PM sent.vtedogs wrote: Thu Jan 09, 2025 5:51 pm Is mine flashable ?
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: ..
Firmware date: 2017-06-22
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
Is my pioneer BDR-XD05s flashable?
Re: Is my pioneer BDR-XD05s flashable?
Dear Coopervid, thank you! It worked for the BD-RW BDR-XD05.Coopervid wrote: Wed Jan 08, 2025 11:15 amPM sent.RB2049 wrote: Sat Jan 04, 2025 8:51 pm I was wondering if my drive would also be flashable
Drive informatie
Naam OS-apparaat: \Device\CdRom1
Huidig profiel: BD-R SRM
Fabrikant: PIONEER
Revisie: 3.01
Serienummer: ...
Firmware datum: 2014-12-26
Bus encryptie flags: 1B
Highest AACS version: 77
Drive platform: RS8231
Firmware version: 3.01/ID34
And on a sidenote, I have another Pioneer drive that does not seem to read blu ray's but it might be able to?
That would be the following drive
Drive informatie
Naam OS-apparaat: G:
Fabrikant: PIONEER
Product: BDW-PR1EPDVPP100
Revisie: 1.01
Serienummer: ...
Firmware datum: 2018-03-06
Drive platform: Pioneer RS8680
Firmware version: ID79
Edit:
Ps: apologies for the direct question(s). I haven’t looked here in ages and saw this post and jumped on the opportunity to ask the question.
Greetings all!
The reason I mentioned the BDW-PR1EPDVPP100: apparently it is used to write (normal) Blu ray's in certain rigs, but the reading capability of the drive for the (normal) blu rays would be turned off according to google searches?
On the other hand, when I check the settings of the drive for blu rays then it says R/W "switched on"...? So I would expect it to read or see blu rays but it never does.
It reads DVD's fine.
If you have any suggestions to make the blu ray burner also read blu rays I would be happy to hear them.
Thanks again for the BD-RW BDR-XD05!
AFAIK there is no compatible firmware for your other drive.RB2049 wrote: Sun Jan 12, 2025 3:05 pmDear Coopervid, thank you! It worked for the BD-RW BDR-XD05.Coopervid wrote: Wed Jan 08, 2025 11:15 amPM sent.RB2049 wrote: Sat Jan 04, 2025 8:51 pm I was wondering if my drive would also be flashable
Drive informatie
Fabrikant: PIONEER
Revisie: 3.01
Serienummer: ...
Drive informatie
Fabrikant: PIONEER
Revisie: 1.01
Serienummer: ...
Edit:
Greetings all!
Ok, thanks again for the information and the help!AFAIK there is no compatible firmware for your other drive.
Greetings!
Ok, sorry to come back to this again, but:RB2049 wrote: Tue Jan 14, 2025 9:03 pmOk, thanks again for the information and the help!AFAIK there is no compatible firmware for your other drive.
Greetings!
I read on another forum that the BDW-PR1EPDVPP100 in some cases has the PIONEER BDR-209 firmware.
Is it possible to write that firmware or a similar/compatible firmware to the drive?
Would be gratefull if I could try.
Greetings!
Is my drive flashable?
Revision: 3.01
Serial number: ...
Firmware date: 2014-12-26
Highest AACS version: 50
Thank you in advance.
Revision: 3.01
Serial number: ...
I'm really new to the UHD ripping scene, I tried to load Warcraft UDH bluray and it didn't load, no sure what is going on
PM sent.halodies wrote: Thu Jan 16, 2025 6:52 pm Is my drive flashable?
Revision: 3.01
Serial number: ...
Check your PM.RB2049 wrote: Thu Jan 16, 2025 9:16 amOk, sorry to come back to this again, but:RB2049 wrote: Tue Jan 14, 2025 9:03 pmOk, thanks again for the information and the help!AFAIK there is no compatible firmware for your other drive.
Greetings!
Greetings!
jimmyjam105
Looks like I am potentially in luck here as my device is near exact as many of the others commenting in this thread. I was looking over the "Ultimate UHD Drives Flashing Guide Updated 2025" post just above this, and saw you (Coop) as an author and loads of info there, but then found this fresh chain and wasn't sure if you were supplying the others more targeted/specific information or not via PM. Would you be so kind as to sharing your instruction via PM with me also? TYVM
Revision: 3.01
Serial number: REMOVED
Revision: 3.01
YOU RULECoopervid wrote: Fri Jan 17, 2025 11:18 amPM sent.halodies wrote: Thu Jan 16, 2025 6:52 pm Is my drive flashable?
Revision: 3.01
Serial number: ...
PM sent.jimmyjam105 wrote: Fri Jan 17, 2025 11:05 pm Looks like I am potentially in luck here as my device is near exact as many of the others commenting in this thread. I was looking over the "Ultimate UHD Drives Flashing Guide Updated 2025" post just above this, and saw you (Coop) as an author and loads of info there, but then found this fresh chain and wasn't sure if you were supplying the others more targeted/specific information or not via PM. Would you be so kind as to sharing your instruction via PM with me also? TYVM
Revision: 3.01
nevermindmyname
Revision: 3.10
Highest AACS version: 81
Revision: 3.10
PM sent.nevermindmyname wrote: Sun Jan 19, 2025 3:52 am Is my drive flashable?
Revision: 3.10
Just bought a Used Set of this BDR-XD05 in Piano Gloss Red, as my Verbatim 43888 with a Pioneer UD04 died on me.
Hopefully i can have it Liberated to be UHD spec's too.
Thanks Coopervid.
OS device name: I:
Revision: 1.21
Serial number: ...
Firmware date: 2014-04-02
Highest AACS version: 68
Firmware version: 1.21/ID69
Thanks Coopervid.
OS device name: I:
Revision: 1.21
Serial number: ...
