NCIS: Los Angles Season 2 Disc 6
MR.WaynesWorld
#1 Post by MR.WaynesWorld » Sun Nov 06, 2011 3:45 pm
I have been having issues converting NCIS: Los Angles Season 2 Disc 6 to MKV files. Two of the episodes fail completely and another fails but actually creates the MKV file. The two that fail I get the following errors;
Saving 1 titles into directory C:/Video/NCIS_LA_S2_D6
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 822917120, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 822919168, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 822921216, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 822923264, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 822925312, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 822927360, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 822929408, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 822931456, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 822933504, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 822935552, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 822937600, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 822939648, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 822941696, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 822943744, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 822945792, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 822947840, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 823146496, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 827242496, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 827244544, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 827246592, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 827248640, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 827250688, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 827252736, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 827254784, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 827256832, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 827258880, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 827260928, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 827262976, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 827265024, attempting to work around
The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 827267072, attempting to work around
The dvd set is a a retail copy. Not sure if this is a bug or what. Looking for help with this problem...
TIA...
crowfax
Re: NCIS: Los Angles Season 2 Disc 6
#2 Post by crowfax » Sun Nov 06, 2011 9:27 pm
Most likely: Damaged disc.
Least likely: Failing DVD drive.
The error literally means the DVD drive can't read the disc.
You may wish to try cleaning the disc with a microfiber cloth, wiping from the center to the edge. Then trying to rip again.
If this fails return the DVD for another one.
MR.WaynesWorld
#3 Post by MR.WaynesWorld » Mon Nov 07, 2011 1:21 am
This is the third set that this has happened to and on two different computers... I thought that is was defective at first as well.. I have tried the same disc with handbrake and DVDFab and they do not have issues with it... Seems funny that I went through three sets of the same DVD series. Was just wondering if anyone else has had the same issue with the same series and disc..
crowfax
#4 Post by crowfax » Mon Nov 07, 2011 2:31 am
It would not be the first time that a whole run of DVD's had been poorly manufactured. However, if you could do the following and send it to the developers, if it is an issue with MakeMKV they can address it.
http://www.makemkv.com/faq/item/8
