Asus BW-16D1X-U
SilentDave
Re: Asus BW-16D1X-U
Post by SilentDave » Sat Jan 11, 2025 8:27 pm
Billycar11 wrote: Tue Jan 07, 2025 12:06 am
jsmelcer wrote: Mon Jan 06, 2025 11:56 pm Hi, I am curious if i could get some assistance too, i have the same drive.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: XXXXXXXXXXX
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Highest AACS version: 16
but its actually an lg not a pioneer
but you can flash it easy see guide below or if you want an auto flash kit email me or marty
I have the exact same drive. How do I email you for the auto flash kit?
Re: Asus BW-16D1X-U
Post by Billycar11 » Sat Jan 11, 2025 10:50 pm
SilentDave wrote: Sat Jan 11, 2025 8:27 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Email is in my signature below
SilentDave
Re: Asus BW-16D1X-U
Post by SilentDave » Sat Jan 11, 2025 10:58 pm
Billycar11 wrote: Sat Jan 11, 2025 10:50 pm
Lol, yeah, I noticed that after I sent my post. I'm confident I can flash it myself, just not 100% sure what firmware to use. Found a Reddit post where someone listed the FW they used (also had the same drive, just different FW), just wanted to get some input from someone knowledgeable here first.
EDIT: Got it flashed successfully 👍🏼
Dazkey69
Re: Asus BW-16D1X-U
Post by Dazkey69 » Thu Jan 16, 2025 6:16 am
New to this.
I am still confused on whether or not patching this is possible.
If I do patch it, do i use the ASUS or the Pioneer?
Screenshot 2025-01-16 011230.png (63.21 KiB) Viewed 21346 times
Re: Asus BW-16D1X-U
Post by Billycar11 » Thu Jan 16, 2025 6:58 am
Dazkey69 wrote: Thu Jan 16, 2025 6:16 am New to this.
yeah email me its a pioneer
you have to remember asus does not make optical drives they rebrand them from lg or pioneer
pioneers are the better ones
charly700
Re: Asus BW-16D1X-U
Post by charly700 » Fri Jan 17, 2025 5:25 pm
Coopervid wrote: Thu Dec 05, 2024 10:16 am
Applesauce wrote: Thu Dec 05, 2024 1:21 am
Coopervid wrote: Wed Dec 04, 2024 7:24 pm
Post your full Makemkv info.
Laufwerksinformation
OS-Gerätename: /dev/sr0
Produzent: ASUS
Produkt: BW-16D1X-U
Revision: E113
Serienummer:
Firmware-Datum: 2020-07-21
Highest AACS version: 81
Firmware version: ID76
PM sent.
Hello, this is my drive from Asus. Can anyone help me to make it UHD Friendly? Thank you
Re: Asus BW-16D1X-U
Post by Coopervid » Fri Jan 17, 2025 9:27 pm
charly700 wrote: Fri Jan 17, 2025 5:25 pm
Produzent: ASUS
Produkt: BW-16D1X-U
Revision: E113
Serienummer:
PM sent.
Post YOUR info and not a quote.
charly700
Re: Asus BW-16D1X-U
Post by charly700 » Fri Jan 17, 2025 10:43 pm
Produzent: ASUS
Produkt: BW-16D1X-U
Revision: E113
Serienummer:
This is my data. I just wrote it in the quote by mistake.
Re: Asus BW-16D1X-U
Post by Coopervid » Sat Jan 18, 2025 12:42 pm
charly700 wrote: Fri Jan 17, 2025 10:43 pm
Produzent: ASUS
Produkt: BW-16D1X-U
Revision: E113
Serienummer:
PM sent.
charly700
Re: Asus BW-16D1X-U
Post by charly700 » Sat Jan 18, 2025 9:24 pm
Coopervid wrote: Sat Jan 18, 2025 12:42 pm
Produzent: ASUS
Produkt: BW-16D1X-U
Revision: E113
Serienummer:
PM sent.
Thank you. Worked perfectly.
enenine
Re: Asus BW-16D1X-U
Post by enenine » Sun Jan 19, 2025 7:24 pm
Can someone send me instructions as well? I'm happy to self-service more if I need to be redirected, though the trend seems to be to ask for a PM? Thanks for any pointers!
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: ...
Highest AACS version: 40
Re: Asus BW-16D1X-U
Post by Coopervid » Sun Jan 19, 2025 9:07 pm
enenine wrote: Sun Jan 19, 2025 7:24 pm Can someone send me instructions as well? I'm happy to self-service more if I need to be redirected, though the trend seems to be to ask for a PM? Thanks for any pointers!
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: ...
You have a LG drive. Read here:
viewtopic.php?f=16&t=19634
enotwhx69
Re: Asus BW-16D1X-U
Post by enotwhx69 » Thu Jan 30, 2025 2:14 am
hi just wanted to share my results with this same drive Asus BW-16D1X-U
Screenshot 2025-01-29 140451.png (14.42 KiB) Viewed 20788 times
images is of the drive and what makemkv reported
odd the label says a205 and makemkv detected a105
but the bh50N was gold to me
SDFtool Flasher (v1.3.5)
used fw: HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936
Screenshot 2025-01-29 173340.png (86.71 KiB) Viewed 20788 times
flashed w/o errors
sophonax42
Re: Asus BW-16D1X-U
Post by sophonax42 » Fri Jan 31, 2025 2:28 pm
I have this:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ---
Firmware date: 2020-07-21
Highest AACS version: 76
Re: Asus BW-16D1X-U
Post by Coopervid » Fri Jan 31, 2025 9:22 pm
sophonax42 wrote: Fri Jan 31, 2025 2:28 pm I have this:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ---
PM sent.
