Se7en steelbook Bluray causes hanging
cpitchford
Post by cpitchford » Thu Jan 09, 2025 4:05 pm
I'm using the command line tool to rip discs and this afternoon I've found a new disc is causing makemkvcon to hang during and "info" request:
`makemkvcon info -r dev:/dev/sr0 --noscan`
As the command runs, it outputs a normal log of information. After it starts outputting the second title, the command and the output hangs. The drive then spins down (idles).
I can CTRL+C to stop the command, but it does stop by itself (as it normally would)
This is the first time I've had makemkvcon hang with an idle drive
Here's what I'm seeing:
MSG:1005,0,1,"MakeMKV v1.17.8 linux(x64-release) started","%1 started","MakeMKV v1.17.8 linux(x64-release)"
DRV:0,0,999,0,"BD-RE HL-DT-ST BD-RE BU40N 1.04 MO4M14B1836","","/dev/sr0"
DRV:1,256,999,0,"","",""
DRV:2,256,999,0,"","",""
DRV:3,256,999,0,"","",""
DRV:4,256,999,0,"","",""
DRV:5,256,999,0,"","",""
DRV:6,256,999,0,"","",""
DRV:7,256,999,0,"","",""
DRV:8,256,999,0,"","",""
DRV:9,256,999,0,"","",""
DRV:10,256,999,0,"","",""
DRV:11,256,999,0,"","",""
DRV:12,256,999,0,"","",""
DRV:13,256,999,0,"","",""
DRV:14,256,999,0,"","",""
DRV:15,256,999,0,"","",""
MSG:1011,0,1,"Using LibreDrive mode (v06.3 id=FA108BB7DA63)","%1","Using LibreDrive mode (v06.3 id=FA108BB7DA63)"
MSG:3007,0,0,"Using direct disc access mode","Using direct disc access mode"
MSG:5085,0,0,"Loaded content hash table, will verify integrity of M2TS files.","Loaded content hash table, will verify integrity of M2TS files."
MSG:3025,16777216,3,"Title #00127.m2ts has length of 10 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00127.m2ts","10","4000"
MSG:3025,16777216,3,"Title #00073.m2ts has length of 536 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00073.m2ts","536","4000"
MSG:3025,16777216,3,"Title #00089.m2ts has length of 866 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00089.m2ts","866","4000"
MSG:3025,16777216,3,"Title #00090.m2ts has length of 148 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00090.m2ts","148","4000"
MSG:3025,16777216,3,"Title #00091.m2ts has length of 338 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00091.m2ts","338","4000"
MSG:3025,16777216,3,"Title #00092.m2ts has length of 647 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00092.m2ts","647","4000"
MSG:3025,16777216,3,"Title #00093.m2ts has length of 497 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00093.m2ts","497","4000"
MSG:3025,16777216,3,"Title #00095.m2ts has length of 457 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00095.m2ts","457","4000"
MSG:3025,16777216,3,"Title #00096.m2ts has length of 91 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00096.m2ts","91","4000"
MSG:3025,16777216,3,"Title #00097.m2ts has length of 78 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00097.m2ts","78","4000"
MSG:3025,16777216,3,"Title #00098.m2ts has length of 23 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00098.m2ts","23","4000"
MSG:3025,16777216,3,"Title #00099.m2ts has length of 140 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00099.m2ts","140","4000"
