I have the exact same drive. How do I email you for the auto flash kit?Billycar11 wrote: Tue Jan 07, 2025 12:06 ambut its actually an lg not a pioneerjsmelcer wrote: Mon Jan 06, 2025 11:56 pm Hi, I am curious if i could get some assistance too, i have the same drive.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: XXXXXXXXXXX
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Highest AACS version: 16
but you can flash it easy see guide below or if you want an auto flash kit email me or marty
Asus BW-16D1X-U
SilentDave
Re: Asus BW-16D1X-U
Re: Asus BW-16D1X-U
Email is in my signature belowSilentDave wrote: Sat Jan 11, 2025 8:27 pmI have the exact same drive. How do I email you for the auto flash kit?Billycar11 wrote: Tue Jan 07, 2025 12:06 ambut its actually an lg not a pioneerjsmelcer wrote: Mon Jan 06, 2025 11:56 pm Hi, I am curious if i could get some assistance too, i have the same drive.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
SilentDave
Re: Asus BW-16D1X-U
Lol, yeah, I noticed that after I sent my post. I'm confident I can flash it myself, just not 100% sure what firmware to use. Found a Reddit post where someone listed the FW they used (also had the same drive, just different FW), just wanted to get some input from someone knowledgeable here first.Billycar11 wrote: Sat Jan 11, 2025 10:50 pmEmail is in my signature belowSilentDave wrote: Sat Jan 11, 2025 8:27 pmI have the exact same drive. How do I email you for the auto flash kit?Billycar11 wrote: Tue Jan 07, 2025 12:06 am
EDIT: Got it flashed successfully
Re: Asus BW-16D1X-U
New to this.
I am still confused on whether or not patching this is possible.
If I do patch it, do i use the ASUS or the Pioneer?
- Screenshot 2025-01-16 011230.png (63.21 KiB) Viewed 21843 times
Re: Asus BW-16D1X-U
yeah email me its a pioneerDazkey69 wrote: Thu Jan 16, 2025 6:16 am New to this.
you have to remember asus does not make optical drives they rebrand them from lg or pioneer
pioneers are the better ones
Re: Asus BW-16D1X-U
Hello, this is my drive from Asus. Can anyone help me to make it UHD Friendly? Thank youCoopervid wrote: Thu Dec 05, 2024 10:16 amPM sent.Applesauce wrote: Thu Dec 05, 2024 1:21 amLaufwerksinformation
OS-Gerätename: /dev/sr0
Produzent: ASUS
Produkt: BW-16D1X-U
Revision: E113
Serienummer:
Firmware-Datum: 2020-07-21
Highest AACS version: 81
Firmware version: ID76
Re: Asus BW-16D1X-U
Post YOUR info and not a quote.charly700 wrote: Fri Jan 17, 2025 5:25 pmHello, this is my drive from Asus. Can anyone help me to make it UHD Friendly? Thank youCoopervid wrote: Thu Dec 05, 2024 10:16 amPM sent.Applesauce wrote: Thu Dec 05, 2024 1:21 am
Produzent: ASUS
Produkt: BW-16D1X-U
Revision: E113
Serienummer:
Re: Asus BW-16D1X-U
Produzent: ASUS
Produkt: BW-16D1X-U
Revision: E113
Serienummer:
Firmware version: ID76 Re: Asus BW-16D1X-U
PM sent.charly700 wrote: Fri Jan 17, 2025 10:43 pmThis is my data. I just wrote it in the quote by mistake.Code: Select all
Laufwerksinformation OS-Gerätename: /dev/sr0 Produzent: ASUS Produkt: BW-16D1X-U Revision: E113 Serienummer: Firmware-Datum: 2020-07-21 Markierungen der Bus-Verschlüsselung: 1B Highest AACS version: 81 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID76
Re: Asus BW-16D1X-U
Thank you. Worked perfectly.Coopervid wrote: Sat Jan 18, 2025 12:42 pmPM sent.charly700 wrote: Fri Jan 17, 2025 10:43 pmThis is my data. I just wrote it in the quote by mistake.Code: Select all
Re: Asus BW-16D1X-U
Can someone send me instructions as well? I'm happy to self-service more if I need to be redirected, though the trend seems to be to ask for a PM? Thanks for any pointers!
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: ...
Highest AACS version: 40
Re: Asus BW-16D1X-U
You have a LG drive. Read here:enenine wrote: Sun Jan 19, 2025 7:24 pm Can someone send me instructions as well? I'm happy to self-service more if I need to be redirected, though the trend seems to be to ask for a PM? Thanks for any pointers!
Drive Information OS device name: /dev/sr0 Current profile: BD-ROM Manufacturer: ASUS Product: BW-16D1X-U Revision: A105 Serial number: ... Firmware date: 2120-12-02 11:14 Bus encryption flags: 1F Highest AACS version: 40 LibreDrive Information Status: Possible, not yet enabled Drive platform: MT1959 No disc inserted
viewtopic.php?f=16&t=19634
Re: Asus BW-16D1X-U
hi just wanted to share my results with this same drive Asus BW-16D1X-U
images is of the drive and what makemkv reported
odd the label says a205 and makemkv detected a105
but the bh50N was gold to me
SDFtool Flasher (v1.3.5)
used fw: HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936 flashed w/o errors
sophonax42
Re: Asus BW-16D1X-U
I have this:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ---
Firmware date: 2020-07-21
Highest AACS version: 76
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ---
Re: Asus BW-16D1X-U
PM sent.sophonax42 wrote: Fri Jan 31, 2025 2:28 pm I have this:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ---
