02, 2025 4:36 pm All 4 guys above have PMs.
You rock Cooper! Thank you for your help!
#485 Post by Coopervid » Thu Jan 09, 2025 10:24 pm
A warning to those morons who don't read their PMs after being helped. PMs will be deleted after 2 weeks and no new is coming.
crowtrobot
#486 Post by crowtrobot » Wed Jan 15, 2025 6:38 am
Well, it looks like I'm in the same boat.
OS device name: /dev/sr0
Revision: 1.14
Serial number: ...
Highest AACS version: 76
Thanks in advance!
funmonkey100
#487 Post by funmonkey100 » Wed Jan 15, 2025 10:41 am
BD-RE PIONEER BD-RW BDR-UD03
1.10
SKDL1650****
Using LibreDrive mode (v01.0 id=A059FCFD72B3)
I also have this drive and can't seem to rip UHD discs.
Thank You.
MeeStaKlean
#488 Post by MeeStaKlean » Fri Jan 17, 2025 12:00 am
I have a new to me UD03 I would like to flash to UD04. Here is the optical spec
OS device name: E:
Revision: 1.00
Serial number: OBDL037500WL
Highest AACS version: 81
Thanks in advance🤘
Code-X
#489 Post by Code-X » Fri Jan 17, 2025 12:47 am
Could I get some help with UHD BD's based on the following information from my drive?
Revision: 1.14
Serial number: ...
Highest AACS version: 42
#490 Post by Coopervid » Fri Jan 17, 2025 11:13 am
crowtrobot wrote: Wed Jan 15, 2025 6:38 am Well, it looks like I'm in the same boat.
Revision: 1.14
Serial number: ...
Thanks in advance!
PM is coming.
#491 Post by Coopervid » Fri Jan 17, 2025 11:15 am
funmonkey100 wrote: Wed Jan 15, 2025 10:41 am BD-RE PIONEER BD-RW BDR-UD03
1.10
SKDL1650****
Thank You.
PM will be sent shortly.
crowtrobot
#492 Post by crowtrobot » Sat Jan 18, 2025 9:38 am
Coopervid wrote: Fri Jan 17, 2025 11:13 am PM is coming.
A huge thank you! It worked perfectly.
mcbreakfast
#493 Post by mcbreakfast » Sat Jan 18, 2025 2:42 pm
Coopervid wrote: Fri May 03, 2024 1:42 pm Check your PM.
Hi have the same Drive, but never Revision.
Revision: 1.14
Serial number: ...
Highest AACS version: 71
#494 Post by Coopervid » Sat Jan 18, 2025 4:53 pm
mcbreakfast wrote: Sat Jan 18, 2025 2:42 pm
Revision: 1.14
Serial number: ...
PM sent.
Furiosa_NAS
#495 Post by Furiosa_NAS » Sat Jan 18, 2025 5:31 pm
The disc drive in my Zappiti/R_volution NAS seems to be on strike, so I am trying to use my external blu-ray drive but need UHD enabled.
Any and all help appreciated:
OS device name: /dev/rdisk7
Revision: 1.14
Serial number: ...
Highest AACS version: 70
