PM sent.gyazomember wrote: Mon Jan 06, 2025 2:34 pm Hello, is this firmware flashable as well? Kind regards
OS device name: E:
Current profile: DVD+R
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.10
Serial number: [redacted]
Firmware date: 2017-04-18
Drive platform: RS8511
Firmware version: 1.10
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
PM sent.urbanhym wrote: Wed Jan 08, 2025 12:52 am Same here:
Product: BD-RW BDR-UD03D
Revision: 1.00
Serial number: ...
Firmware date: 2014-05-14
Drive platform: RS8510
Firmware version: 1.00/ID84
PM sent.futuremon wrote: Wed Jan 08, 2025 1:04 am Hiya everyone,
It appears I'm also in the realm of the Pioneer BDR-UD03 drive not having the proper flashed update. What's the best way to flash the drive to enable reading of UHD 4K?
Many thanks! This forum has been super helpful!
Revision: 1.14
Firmware date: 2020-06-15
Highest AACS version: 66
Firmware version: 1.14
futuremon
You rock Cooper! Thank you for your help!
A warning to those morons who don't read their PMs after being helped. PMs will be deleted after 2 weeks and no new is coming.
crowtrobot
Well, it looks like I'm in the same boat.
OS device name: /dev/sr0
Revision: 1.14
Serial number: ...
Highest AACS version: 76
Thanks in advance!
Revision: 1.14
Serial number: ...
Thanks in advance!
funmonkey100
BD-RE PIONEER BD-RW BDR-UD03
1.10
SKDL1650****
Using LibreDrive mode (v01.0 id=A059FCFD72B3)
I also have this drive and can't seem to rip UHD discs.
Thank You.
1.10
SKDL1650****
Thank You.
MeeStaKlean
I have a new to me UD03 I would like to flash to UD04. Here is the optical spec
OS device name: E:
Revision: 1.00
Serial number: OBDL037500WL
Highest AACS version: 81
Thanks in advance
OS device name: E:
Revision: 1.00
Thanks in advance
Code-X
Could I get some help with UHD BD's based on the following information from my drive?
Revision: 1.14
Serial number: ...
Highest AACS version: 42
PM is coming.crowtrobot wrote: Wed Jan 15, 2025 6:38 am Well, it looks like I'm in the same boat.
Revision: 1.14
Serial number: ...
Thanks in advance!
PM will be sent shortly.funmonkey100 wrote: Wed Jan 15, 2025 10:41 am BD-RE PIONEER BD-RW BDR-UD03
1.10
SKDL1650****
Thank You.
crowtrobot
A huge thank you! It worked perfectly.
mcbreakfast
Hi have the same Drive, but never Revision.
Revision: 1.14
Serial number: ...
Highest AACS version: 71
PM sent.mcbreakfast wrote: Sat Jan 18, 2025 2:42 pmHi have the same Drive, but never Revision.
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: ... Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 71 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
Furiosa_NAS
The disc drive in my Zappiti/R_volution NAS seems to be on strike, so I am trying to use my external blu-ray drive but need UHD enabled.
Any and all help appreciated:
OS device name: /dev/rdisk7
Revision: 1.14
Serial number: ...
Highest AACS version: 70
Revision: 1.14
Serial number: ...
