Pauses when ripping then carries on
I'm not getting any error messages but this has happened to two different films, it will pause near the end you can hear the drive stops then in about 3-4 minutes it will start again.
It is a USB drive with no separate power cable.
Re: Pauses when ripping then carries on
Just seeing if it happens to anyone else? The drive stops for a few minutes then it powers up and then carries on, sometimes it will do it a couple of times during a rip.
Does it really stop or just slow down?
MakeMKV drive speed control
This is the last entry in that thread:
mike admin wrote:Starting with 1.15.3 MakeMKV manages read speed more actively. Specifically, it switches to the minimum speed not only on errors, but also around disc edges and layer breaks. Passing the layer switch on minimum speed eliminates many firmware bugs relayed to high-speed seek errors.
Its not speed control it completely stops the light on the player goes out, if I go into device manager the manager freezes.
Defective or dirty discs can lockup my LG disc player so badly that I need to power cycle my computer. Try cleaning or replacing the problem discs.
Thanks I will give it a clean the next time it happens.
I thought I would update this:jinx100 wrote: Fri Jan 10, 2025 1:47 pm Defective or dirty discs can lockup my LG disc player so badly that I need to power cycle my computer. Try cleaning or replacing the problem discs.
I think it could well be that the discs are dirty but not to the eye, I have had a handful of discs that pauses completely and then resumes after 5 minutes, while it has stopped MakeMKV seems to completely freeze with the rest of windows, not being able to do anything, it's strange though because if I let it wait it will come back to life and resumes with no errors. You would think it would pop up with a error.
For testing I have shutdown the computer and cleaned the disc with some specs glass cleaner and when I rip again it doesn't pause, sometimes it will pause at the last 20 seconds even though I gave it a good clean.
I got a new BU40N drive today and ripped my first 4K discs, it did this on every single one, somewhere during the process it stopped and the drive spun down, 5 minutes later it powered up again and continued like nothing happened, no disc failures or errors. I have ripped hundreds or regular blu rays and I have never seen this happen.
I dont know if the drive can pause itself due to heat or something but its real
it should not do that something is wrongterristaz wrote: Thu Jun 11, 2026 9:32 pm I got a new BU40N drive today and ripped my first 4K discs, it did this on every single one, somewhere during the process it stopped and the drive spun down, 5 minutes later it powered up again and continued like nothing happened, no disc failures or errors. I have ripped hundreds or regular blu rays and I have never seen this happen.
I dont know if the drive can pause itself due to heat or something but its real![]()
i have tested thousands of BU40Ns if that happens you dont have enough power or your usb ports are going to sleep turn off usb selective suspending or its having a hard time reading the disc
