Not all subtitles are visible in MakeMKV
mryoaz
Post by mryoaz » Sat Jan 11, 2025 8:00 pm
I have a blu-ray which have more subtitles then MakeMKV is showing. In VLC play I see 16 tracks for subtitles. In MakeMKV there are only 3: english, japanese (2x). The one I want (dutch) is not present.
Different preferred language settings: default, english, dutch will produce the same result.
Is there a way to get the subtitles I want?
Re: Not all subtitles are visible in MakeMKV
Post by Woodstock » Sat Jan 11, 2025 10:53 pm
Under Preferences->Language, what do you have set for "Preferred language"? If anything other than "none" is set, it will hide other languages by default. With a setting of "none", though, you should see a list of selectable languages for both audio and subtitle.
Under the "Advanced" tab (only visible if you have "Expert mode" checked in the General tab), there is a Default selection rule that lets you set which languages are preferred.
mryoaz
Post by mryoaz » Sun Jan 12, 2025 6:44 pm
If have "Preferred language"" at none.
The default selection rule is:
-sel:all,+sel:(favlang|nolang),-sel:mvcvideo,=100:all,-10:favlang
I never changed those settings, with other blu-ray's i haven't experienced this problem.
Post by dcoke22 » Thu Jan 23, 2025 10:24 pm
The .mpls file that defines that title is probably hiding the other subtitles. If you look at the underlying .m2ts file, you'll find all the audio and subtitle tracks available. On the disc there is probably a different .mpls file that defines a different title that surfaces different audio or subtitle tracks.
