Firmware for LG BP60NB10 that is compatible with both MakeMKV and DVDFab
yuplayvpn
Post by yuplayvpn »
Hello! I have an LG BP60NB10 (NB12) drive that I flashed using SDFtool Flasher with firmware DE_LG_BP60NB10-NB12_1.02-MK.bin from MartyMcNuts' firmware pack. It works perfectly with MakeMKV. However, when I try to open a UHD disc with DVDFab, it reports:
"Your current drive is not supported. Please switch to a UHD-friendly drive that does not require AACS 2.0 authentication and then try again."
I guess this might be a firmware issue (but I'm not entirely sure). Is there a firmware version available that would work with both MakeMKV and DVDFab?
Thank you! :)
Re: Firmware for LG BP60NB10 that is compatible with both MakeMKV and DVDFab
yuplayvpn wrote: Fri Jan 17, 2025 5:10 am Hello! I have an LG BP60NB10 (NB12) drive that I flashed using SDFtool Flasher with firmware DE_LG_BP60NB10-NB12_1.02-MK.bin from MartyMcNuts' firmware pack. It works perfectly with MakeMKV. However, when I try to open a UHD disc with DVDFab, it reports:
Thank you! :)
MK firmwares don't work with DVDFab and no, there's not a BP60NB10 firmware compatible with DVDFab.
