Failed title - Log attached
ana2451
#1 Post by ana2451 » Mon Dec 02, 2019 6:27 pm
I am very new to MakeMKV (this is my first attempt at ripping).
I tried on the Polar Express DVD I have - there are 3 tracks for 3 different languages. I only selected the one for English and deselected everything else.
Every time I run, I keep getting an error and it not working.
I'm not really sure what I'm doing wrong or how to remedy - I've tried searching but haven't been able to find anything helpful for my issue.
The disk isn't exactly in mint condition - some slight smudges - but I was able to get it to work with other programs so I'm not sure if it's the program or what.
Re: Failed title - Log attached
#2 Post by Woodstock » Mon Dec 02, 2019 7:53 pm
Smudges cause read errors, so it is best to thoroughly clean the disk. Scratches too; they're worst when they follow the curve of the disk.
I believe Polar Express is a Disney title, and the 3 versions share almost all the same video, so an error in the wrong place will cause problems no matter which version you chose.
SOMETIMES, though, deselecting an audio or subtitle track can let the rip pass by a bad spot; it may be that the bad spot only affects one of the tracks in the title.
ana2451
#3 Post by ana2451 » Mon Dec 02, 2019 8:26 pm
I can get it to work with HandBrake but not with MakeMKV - should I just use that program instead?
None of the DVDs I have are without at least some minor scratches, unfortunately, due to use over the years. Does this program only really work on brand-new or like-new discs?
#4 Post by mike admin » Mon Dec 02, 2019 8:51 pm
ana2451 wrote: Mon Dec 02, 2019 8:26 pm I can get it to work with HandBrake but not with MakeMKV - should I just use that program instead?
Can you please test the newly-released 1.14.6, and if it still fails then post the updated log file. Thanks!
ana2451
#5 Post by ana2451 » Mon Dec 02, 2019 9:26 pm
Downloaded the new release and tried again - still failed unfortunately..
Attached is the log for this go-around!
deetce
#6 Post by deetce » Sat Dec 24, 2022 5:34 am
I know this is an older post, but i too have been having issues with Polar Express. We even went so far as to purchase a brand new disc to rule out any condition issues. We're able to get the program to successfully open and recognize data on the disc, but the second we try to move beyond that step, we get a failure error. here's the most recent log data from our new disc. Thoughts/help would be appreciated.
Complex multiplex encountered - 16 cells and 2623 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #1 was added (53 cell(s), 1:39:26)
Title #4 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory B:/Video/THE POLAR EXPRESS DISC 1
Failed to save title 0 to file B:/Video/THE POLAR EXPRESS DISC 1/THE POLAR EXPRESS DISC 1-A1_t00.mkv
0 titles saved, 1 failed
#7 Post by Woodstock » Sat Dec 24, 2022 4:15 pm
Make sure that you have "Log debug messages" checked on the first page of Preferences (the wrench-shaped icon). This will show more detail of WHY the rip failed.
deetce
#8 Post by deetce » Sun Dec 25, 2022 12:07 am
I'll be honest, i have no idea what any of it means...
#9 Post by Woodstock » Sun Dec 25, 2022 2:27 am
---- Failed B:/Video/THE POLAR EXPRESS DISC 1/THE POLAR EXPRESS DISC 1-A1_t00.mkv
Essentially, there is a problem with reading the file. MakeMKV couldn't read it after several attempts, so it's a "permanent error" (permanent as long as it's trying to read it that time), which likely can be cleaned.
Clean, damp, soft cloth, maybe with a little dish soap, across the disk (sideways, not circular!) should help.
ARandomNightFury
#10 Post by ARandomNightFury » Sun Dec 22, 2024 7:20 pm
I am posting to this thread as I have recently gotten what seems to be the exact same or similar release of The Polar Express (with the same "Complex multiplex encountered - 16 cells and 2623 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided." prompt during access). Attached is my debug log (with user information removed). This disc is very pristine, as I handled it with microfiber gloves after cleaning, to ensure no read errors relating to a dirty disc.
storageisfun
#11 Post by storageisfun » Mon Dec 30, 2024 6:34 am
An issue similar to this happened to me when ripping.
Maybe try ripping all of the files and all of the audio tracks and subtitles on the disc instead of just the specific one.
What is the physical condition of the disc? Smudged? Scratched to an extreme degree?
#12 Post by dcoke22 » Thu Jan 16, 2025 2:16 pm
ARandomNightFury wrote: Sun Dec 22, 2024 7:20 pm I am posting to this thread as I have recently gotten what seems to be the exact same or similar release of The Polar Express (with the same "Complex multiplex encountered - 16 cells and 2623 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided." prompt during access). Attached is my debug log (with user information removed). This disc is very pristine, as I handled it with microfiber gloves after cleaning, to ensure no read errors relating to a dirty disc.
Do you get the same error if you uncheck the closed captions/subtitles? With those unchecked, then CCExtractor won't run. I wonder if that produces a different result.
Additionally, do you get the same behavior if you try with an older version of MakeMKV, say 1.16.7 perhaps? https://makemkv.com/download/old/
