Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Fox_Mulder wrote: Fri Jan 10, 2025 2:10 am
Coopervid wrote: Thu Jan 09, 2025 9:25 pm
RobinStn wrote: Thu Jan 09, 2025 9:08 pm Hallo Coopervid,
could you please send me the Firmware for the Verbatim 43890 Drive to support UHD discs.
I would appreciated it.
Post your Makemkv info.
How much should the firmware cost? I'm trying to decide which is more worthwhile.
I don't charge for it but you are free to send some bucks as appreciation.
RobinStn
Post by RobinStn »
Drive informatie
Naam OS-apparaat: E:
Fabrikant: PIONEER
Product: BD-RW BDR-UD03
Revisie: 1.14
Serienummer: ...
Firmware datum: 2020-06-15
Bus encryptie flags: 1B
RobinStn wrote: Fri Jan 10, 2025 4:51 pm
Drive informatie
Fabrikant: PIONEER
Revisie: 1.14
Serienummer: ...
PM sent.
Gotham67
Post by Gotham67 »
Hi Coopervid, seems you can help alot of us here :=)
It appears I have the same BD player, is it possible to send me a PM also please ?
Thx a lot!
Manufacturer: PIONEER
Revision: 1.14
Serial number: ..
Firmware date: 2020-06-15
Highest AACS version: 46
Drive platform: RS8511
Firmware version: 1.14
Gotham67 wrote: Sat Jan 11, 2025 1:05 am Hi Coopervid, seems you can help alot of us here :=)
Thx a lot!
Revision: 1.14
Serial number: ..
PM sent.
xSt0rmx
Post by xSt0rmx »
Hey Coopervid, if you could help me out as well I would appreciate it!
Revision: 1.14
Serial number: ...
merlyanne
Post by merlyanne »
Hi Coopervid, I have the Verbatim 43888 - that isn't reading 4k - are you able to help at all please?
xSt0rmx wrote: Sat Jan 11, 2025 6:34 pm Hey Coopervid, if you could help me out as well I would appreciate it!
Revision: 1.14
Serial number: ...
PM sent.
Rastarize
Post by Rastarize »
Hey Coopervid, would appreciate your help as well.
Revision: 1.14
Serial number: xxxxxxxx
Rastarize wrote: Sun Jan 12, 2025 9:35 pm Hey Coopervid, would appreciate your help as well.
Revision: 1.14
Pm sent.
rr17302
Post by rr17302 »
Coopervid, I just purchased the Verbatim 43890. Can you help me have this read UHD BDs? Here's the MakeMKV data:
OS device name: F:
Revision: 1.14
Serial number: ...
Highest AACS version: 81
Thank you. Ron
rr17302 wrote: Wed Jan 15, 2025 11:47 pm Coopervid, I just purchased the Verbatim 43890. Can you help me have this read UHD BDs? Here's the MakeMKV data:
OS device name: F:
Revision: 1.14
Serial number: ...
Thank you. Ron
PM sent.
Code-X
Post by Code-X »
Does the UHD update for BDR-UD03 also address the sleep issue?
SaberSage
Post by SaberSage »
I am so sorry to bother you, really. I basically bought this drive assuming it could handle uhd and enabling uhd would be the only thing keeping me from sending it back. So thank you for doing what you are doing, and I would be grateful for a pm.
OS device name: G:
Revision: 1.14
Serial number: ...
Code-X wrote: Fri Jan 17, 2025 12:19 am Does the UHD update for BDR-UD03 also address the sleep issue?
Pioneers don't have the sleep bug. Only friendly LG drives have it.
