Is my pioneer BDR-XD05s flashable?
Re: Is my pioneer BDR-XD05s flashable?
Post by Coopervid » Thu Jan 09, 2025 9:27 pm
vtedogs wrote: Thu Jan 09, 2025 5:51 pm Is mine flashable ?
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: ..
Firmware date: 2017-06-22
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
PM sent.
RB2049
Post by RB2049 » Sun Jan 12, 2025 3:05 pm
Coopervid wrote: Wed Jan 08, 2025 11:15 am
RB2049 wrote: Sat Jan 04, 2025 8:51 pm I was wondering if my drive would also be flashable
Drive informatie
Naam OS-apparaat: \Device\CdRom1
Huidig profiel: BD-R SRM
Fabrikant: PIONEER
Revisie: 3.01
Serienummer: ...
Firmware datum: 2014-12-26
Bus encryptie flags: 1B
Highest AACS version: 77
Drive platform: RS8231
Firmware version: 3.01/ID34
And on a sidenote, I have another Pioneer drive that does not seem to read blu ray's but it might be able to?
That would be the following drive
Drive informatie
Naam OS-apparaat: G:
Fabrikant: PIONEER
Product: BDW-PR1EPDVPP100
Revisie: 1.01
Serienummer: ...
Firmware datum: 2018-03-06
Drive platform: Pioneer RS8680
Firmware version: ID79
Edit:
Ps: apologies for the direct question(s). I haven’t looked here in ages and saw this post and jumped on the opportunity to ask the question.
Greetings all!
PM sent.
Dear Coopervid, thank you! It worked for the BD-RW BDR-XD05.
The reason I mentioned the BDW-PR1EPDVPP100: apparently it is used to write (normal) Blu ray's in certain rigs, but the reading capability of the drive for the (normal) blu rays would be turned off according to google searches?
On the other hand, when I check the settings of the drive for blu rays then it says R/W "switched on"...? So I would expect it to read or see blu rays but it never does.
It reads DVD's fine.
If you have any suggestions to make the blu ray burner also read blu rays I would be happy to hear them.
Thanks again for the BD-RW BDR-XD05!
Post by Coopervid » Tue Jan 14, 2025 5:30 pm
RB2049 wrote: Sun Jan 12, 2025 3:05 pm
Drive informatie
Fabrikant: PIONEER
Revisie: 3.01
Serienummer: ...
Drive informatie
Fabrikant: PIONEER
Revisie: 1.01
Serienummer: ...
Edit:
Greetings all!
PM sent.
AFAIK there is no compatible firmware for your other drive.
RB2049
Post by RB2049 » Tue Jan 14, 2025 9:03 pm
Ok, thanks again for the information and the help!
Greetings!
RB2049
Post by RB2049 » Thu Jan 16, 2025 9:16 am
RB2049 wrote: Tue Jan 14, 2025 9:03 pm
Greetings!
Ok, sorry to come back to this again, but:
I read on another forum that the BDW-PR1EPDVPP100 in some cases has the PIONEER BDR-209 firmware.
Is it possible to write that firmware or a similar/compatible firmware to the drive?
Would be gratefull if I could try.
Greetings!
halodies
Post by halodies » Thu Jan 16, 2025 6:52 pm
Is my drive flashable?
Revision: 3.01
Serial number: ...
Firmware date: 2014-12-26
Highest AACS version: 50
Thank you in advance.
halodies
Post by halodies » Fri Jan 17, 2025 8:11 am
I'm really new to the UHD ripping scene, I tried to load Warcraft UDH bluray and it didn't load, no sure what is going on
Post by Coopervid » Fri Jan 17, 2025 11:18 am
halodies wrote: Thu Jan 16, 2025 6:52 pm Is my drive flashable?
Revision: 3.01
Serial number: ...
PM sent.
Post by Coopervid » Fri Jan 17, 2025 11:46 am
RB2049 wrote: Thu Jan 16, 2025 9:16 am
Greetings!
Greetings!
Check your PM.
jimmyjam105
Post by jimmyjam105 » Fri Jan 17, 2025 11:05 pm
Looks like I am potentially in luck here as my device is near exact as many of the others commenting in this thread. I was looking over the "Ultimate UHD Drives Flashing Guide Updated 2025" post just above this, and saw you (Coop) as an author and loads of info there, but then found this fresh chain and wasn't sure if you were supplying the others more targeted/specific information or not via PM. Would you be so kind as to sharing your instruction via PM with me also? TYVM
Revision: 3.01
Serial number: REMOVED
halodies
Post by halodies » Sat Jan 18, 2025 8:32 am
Coopervid wrote: Fri Jan 17, 2025 11:18 am
Revision: 3.01
Serial number: ...
PM sent.
YOU RULE
Post by Coopervid » Sat Jan 18, 2025 12:25 pm
jimmyjam105 wrote: Fri Jan 17, 2025 11:05 pm Looks like I am potentially in luck here as my device is near exact as many of the others commenting in this thread. I was looking over the "Ultimate UHD Drives Flashing Guide Updated 2025" post just above this, and saw you (Coop) as an author and loads of info there, but then found this fresh chain and wasn't sure if you were supplying the others more targeted/specific information or not via PM. Would you be so kind as to sharing your instruction via PM with me also? TYVM
Revision: 3.01
PM sent.
nevermindmyname
Post by nevermindmyname » Sun Jan 19, 2025 3:52 am
Revision: 3.10
Highest AACS version: 81
Post by Coopervid » Sun Jan 19, 2025 10:21 am
nevermindmyname wrote: Sun Jan 19, 2025 3:52 am Is my drive flashable?
Revision: 3.10
PM sent.
Yethidran
Post by Yethidran » Mon Jan 20, 2025 4:37 am
Just bought a Used Set of this BDR-XD05 in Piano Gloss Red, as my Verbatim 43888 with a Pioneer UD04 died on me.
Hopefully i can have it Liberated to be UHD spec's too.
Thanks Coopervid.
OS device name: I:
Revision: 1.21
Serial number: ...
Firmware date: 2014-04-02
Highest AACS version: 68
Firmware version: 1.21/ID69
