BDR-XD07B UHD Flash
skrubbles
BDR-XD07B UHD Flash
#1 Post by skrubbles » Thu Aug 01, 2024 11:24 pm
I recently got a BDR-XD07B off of Ebay. Is it possible to flash this to enable UHD?
OS device name: /dev/rdisk2
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.02
Serial number:
Firmware date: 2019-09-05
Bus encryption flags: 13
Highest AACS version: 65
Drive platform: RS8D30
Firmware version: 1.02
Re: BDR-XD07B UHD Flash
#2 Post by Coopervid » Fri Aug 02, 2024 9:00 am
Revision: 1.02
Serial number:
Raed the PM I will send to you.
skrubbles
#3 Post by skrubbles » Sat Aug 03, 2024 2:00 am
Thank you! Just finished flashing and everything seems to work :)
Phillipino
#4 Post by Phillipino » Tue Dec 31, 2024 6:31 pm
I have this same drive too! can it be made to work with 4K UHD as well? or is that the same as UHD? Please PM Me as well!
#5 Post by Coopervid » Tue Dec 31, 2024 7:47 pm
You need to post your Makemkv info.
Phillipino
#6 Post by Phillipino » Thu Jan 02, 2025 6:39 am
Forgive me, I'm still new. Is this the information that's on the bottom label of the drive? Or am I able to pull this info from elsewhere?
#7 Post by Coopervid » Thu Jan 02, 2025 2:02 pm
Install and run Makemkv. Then copy & paste the text it shows about your drive in your next post.
Phillipino
#8 Post by Phillipino » Fri Jan 03, 2025 9:15 am
OS device name: E:
Revision: 1.02
Serial number:
Highest AACS version: 81
Here's what I have!
Chewey182
#9 Post by Chewey182 » Sat Jan 04, 2025 12:29 pm
OS device name: E:
Revision: 1.03
Serial number: ...
Firmware date: 2020-08-20
Firmware version: 1.03
me too! :D
RexRazor
#10 Post by RexRazor » Wed Jan 08, 2025 12:07 am
I owned this drive for a few years now. I'm wondering what it will take to make it work to read UHD? Blu-ray disk works just fine. Any help would be greatly appreciated!
Revision: 1.02
Serial number: ...
#11 Post by Coopervid » Wed Jan 08, 2025 10:57 am
OS device name: E:
Revision: 1.02
Serial number:
Here's what I have!
PM sent.
#12 Post by Coopervid » Wed Jan 08, 2025 10:59 am
Revision: 1.02
Serial number: ...
PM sent.
Cush1978
#13 Post by Cush1978 » Tue Jan 14, 2025 9:44 pm
I think I'm in the same boat here:
OS device name: E:
Revision: 1.03
Serial number: ...
#14 Post by Coopervid » Tue Jan 14, 2025 10:31 pm
OS device name: E:
Revision: 1.03
Serial number: ...
Your boat is floating.
LordBrandon
#15 Post by LordBrandon » Wed Jan 15, 2025 1:24 am
So it looks like I was fortunate enough to buy a drive that can support UHD disks, but it seems I need help in order for it to do so.
Is there someone who can help me to get it working?
OS device name: H:
Revision: 1.03
Serial number: ---
Highest AACS version: 56
I took out the serial number but can give it if needed.
Brandon