MSG:3025,16777216,3,"Title #00100.m2ts has length of 58 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00100.m2ts","58","4000"
MSG:3025,16777216,3,"Title #00101.m2ts has length of 236 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00101.m2ts","236","4000"
MSG:3025,16777216,3,"Title #00102.m2ts has length of 74 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00102.m2ts","74","4000"
MSG:3025,16777216,3,"Title #00104.m2ts has length of 328 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00104.m2ts","328","4000"
MSG:3025,16777216,3,"Title #00107.m2ts has length of 400 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00107.m2ts","400","4000"
MSG:3025,16777216,3,"Title #00108.m2ts has length of 539 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00108.m2ts","539","4000"
MSG:3025,16777216,3,"Title #00110.m2ts has length of 859 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00110.m2ts","859","4000"
MSG:3025,16777216,3,"Title #00112.m2ts has length of 148 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00112.m2ts","148","4000"
MSG:3025,0,3,"Title #00128.m2ts has length of 447 seconds which is less than minimum title length of 4000 seconds and was therefore skipped","Title #%1 has length of %2 seconds which is less than minimum title length of %3 seconds and was therefore skipped","00128.m2ts","447","4000"
MSG:5011,0,0,"Operation successfully completed","Operation successfully completed"
TCOUNT:2
CINFO:1,6209,"Blu-ray disc"
CINFO:2,0,"SE7EN"
CINFO:28,0,"eng"
CINFO:29,0,"English"
CINFO:30,0,"SE7EN"
CINFO:31,6119,"<b>Source information</b><br>"
CINFO:32,0,"SE7EN"
CINFO:33,0,"0"
TINFO:0,2,0,"SE7EN"
TINFO:0,8,0,"37"
TINFO:0,9,0,"2:06:49"
TINFO:0,10,0,"34.1 GB"
TINFO:0,11,0,"36690302976"
TINFO:0,16,0,"00100.mpls"
TINFO:0,25,0,"1"
TINFO:0,26,0,"20"
TINFO:0,27,0,"SE7EN_t00.mkv"
TINFO:0,28,0,"eng"
TINFO:0,29,0,"English"
TINFO:0,30,0,"SE7EN - 37 chapter(s) , 34.1 GB"
TINFO:0,31,6120,"<b>Title information</b><br>"
TINFO:0,33,0,"0"
SINFO:0,0,1,6201,"Video"
SINFO:0,0,5,0,"V_VC1"
SINFO:0,0,6,0,"VC-1"
SINFO:0,0,7,0,"VC-1"
SINFO:0,0,19,0,"1920x1080"
SINFO:0,0,20,0,"16:9"
SINFO:0,0,21,0,"23.976 (24000/1001)"
SINFO:0,0,22,0,"0"
SINFO:0,0,28,0,"eng"
SINFO:0,0,29,0,"English"
SINFO:0,0,30,0,"VC-1"
SINFO:0,0,31,6121,"<b>Track information</b><br>"
SINFO:0,0,33,0,"0"
SINFO:0,0,38,0,""
SINFO:0,0,42,5088,"( Lossless conversion )"
SINFO:0,1,1,6202,"Audio"
SINFO:0,1,2,0,"Surround 7.1"
SINFO:0,1,3,0,"eng"
SINFO:0,1,4,0,"English"
SINFO:0,1,5,0,"A_DTS"
SINFO:0,1,6,0,"DTS-HD MA"
SINFO:0,1,7,0,"DTS-HD Master Audio"
SINFO:0,1,14,0,"8"
SINFO:0,1,17,0,"48000"
SINFO:0,1,18,0,"24"
SINFO:0,1,22,0,"1024"
SINFO:0,1,28,0,"eng"
SINFO:0,1,29,0,"English"
SINFO:0,1,30,0,"DTS-HD MA Surround 7.1 English"
SINFO:0,1,31,6121,"<b>Track information</b><br>"
SINFO:0,1,33,0,"90"
SINFO:0,1,38,0,""
SINFO:0,1,40,0,"7.1"
SINFO:0,1,42,5088,"( Lossless conversion )"
SINFO:0,2,1,6202,"Audio"
SINFO:0,2,2,0,"Surround 5.1"
SINFO:0,2,3,0,"eng"
SINFO:0,2,4,0,"English"
SINFO:0,2,5,0,"A_DTS"
SINFO:0,2,6,0,"DTS"
SINFO:0,2,7,0,"DTS"
SINFO:0,2,13,0,"1.5 Mb/s"
SINFO:0,2,14,0,"6"
SINFO:0,2,17,0,"48000"
SINFO:0,2,22,0,"2304"
SINFO:0,2,28,0,"eng"
SINFO:0,2,29,0,"English"
