Hallo Coopervid,
could you please send me the Firmware for the Verbatim 43890 Drive to support UHD discs.
Greatly appreciated
Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
knippinski
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
PM is coming.knippinski wrote: Fri Dec 27, 2024 7:20 pm Hallo Coopervid,
Greatly appreciated
Psyire
Hi Coopervid,
I just picked up one of these drives as well, can you send me the firmware required for UHD?
Thanks bud!
Thanks bud!
PM is coming.Psyire wrote: Wed Jan 08, 2025 2:09 am Hi Coopervid,
Thanks bud!
juanan
HI!
I have the same problem. After several weeks using Verbatim 43890 to play/record Blurays with success,
I´ve just tried to read a UHD disks with this Makemkv result:
Información de unidad de disco
Nombre del SO del dispositivo: H:
Fabricante: PIONEER
Producto: BD-RW BDR-UD03
Revisión: 1.14
Número de serie: BDDLXXXXXXWL
Fecha del firmware: 2020-06-15
Marcas de cifrado bus: 1B
Highest AACS version: 17
Drive platform: RS8511
Firmware version: 1.14
No hay disco insertado (no disk inserted)
SO, would you please help me to flash my drive?
Thanks in advance
Fabricante: PIONEER
Revisión: 1.14
Thanks in advance
PM is coming.juanan wrote: Wed Jan 08, 2025 4:08 pm HI!
Fabricante: PIONEER
Revisión: 1.14
Thanks in advance
Fox_Mulder
Quick question: I'm thinking about buying a burner that can read 4k films. Does the firmware upgrade from BDR-UD03 to BDR-UD04 always work? What are the disadvantages? Or should I just buy a 43888 with
Pioneer BDR-UD04?
Pioneer BDR-UD04?
Yes it works with all drives but if you find a 43888 why bother?Fox_Mulder wrote: Thu Jan 09, 2025 12:08 am Quick question: I'm thinking about buying a burner that can read 4k films. Does the firmware upgrade from BDR-UD03 to BDR-UD04 always work? What are the disadvantages? Or should I just buy a 43888 with
Pioneer BDR-UD04?
zittrig
@Fox_Mulder: But have a good look at the drive before buying if you want a 43888 with Pioneer drive only. Because since recently there are 43888 with LG's BU40N released also.
Fox_Mulder
OK. Thanks for the info.zittrig wrote: Thu Jan 09, 2025 1:40 pm @Fox_Mulder: But have a good look at the drive before buying if you want a 43888 with Pioneer drive only. Because since recently there are 43888 with LG's BU40N released also.
Can you see it on the packaging?
What disadvantage does the LG have compared to the Pioneer?
RobinStn
Hallo Coopervid,
I would appreciated it.
Post your Makemkv info.RobinStn wrote: Thu Jan 09, 2025 9:08 pm Hallo Coopervid,
Fox_Mulder
How much should the firmware cost? I'm trying to decide which is more worthwhile.
zittrig
IMO the BU40N is the best of the LG family so it wouldn't be a mistake to get one.Fox_Mulder wrote: Thu Jan 09, 2025 6:02 pmOK. Thanks for the info.zittrig wrote: Thu Jan 09, 2025 1:40 pm @Fox_Mulder: But have a good look at the drive before buying if you want a 43888 with Pioneer drive only. Because since recently there are 43888 with LG's BU40N released also.
Marty explained some optical differences here ..
viewtopic.php?f=19&t=36199#top
RobinStn
Drive informatie
Naam OS-apparaat: E:
Fabrikant: PIONEER
Product: BD-RW BDR-UD03
Revisie: 1.14
Serienummer: ...
Firmware datum: 2020-06-15
Bus encryptie flags: 1B
