Disc disappearing half way through rip
mumrah
Post by mumrah »
I've ripped 4 BD so far with no issues. On my first UHD rip, I'm getting an error around half way through the rip
002003:0000 Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00505.m2ts+00507.m2ts+00500.m2ts+00504.m2ts+00503.m2ts+00506.m2ts+00509.m2ts' at offset '26524778496'
001003:0020 DEBUG: Code 1073741830 at PG%TK;0&yG6+i331:213130559
002003:0000 Error 'Posix error - Device not configured' occurred while reading '/dev/rdisk9' at offset '26524778496'
DEBUG: Code 1073741830 at q3An)$5vw:?Ba+v4.5:29394896
001003:0020 DEBUG: Code 1073741830 at q3An)$5vw:?Ba+v4.5:213131502
It's like the disc just disappears?
I am using a Pioneer drive in an external Other World Computing enclosure (with external power). The OS sees this drive as a 5GB/s device, so I think the USB3.1 is being properly converted to USB-C by my adapter.
Any ideas what's causing this? I've ordered a dedicated USB 3.1 type B to USB-C cable to rule out adapter issues.
Edit: I noticed it happens at a different offset each time. On another attempt I got
Error 'Posix error - Device not configured' occurred while reading '/dev/rdisk5' at offset '26525958144'
which suggests that it is not specific to this disk, but rather a timing or power issue.
Re: Disc disappearing half way through rip
An issue can happen when the drive takes too long to decode data, and the OS decides to declare it "dead". This can happen when the drive reaches a speed that exceeds it's available power, common with USB devices. Your getting a higher-capability cable will likely help.
flojo
Post by flojo »
You need only USB 2.0 speeds. Also type C defines the mating form, not the speed.
Try a USB cable with thicker wires/lower AWG. You also want a power supply that can deliver >= 2 amps. If you're stuck with type C, a "charging" cable might be your best bet since they seemingly have thicker wires and meet the USB 2.0 (4 conductor) spec.
Type C "data" cables typically use higher AWG since there has to be at least 9 conductors inside the sheath I believe. The higher the AWG, the thinner the wires, so this is bad for the purpose you're attempting or any other power related applications. They make special type C "PD" data cables specifically to overcome the higher AWG problem.
https://en.wikipedia.org/wiki/Blu-ray#Drive_speeds
https://en.wikipedia.org/wiki/USB#Conne ... _reference
mumrah
Post by mumrah »
This is the cable I ordered https://www.amazon.com/gp/product/B00UXKTJE0
Right now I am using a short USB-C to USB-A adapter. It has worked fine for other BD discs, just not this large UHD one.
Are there any OS settings I can tweak to prevent the drive from being detected as dead?
According to System Information, the drive is not asking for any additional power from the OS.
Mercury Pro Optical:
  Product ID:	0xde2c
  Vendor ID:	0x1e91
  Version:	1.00
  Serial Number:	230924880EC5
  Speed:	Up to 5 Gb/s
  Manufacturer:	Other World Computing
  Location ID:	0x00200000 / 1
  Current Available (mA):	900
  Current Required (mA):	0
  Extra Operating Current (mA):	0
The power supply that came with the external enclosure is 12V 3A
flojo
Post by flojo »
I don't have that enclosure or use MacOS for anything block device related, but I will say that it seems like you have good enough hardware, so it might be a software problem. Can your drive read UHD discs? I don't know how to interpret "Device not configured".
mumrah
Post by mumrah »
I'm not sure how to tell. MakeMKV can load the track list.
MakeMKV v1.17.8 darwin(arm64-release) started
Debug logging enabled, log will be saved as /Users/davidarthur/MakeMKV_log.txt
Optical drive "BD-RE PIONEER BD-RW BDR-S13U 1.03 DIDL302009UCd" opened in OS access mode.
