I don't charge for it but you are free to send some bucks as appreciation.Fox_Mulder wrote: Fri Jan 10, 2025 2:10 amHow much should the firmware cost? I'm trying to decide which is more worthwhile.
Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
RobinStn
Drive informatie
Naam OS-apparaat: E:
Fabrikant: PIONEER
Product: BD-RW BDR-UD03
Revisie: 1.14
Serienummer: ...
Firmware datum: 2020-06-15
Bus encryptie flags: 1B
PM sent.RobinStn wrote: Fri Jan 10, 2025 4:51 pmDrive informatie
Fabrikant: PIONEER
Revisie: 1.14
Serienummer: ...
Gotham67
Hi Coopervid, seems you can help alot of us here :=)
It appears I have the same BD player, is it possible to send me a PM also please ?
Thx a lot!
Thx a lot!
Manufacturer: PIONEER
Revision: 1.14
Serial number: ..
Firmware date: 2020-06-15
Highest AACS version: 46
Drive platform: RS8511
Firmware version: 1.14
Unrestricted read speed: Yes-
PM sent.Gotham67 wrote: Sat Jan 11, 2025 1:05 am Hi Coopervid, seems you can help alot of us here :=)
Thx a lot!Code: Select all
Drive Information OS device name: D: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: .. Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 46 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
xSt0rmx
Hey Coopervid, if you could help me out as well I would appreciate it!
Revision: 1.14
Serial number: ...
Revision: 1.14
Serial number: ...
merlyanne
Hi Coopervid, I have the Verbatim 43888 - that isn't reading 4k - are you able to help at all please?
PM sent.xSt0rmx wrote: Sat Jan 11, 2025 6:34 pm Hey Coopervid, if you could help me out as well I would appreciate it!
Revision: 1.14
Serial number: ...
Rastarize
Hey Coopervid, would appreciate your help as well.
Revision: 1.14
Serial number: xxxxxxxx
Revision: 1.14
Pm sent.Rastarize wrote: Sun Jan 12, 2025 9:35 pm Hey Coopervid, would appreciate your help as well.
Revision: 1.14
rr17302
Coopervid, I just purchased the Verbatim 43890. Can you help me have this read UHD BDs? Here's the MakeMKV data:
OS device name: F:
Revision: 1.14
Serial number: ...
Highest AACS version: 81
Thank you. Ron
OS device name: F:
Revision: 1.14
Serial number: ...
Thank you. Ron
PM sent.rr17302 wrote: Wed Jan 15, 2025 11:47 pm Coopervid, I just purchased the Verbatim 43890. Can you help me have this read UHD BDs? Here's the MakeMKV data:
OS device name: F:
Revision: 1.14
Serial number: ...
Thank you. Ron
Code-X
Does the UHD update for BDR-UD03 also address the sleep issue?
SaberSage
I am so sorry to bother you, really. I basically bought this drive assuming it could handle uhd and enabling uhd would be the only thing keeping me from sending it back. So thank you for doing what you are doing, and I would be grateful for a pm.
OS device name: G:
Revision: 1.14
Serial number: ...
OS device name: G:
Revision: 1.14
Serial number: ...
Pioneers don't have the sleep bug. Only friendly LG drives have it.Code-X wrote: Fri Jan 17, 2025 12:19 am Does the UHD update for BDR-UD03 also address the sleep issue?
