Medium Error on single episode of a disc
Tavyk
Post by Tavyk »
Last year I got the blu-rays for seasons 1-3 of Agents of Shield on eBay, being seasons 1 and 3 used and season 2 brand new.
As soon as they arrived I ripped the first season and now, having binged it, I decided rip the other ones.
I've ripped all of the episodes, except for the first episode of season 2. All other episodes in that disc are perfectly fine and have been ripped.
The disc has some markings but reproduces perfectly on my blu-ray player (on my TV) and on VLC. I've tried cleaning it with a microfiber cloth but it didn't change anything.
Whenever I try to rip the first episode with MakeMKV, it fails around halfway the episode (watching I didn't notice any problems like hiccups or anything).
I'm using Windows 10 Pro and my drive is a LG BD-RE BP60NB10, patched.
This is the log from MakeMKV:
MakeMKV v1.17.8 win(x64-release) started
Using LibreDrive mode (v06.3 id=4C194CE2C4D1)
File 00801.mpls was added as title #0
File 00803.mpls was added as title #1
File 00802.mpls was added as title #2
File 00804.mpls was added as title #3
File 00805.mpls was added as title #4
[SKIPPED A BUNCH OF TITLES LESS THAN 180 SECS]
Saving 1 titles into directory E:/Séries e Filmes/Agents of SHIELD/Extraido-S2
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '3297570816'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '3297570816'
Failed to save title 0 to file E:/Séries e Filmes/Agents of SHIELD/Extraido-S2/Marvel's Agents Of S.H.I.E.L.D.- Season 2 (Disc 1)_t00.mkv
Encountered 35 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
I have tried to increase the retry count, it made no difference.
I don't have another drive as this one was expensive to import as it is.
After first trying to rip disc 1, I ripped the rest of season 2 and the entire season 3 with no problems (except some discs were slow to rip, but after cleaning them they went up to 4,3x).
I've read some people comment that the reason I can reproduce is because of error correcting VLC does. Is there a way to use EC to rip this one episode? Or a program that does it?
Worst case scenario I'll just play the episode and record the screen with OBS lol.
Re: Medium Error on single episode of a disc
This error:
means the drive was unable to correctly read a spot on the disc. The standard advice is to gently clean the disc and try again. Even though you mentioned attempting to clean the disc, it doesn't hurt to give it second cleaning at this point. If possible trying the disc in a different drive might work.
Generally speaking, MakeMKV either produces an exact, correct copy of the data on a disc or nothing. Blu-rays have something called the content hash table that MakeMKV uses to verify that what is read is actually correct. Regular players ignore read errors and hope the resulting glitch is too small to notice.
