Pioneer BDR-212DBK vs BDR-212V
PurpleWayneMV
Re: Pioneer BDR-212DBK vs BDR-212V
I just received my new Pioneer BDR-212V. Would appreciate any help with getting the firmware information for flashing the BDR-212V to support Libredrive and UHD.
(I will have it replace my older BDR-209DBK drive which has been failing. I had asked about it here before, but I gave up trying to find a lasting fix. It works inconsistently. I tried cleaning the lens, but I think the problem is something else with the drive. Maybe it could be repaired, but that would take someone with much more skill than I have.)
Thanks.
OS device name: E:
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: xxxxxxxxxxxxx
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 78
Firmware version: ID06
Thanks.
OS device name: E:
Revision: 1.02
sure email me this goes for every one see belowPurpleWayneMV wrote: Mon Jan 06, 2025 4:02 am I just received my new Pioneer BDR-212V. Would appreciate any help with getting the firmware information for flashing the BDR-212V to support Libredrive and UHD.
Thanks.
OS device name: E:
Revision: 1.02
I also recently obtained a Pioneer BDR-212V and would like to "liberate" it for UHD-videos. Any help is much appreciated.
Here is the drive info from MakeMKV:
A Happy New Year to all!
OS device name: F:
Revision: 1.02
Serial number: <REDACTED>
Firmware version: ID06Re: Pioneer BDR-212DBK vs BDR-212V
PM sent.tangofan wrote: Tue Jan 07, 2025 3:37 am I also recently obtained a Pioneer BDR-212V and would like to "liberate" it for UHD-videos. Any help is much appreciated.
A Happy New Year to all!Code: Select all
Drive Information OS device name: F: Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Serial number: <REDACTED> Firmware date: 2022-05-31 Bus encryption flags: 13 Highest AACS version: 78 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06
I'm also looking for firmware for a new BDR-212V. Any and all help would be appreciated, Thanks!
OS device name: G:
Revision: 1.02
Serial number: XXXXX
Highest AACS version: 77
PM sent.jstabb wrote: Mon Jan 13, 2025 11:44 pm I'm also looking for firmware for a new BDR-212V. Any and all help would be appreciated, Thanks!
Drive Information OS device name: G: Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Serial number: XXXXX Firmware date: 2022-05-31 Bus encryption flags: 13 Highest AACS version: 77 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06
Worked a treat. Thank you!Coopervid wrote: Tue Jan 14, 2025 3:10 pmPM sent.jstabb wrote: Mon Jan 13, 2025 11:44 pm I'm also looking for firmware for a new BDR-212V. Any and all help would be appreciated, Thanks!
asperatedgerm
I'd like to liberate my pioneer drive, if possible.
Thank you in advance for assistance.
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: XXXXXXXXXXXX
Firmware date: 2022-12-27
Highest AACS version: 68
Drive platform: Pioneer RS9331Re: Pioneer BDR-212DBK vs BDR-212V
Not possible. Your firmware is too new and your drive can't be flashed.asperatedgerm wrote: Wed Jan 15, 2025 5:27 pm Hello,
Thank you in advance for assistance.Code: Select all
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-XD08U Revision: 1.02 Serial number: XXXXXXXXXXXX Firmware date: 2022-12-27 Bus encryption flags: 1B Highest AACS version: 68 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS9331
vmware-fanboy
Hello Coopervid I have just purchased Pioneer BDR-212V with drive information below.
Can you please advise me on next steps for libredrive firmware?
Thank you very much.
OS device name: E:
Revision: 1.02
PM sent.vmware-fanboy wrote: Thu Jan 16, 2025 4:12 pm Hello Coopervid I have just purchased Pioneer BDR-212V with drive information below.
Can you please advise me on next steps for libredrive firmware?Code: Select all
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Firmware date: 2022-05-31 Bus encryption flags: 13 Highest AACS version: 68 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06 No disc inserted
BullyFreeBear
Hi Coopervid, I would like to flash my BDR-212v.
I just made a account so let me know if I need to do anything!
OS device name: E:
Revision: 1.02
Highest AACS version: 81
OS device name: E:
Revision: 1.02
PM sent.BullyFreeBear wrote: Sat Jan 18, 2025 9:43 pm Hi Coopervid, I would like to flash my BDR-212v.
OS device name: E:
Revision: 1.02
BullyFreeBear
Thank you Cooper! Everything worked!
Hi Coovervid, could you help me out?
OS device name: /dev/rdisk4
Revision: 1.02