Using LibreDrive mode (v01.0 id=DFE22909F92F)
Using Java runtime from /Library/Java/JavaVirtualMachines/jdk-21.jdk/Contents/Home/bin/java
Title #00001.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.mpls has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.mpls has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.mpls has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00706.mpls was added as title #0
File 00823.mpls was added as title #1
File 00824.mpls was added as title #2
File 00016.mpls was added as title #3
File 00027.mpls was added as title #4
File 00030.mpls was added as title #5
File 00032.mpls was added as title #6
File 00038.mpls was added as title #7
File 00041.mpls was added as title #8
File 00043.mpls was added as title #9
File 00047.mpls was added as title #10
File 00048.mpls was added as title #11
File 00061.mpls was added as title #12
File 00062.mpls was added as title #13
File 00067.mpls was added as title #14
File 00071.mpls was added as title #15
File 00072.mpls was added as title #16
File 00073.mpls was added as title #17
File 00074.mpls was added as title #18
File 00078.mpls was added as title #19
File 00081.mpls was added as title #20
File 00084.mpls was added as title #21
File 00085.mpls was added as title #22
File 00086.mpls was added as title #23
File 00090.mpls was added as title #24
File 00091.mpls was added as title #25
File 00095.mpls was added as title #26
File 00099.mpls was added as title #27
File 00100.mpls was added as title #28
File 00103.mpls was added as title #29
File 00106.mpls was added as title #30
File 00109.mpls was added as title #31
File 00113.mpls was added as title #32
File 00131.mpls was added as title #33
File 00136.mpls was added as title #34
File 00143.mpls was added as title #35
File 00144.mpls was added as title #36
File 00146.mpls was added as title #37
File 00151.mpls was added as title #38
File 00152.mpls was added as title #39
File 00154.mpls was added as title #40
File 00155.mpls was added as title #41
File 00162.mpls was added as title #42
Title 00167.mpls is equal to title 00067.mpls and was skipped
File 00175.mpls was added as title #43
File 00178.mpls was added as title #44
File 00186.mpls was added as title #45
Title 00187.mpls is equal to title 00113.mpls and was skipped
File 00195.mpls was added as title #46
File 00199.mpls was added as title #47
File 00210.mpls was added as title #48
File 00230.mpls was added as title #49
File 00232.mpls was added as title #50
Title 00233.mpls is equal to title 00151.mpls and was skipped
File 00239.mpls was added as title #51
File 00252.mpls was added as title #52
File 00255.mpls was added as title #53
Title 00256.mpls is equal to title 00091.mpls and was skipped
File 00257.mpls was added as title #54
File 00260.mpls was added as title #55
File 00266.mpls was added as title #56
File 00267.mpls was added as title #57
File 00273.mpls was added as title #58
File 00287.mpls was added as title #59
File 00292.mpls was added as title #60
File 00297.mpls was added as title #61
File 00299.mpls was added as title #62
File 00300.mpls was added as title #63
File 00302.mpls was added as title #64
File 00307.mpls was added as title #65
File 00308.mpls was added as title #66
File 00310.mpls was added as title #67
File 00319.mpls was added as title #68
File 00321.mpls was added as title #69
File 00325.mpls was added as title #70
File 00329.mpls was added as title #71
File 00334.mpls was added as title #72
File 00338.mpls was added as title #73
Title 00341.mpls is equal to title 00074.mpls and was skipped
File 00342.mpls was added as title #74
File 00343.mpls was added as title #75
File 00346.mpls was added as title #76
Title 00351.mpls is equal to title 00030.mpls and was skipped
File 00352.mpls was added as title #77
File 00364.mpls was added as title #78
File 00365.mpls was added as title #79
File 00371.mpls was added as title #80
File 00380.mpls was added as title #81
File 00390.mpls was added as title #82
File 00395.mpls was added as title #83
File 00396.mpls was added as title #84
File 00397.mpls was added as title #85
File 00398.mpls was added as title #86
File 00404.mpls was added as title #87
File 00410.mpls was added as title #88
Title 00413.mpls is equal to title 00257.mpls and was skipped
File 00415.mpls was added as title #89
File 00427.mpls was added as title #90
File 00431.mpls was added as title #91
File 00432.mpls was added as title #92
File 00435.mpls was added as title #93
File 00437.mpls was added as title #94
File 00439.mpls was added as title #95
File 00444.mpls was added as title #96
Title 00446.mpls is equal to title 00032.mpls and was skipped
File 00454.mpls was added as title #97
Title 00456.mpls is equal to title 00043.mpls and was skipped
File 00459.mpls was added as title #98
File 00462.mpls was added as title #99
Title 00469.mpls is equal to title 00103.mpls and was skipped
File 00476.mpls was added as title #100
File 00479.mpls was added as title #101
File 00483.mpls was added as title #102
File 00485.mpls was added as title #103
File 00490.mpls was added as title #104
File 00507.mpls was added as title #105
File 00508.mpls was added as title #106
File 00512.mpls was added as title #107
File 00513.mpls was added as title #108
Title 00514.mpls is equal to title 00162.mpls and was skipped
Title 00523.mpls is equal to title 00410.mpls and was skipped
File 00526.mpls was added as title #109
File 00529.mpls was added as title #110
File 00531.mpls was added as title #111
File 00544.mpls was added as title #112
File 00580.mpls was added as title #113
File 00587.mpls was added as title #114
