deadchip12
Post by deadchip12 » Mon Jan 06, 2025 4:56 am
@RESET_9999
I looked for Alien Romulus web rpu in your google drive folder and only saw Alien.Romulus.2024.UHD.BluRay.2160p.TrueHD.Atmos.7.1.DV.HEVC.REMUX-FraMeSToR Retail P7 FEL (cmv4.0 added).bin. Is this file the equivalent of CMV4.0_L3L8L9_transfered.bin? Do we just inject this directly to the bluray mkv file?
darrrkmanxxx
Post by darrrkmanxxx » Mon Jan 06, 2025 9:34 am
deadchip12 wrote: Mon Jan 06, 2025 4:56 am @RESET_9999
can you please share the link with all of the RPUs?
Post by RESET_9999 » Mon Jan 06, 2025 12:08 pm
darrrkmanxxx wrote: Mon Jan 06, 2025 9:34 am can you please share the link with all of the RPUs?
The link is private...
Instructions on how to access it are in the Resolve Metadata Generation tutorial comments.
deadchip12 wrote: Mon Jan 06, 2025 4:56 am I looked for Alien Romulus web rpu in your google drive folder and only saw Alien.Romulus.2024.UHD.BluRay.2160p.TrueHD.Atmos.7.1.DV.HEVC.REMUX-FraMeSToR Retail P7 FEL (cmv4.0 added).bin. Is this file the equivalent of CMV4.0_L3L8L9_transfered.bin? Do we just inject this directly to the bluray mkv file?
yes, I did all the possible movies on my GD.
darrrkmanxxx
Post by darrrkmanxxx » Tue Jan 07, 2025 1:20 pm
@RESET_9999
For devices who can't play P7, what would be the workflow to get the best out of dynamic metadata?
exmaple:
I have one profile 7 remux and a web-dl profile 8, which are compatible in brighntess.
- Extract rpu from web-dl p8
- convert P7 to P8 with dovi_tool
- inject into converted remux
Is that correct?
Post by RESET_9999 » Tue Jan 07, 2025 3:25 pm
just convert the P7 rip to P8 with workflow 4-1
darrrkmanxxx
Post by darrrkmanxxx » Tue Jan 07, 2025 3:40 pm
RESET_9999 wrote: Tue Jan 07, 2025 3:25 pm just convert the P7 rip to P8 with workflow 4-1
thanks, is this the same as with dovi_tool mode 2 from quietvoid?
Post by RESET_9999 » Tue Jan 07, 2025 3:49 pm
yes, all the workflows rely on dovi_tool.exe ... there's no other way.
fazambuja
Post by fazambuja » Wed Jan 08, 2025 2:18 am
Would it be possible to extract the HDR10plus of lower quality mkv and inject it into its higher quality variant?
File size                                : 23.3 GiB
Duration                                 : 1 h 59 min
Overall bit rate                         : 28.0 Mb/s
Frame rate                               : 23.976 FPS
Movie name                               : Alien Romulus (2024)
Encoded date                             : 2024-12-05 16:14:58 UTC
Writing application                      : mkvmerge v88.0 ('All I Know') 64-bit
Writing library                          : libebml v1.4.5 + libmatroska v1.7.1 / Lavf60.3.100
Cover                                    : Yes
Attachments                              : cover.jpg
Time code of first frame                 : 01:00:00:00
Time code source                         : Matroska tags
Video
HDR format                               : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, no metadata compression, HDR10 compatible / SMPTE ST 2094 App 4, [B]Version HDR10+ Profile A, HDR10+ Profile A[/B] compatible
Bit rate                                 : 25.7 Mb/s
Height                                   : 1 608 pixels
Display aspect ratio                     : 2.39:1
Chroma subsampling                       : 4:2:0
Bits/(Pixel*Frame)                       : 0.173
Stream size                              : 21.4 GiB (92%)
Title                                    : HSaber <-|-> Z@X
Mastering display color primaries        : BT.2020
Maximum Frame-Average Light Level        : 400 cd/m2
File size                                : 53.6 GiB
Overall bit rate                         : 64.5 Mb/s
Movie name                               : Alien: Romulus - Ultra HD™
Encoded date                             : 2024-11-26 14:39:36 UTC
Cover                                    : Yes
Video
ID in the original source medium         : 4113 (0x1011)
HDR format                               : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Bit rate                                 : 54.9 Mb/s
Bits/(Pixel*Frame)                       : 0.276
Stream size                              : 45.6 GiB (85%)
Title                                    : English
Post by RESET_9999 » Wed Jan 08, 2025 11:59 am
Yes, measure both videos if they are the same grade.
dkangel
Post by dkangel » Wed Jan 08, 2025 4:55 pm
RESET_9999 wrote: Fri Dec 27, 2024 2:59 pm
Thanks for explaining. How to interpret those? Is the madvr plot the best, because it has the most dynamics?
If I do the madvr measuremnt, I adjust cmv4.0 when I generate from madvr file with dovi_tool ,e.g.
No, madvr generated metadata (3-2) is the worst and not really suited for DV playback. Also, Madvr scene cut detection is not very good. It's quite sensitive to flashes/explosions/fast movement and can sometimes miss obvious scene cuts. The best dv metadata generation is one of the analysis tunings using Davinci Resolve. I prefer the ''balanced tuning'' which is the dovi_scripts default in workflow 3-1
Hello
in your video you said that we should choose most highlights details in resolve but now i see that you prefer balanced. So what is the best ? :D
Post by RESET_9999 » Wed Jan 08, 2025 5:38 pm
Yeah, when I did the video, I was using tuning 1.
After more tests/comparisons, I now prefer tuning 3 because it's a bit brighter without clipping. Both tunings are good though and tuning 3(balanced) is Resolve default.
dkangel
Post by dkangel » Wed Jan 08, 2025 8:03 pm
ok thank you :)
powdeau
Post by powdeau » Fri Jan 10, 2025 12:22 pm
Does Chroma Weight makes a big difference if it is used only in 100 nits trim?
Post by RESET_9999 » Fri Jan 10, 2025 3:22 pm
powdeau wrote: Fri Jan 10, 2025 12:22 pm Does Chroma Weight makes a big difference if it is used only in 100 nits trim?
yes and it doesn't matter if it's only a 100nits trim because whatever they did in the SDR trim gets extrapolated to any brightness.
thankfully CW is not used very often.
darrrkmanxxx
Post by darrrkmanxxx » Fri Jan 10, 2025 10:48 pm
RESET_9999 wrote: Fri Jan 10, 2025 3:22 pm
so if there are no CW trims (flat line) at 1000nits and my device has 1000nits peak brightness, will it still be tone mapped because of the 100nit trim?
