neo305
#16
Post
by neo305 » Thu Jan 16, 2025 1:15 pm
SamuriHL wrote:Just for future reference the keydb is updated real-time throughout the day. It's constantly being updated. So downloading it once it's not going to be sufficient for newer titles.
Sent from my SM-S928U1 using Tapatalk
Is there no way to do this automatically? We just have to dl it manually everytime we get a new release?
keydb_helper
#17
Post
by keydb_helper » Thu Jan 16, 2025 3:01 pm
kdubbs29 wrote: Thu Jan 16, 2025 1:12 pm
That makes total sense. I've never needed to download it prior to this.
1) Going forward, should I delete the KEYDB.cfg from my MakeMKV folder (I don't believe it was in that folder prior to this mess)?
2)I have my preferences set to enable internet access, so will that cover me going forward if I do delete the KEYDB.cfg file?
1. The public keydb.cfg file generally has support for new titles several days or even weeks before MakeMKV adds support via its native "hashed key" database. So deleting the keydb.cfg file will serve no other purpose than restricting the titles you can decrypt.
2. Allowing internet access in MakeMKV will allow it to fetch the latest "hashed key" database but as I mentioned this database is distinct from the public database and slower to support new titles.
neo305 wrote: Thu Jan 16, 2025 1:15 pm
The FindVUK tool is usually recommended for synchronizing your local keydb.cfg file. There are a few guides on this forum which might you find helpful.
#18
Post
by SamuriHL » Thu Jan 16, 2025 3:18 pm
Just make sure that once FindVUK updates the keydb.cfg file that it gets copied into the MakeMKV directory. That's why following the guides on this forum is recommended because coopervid and others show how to modify the findvuk syncrhonize bat file to add that copy so it happens automatically.
#19
Post
by SamuriHL » Fri Jan 17, 2025 2:44 pm
There is now.
viewtopic.php?p=166510#p166510