File 00596.mpls was added as title #115
File 00598.mpls was added as title #116
File 00600.mpls was added as title #117
File 00601.mpls was added as title #118
File 00602.mpls was added as title #119
File 00604.mpls was added as title #120
File 00605.mpls was added as title #121
File 00606.mpls was added as title #122
File 00607.mpls was added as title #123
File 00613.mpls was added as title #124
File 00615.mpls was added as title #125
File 00629.mpls was added as title #126
File 00631.mpls was added as title #127
File 00645.mpls was added as title #128
File 00671.mpls was added as title #129
File 00672.mpls was added as title #130
File 00675.mpls was added as title #131
File 00676.mpls was added as title #132
Title 00696.mpls is equal to title 00508.mpls and was skipped
File 00698.mpls was added as title #133
Title 00699.mpls is equal to title 00544.mpls and was skipped
File 00703.mpls was added as title #134
Title 00704.mpls is equal to title 00325.mpls and was skipped
File 00709.mpls was added as title #135
File 00715.mpls was added as title #136
File 00722.mpls was added as title #137
File 00724.mpls was added as title #138
File 00725.mpls was added as title #139
File 00730.mpls was added as title #140
File 00732.mpls was added as title #141
File 00743.mpls was added as title #142
File 00751.mpls was added as title #143
File 00755.mpls was added as title #144
File 00757.mpls was added as title #145
Title 00765.mpls is equal to title 00676.mpls and was skipped
Title 00767.mpls is equal to title 00629.mpls and was skipped
File 00775.mpls was added as title #146
Title 00778.mpls is equal to title 00703.mpls and was skipped
Title 00791.mpls is equal to title 00338.mpls and was skipped
File 00792.mpls was added as title #147
File 00795.mpls was added as title #148
File 00799.mpls was added as title #149
File 00800.mpls was added as title #150
Title 00801.mpls is equal to title 00103.mpls and was skipped
File 00827.mpls was added as title #151
Title 00829.mpls is equal to title 00091.mpls and was skipped
File 00830.mpls was added as title #152
File 00833.mpls was added as title #153
Title 00839.mpls is equal to title 00041.mpls and was skipped
File 00857.mpls was added as title #154
File 00861.mpls was added as title #155
File 00862.mpls was added as title #156
File 00865.mpls was added as title #157
File 00874.mpls was added as title #158
File 00885.mpls was added as title #159
Title 00886.mpls is equal to title 00410.mpls and was skipped
File 00895.mpls was added as title #160
File 00896.mpls was added as title #161
File 00903.mpls was added as title #162
File 00906.mpls was added as title #163
File 00909.mpls was added as title #164
File 00910.mpls was added as title #165
File 00915.mpls was added as title #166
File 00925.mpls was added as title #167
File 00927.mpls was added as title #168
File 00933.mpls was added as title #169
Title 00935.mpls is equal to title 00146.mpls and was skipped
File 00939.mpls was added as title #170
Title 00943.mpls is equal to title 00895.mpls and was skipped
File 00947.mpls was added as title #171
Title 00950.mpls is equal to title 00027.mpls and was skipped
File 00953.mpls was added as title #172
File 00955.mpls was added as title #173
File 00966.mpls was added as title #174
File 00968.mpls was added as title #175
File 00975.mpls was added as title #176
File 00976.mpls was added as title #177
File 00978.mpls was added as title #178
File 00979.mpls was added as title #179
File 00983.mpls was added as title #180
File 00987.mpls was added as title #181
File 00992.mpls was added as title #182
File 00999.mpls was added as title #183
Title #00002.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00276.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00277.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00279.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00280.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00500.m2ts was added as title #184
Title #00501.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00502.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00503.m2ts was added as title #185
Title #00504.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00505.m2ts was added as title #186
Title #00506.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00507.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00508.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00509.m2ts was added as title #187
Title #01984.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
I do notice that the track listing is a bit weird.
Screenshot 2025-01-17 at 12.06.52 PM.jpg (858.46 KiB) Viewed 10323 times
How can I check if the drive supports UHD? It's a Pioneer BDR-S13U
mumrah
Post by mumrah »
No luck after using a new cord. I guess this is an OS issue :-/
Has anyone had luck with this drive and ripping UHD on Mac OS?
mumrah wrote: Sun Jan 19, 2025 11:17 pm No luck after using a new cord. I guess this is an OS issue :-/
I rip on macOS all the time. My Pioneer drives are in Vantec cases instead of the OWC cases, although I have two non-Pioneer drives in OWC cases. Either case should be fine.
Are you sure you want to rip dozens of copies of the movie?
Does it work if you make a decrypted backup of the disc? (click the icon of the yellow folder with the green arrow on the first screen of MakeMKV) Once a backup is made, you can open that backup with MakeMKV and create .mkv files without having to read from the optical disc again.
mumrah
Post by mumrah »
Turns out this was a damaged disc. I have since tried other UHD discs and was able to rip with no problems.
