PM sent.SaberSage wrote: Fri Jan 17, 2025 1:05 am I am so sorry to bother you, really. I basically bought this drive assuming it could handle uhd and enabling uhd would be the only thing keeping me from sending it back. So thank you for doing what you are doing, and I would be grateful for a pm.
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ...
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Post your Makemkv info.merlyanne wrote: Sun Jan 12, 2025 7:18 pm Hi Coopervid, I have the Verbatim 43888 - that isn't reading 4k - are you able to help at all please?
Yethidran
Looks like my Verbatim 43888 with a Pioneer UD04 is also failing on me...
it refuses to read or load 4K UHD Discs too...i have cleaned the Lens with a QTip dipped with alcohol and dried the lens and clean it once again with a clean dry QTip, but to no avail...
any chance of getting the firmware to try and recover it with a Reflash?
Thanks in Advance.
Cheer's!!
OS device name: K:
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: ...
Highest AACS version: 68
Drive platform: RS8A10
Thanks in Advance.
Cheer's!!
OS device name: K:
Revision: 1.14
Serial number: ...
Nah.... Most likely a power problem since the Verbatim enclosure is very power hungry. Connect to USB-C or use a powered USB hub.Yethidran wrote: Fri Jan 17, 2025 1:19 pm Looks like my Verbatim 43888 with a Pioneer UD04 is also failing on me...
Thanks in Advance.
Cheer's!!
OS device name: K:
Revision: 1.14
Serial number: DFDL149576WL
Yethidran
Phew!! Solved the issue!!
i gave it a hard knock on the casing and turned the casing "Upside Down" and loaded the 4K disc and it started to work!!
Oh My!!
the things i do to torture these beautiful drives!!
Hahahaha!!
Oh My!!
Hahahaha!!
Yethidran
OS device name: \Device\CdRom5
Revision: 1.14
Disc Information
Label: OBLIVIONUHD_UPK1
Timestamp: 2016-07-05 11:51:42
Protection: AACS2.0/C v60
Data capacity: 60.88 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Revision: 1.14
Disc Information
Number of layers: 2
Yethidran
its working, but i have to place the drive upside down, and also gotta give it a knock in the center of the drive!!
zittrig
Knocking the drive hard is not the ususal way, I think
Coopervid pointed at the power supply of the 43888. You can also try change the cable, if the issue rise again or try to deactivate USB power save function. That's a experience that I've made (and it's a solution that the verbatim support suggested).
Yethidran
thanks zittrig, but where is the deactivate USB power save function?
my verbatim 43888 did not come with any software utilities.. there is a cd rom which has the nero burning software..
He means deactivate USB power save function in windows.Yethidran wrote: Sat Jan 18, 2025 4:56 am thanks zittrig, but where is the deactivate USB power save function?
Try using a USB-C port, a self powered USB hub (30w+) or at the very least a USB 3.0+ port direct on the motherboard.
zittrig
Yes, thanks Marty, that's was I meant. (my internet was shut down, so I wasn't able to reply ...
Yethidran
Ah ! Okie...
Thanks gentleman!!
Cheers!!
Thanks gentleman!!
Cheers!!
alpensiedler
hi coopervid, would you happen to have a uhd firmware that would work for my 43890:
many thanks in advance and have a great weekend!
Laufwerksinformation
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: ...
Firmware-Datum: 2020-06-15
Highest AACS version: 76
PM sent.alpensiedler wrote: Sun Jan 19, 2025 4:11 am hi coopervid, would you happen to have a uhd firmware that would work for my 43890:
many thanks in advance and have a great weekend!Code: Select all
Laufwerksinformation OS-Gerätename: E: Produzent: PIONEER Produkt: BD-RW BDR-UD03 Revision: 1.14 Serienummer: ... Firmware-Datum: 2020-06-15 Markierungen der Bus-Verschlüsselung: 1B Highest AACS version: 76 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
alpensiedler