SINFO:0,2,30,0,"DTS Surround 5.1 English"
SINFO:0,2,31,6121,"<b>Track information</b><br>"
SINFO:0,2,33,0,"90"
SINFO:0,2,38,0,"d"
SINFO:0,2,39,0,"Default"
SINFO:0,2,40,0,"5.1(side)"
SINFO:0,2,42,5088,"( Lossless conversion )"
SINFO:0,3,1,6202,"Audio"
SINFO:0,3,2,0,"Surround 5.1"
SINFO:0,3,3,0,"deu"
SINFO:0,3,4,0,"German"
SINFO:0,3,5,0,"A_AC3"
SINFO:0,3,6,0,"DD"
SINFO:0,3,7,0,"Dolby Digital"
SINFO:0,3,13,0,"640 Kb/s"
SINFO:0,3,14,0,"6"
SINFO:0,3,17,0,"48000"
SINFO:0,3,22,0,"0"
SINFO:0,3,28,0,"eng"
SINFO:0,3,29,0,"English"
SINFO:0,3,30,0,"DD Surround 5.1 German"
SINFO:0,3,31,6121,"<b>Track information</b><br>"
SINFO:0,3,33,0,"100"
SINFO:0,3,38,0,""
SINFO:0,3,40,0,"5.1(side)"
SINFO:0,3,42,5088,"( Lossless conversion )"
SINFO:0,4,1,6202,"Audio"
SINFO:0,4,2,0,"Surround 5.1"
SINFO:0,4,3,0,"spa"
SINFO:0,4,4,0,"Spanish"
SINFO:0,4,5,0,"A_AC3"
SINFO:0,4,6,0,"DD"
SINFO:0,4,7,0,"Dolby Digital"
SINFO:0,4,13,0,"640 Kb/s"
SINFO:0,4,14,0,"6"
SINFO:0,4,17,0,"48000"
SINFO:0,4,22,0,"0"
SINFO:0,4,28,0,"eng"
SINFO:0,4,29,0,"English"
SINFO:0,4,30,0,"DD Surround 5.1 Spanish"
SINFO:0,4,31,6121,"<b>Track information</b><br>"
SINFO:0,4,33,0,"100"
SINFO:0,4,38,0,""
SINFO:0,4,40,0,"5.1(side)"
SINFO:0,4,42,5088,"( Lossless conversion )"
SINFO:0,5,1,6202,"Audio"
SINFO:0,5,2,5091,"Stereo"
SINFO:0,5,3,0,"spa"
SINFO:0,5,4,0,"Spanish"
SINFO:0,5,5,0,"A_AC3"
SINFO:0,5,6,0,"DD"
SINFO:0,5,7,0,"Dolby Digital"
SINFO:0,5,13,0,"192 Kb/s"
SINFO:0,5,14,0,"2"
SINFO:0,5,17,0,"48000"
SINFO:0,5,22,0,"0"
SINFO:0,5,28,0,"eng"
SINFO:0,5,29,0,"English"
SINFO:0,5,30,0,"DD Stereo Spanish"
SINFO:0,5,31,6121,"<b>Track information</b><br>"
SINFO:0,5,33,0,"100"
SINFO:0,5,38,0,""
SINFO:0,5,40,0,"stereo"
SINFO:0,5,42,5088,"( Lossless conversion )"
SINFO:0,6,1,6202,"Audio"
SINFO:0,6,2,5091,"Stereo"
SINFO:0,6,3,0,"por"
SINFO:0,6,4,0,"Portuguese"
SINFO:0,6,5,0,"A_AC3"
SINFO:0,6,6,0,"DD"
SINFO:0,6,7,0,"Dolby Digital"
SINFO:0,6,13,0,"192 Kb/s"
SINFO:0,6,14,0,"2"
SINFO:0,6,17,0,"48000"
SINFO:0,6,22,0,"0"
SINFO:0,6,28,0,"eng"
SINFO:0,6,29,0,"English"
SINFO:0,6,30,0,"DD Stereo Portuguese"
SINFO:0,6,31,6121,"<b>Track information</b><br>"
SINFO:0,6,33,0,"100"
SINFO:0,6,38,0,""
SINFO:0,6,40,0,"stereo"
SINFO:0,6,42,5088,"( Lossless conversion )"
SINFO:0,7,1,6202,"Audio"
SINFO:0,7,2,0,"Surround 5.1"
SINFO:0,7,3,0,"tha"
SINFO:0,7,4,0,"Thai"
SINFO:0,7,5,0,"A_AC3"
SINFO:0,7,6,0,"DD"
SINFO:0,7,7,0,"Dolby Digital"
SINFO:0,7,13,0,"640 Kb/s"
SINFO:0,7,14,0,"6"
SINFO:0,7,17,0,"48000"
SINFO:0,7,22,0,"0"
SINFO:0,7,28,0,"eng"
SINFO:0,7,29,0,"English"
SINFO:0,7,30,0,"DD Surround 5.1 Thai"
SINFO:0,7,31,6121,"<b>Track information</b><br>"
SINFO:0,7,33,0,"100"
SINFO:0,7,38,0,""
SINFO:0,7,40,0,"5.1(side)"
SINFO:0,7,42,5088,"( Lossless conversion )"
SINFO:0,8,1,6202,"Audio"
SINFO:0,8,2,5091,"Stereo"
SINFO:0,8,3,0,"eng"
SINFO:0,8,4,0,"English"
SINFO:0,8,5,0,"A_AC3"
SINFO:0,8,6,0,"DD"
SINFO:0,8,7,0,"Dolby Digital"
SINFO:0,8,13,0,"192 Kb/s"
SINFO:0,8,14,0,"2"
SINFO:0,8,17,0,"48000"
SINFO:0,8,22,0,"0"
SINFO:0,8,28,0,"eng"
SINFO:0,8,29,0,"English"
SINFO:0,8,30,0,"DD Stereo English"
SINFO:0,8,31,6121,"<b>Track information</b><br>"
SINFO:0,8,33,0,"90"
SINFO:0,8,38,0,""
SINFO:0,8,40,0,"stereo"
SINFO:0,8,42,5088,"( Lossless conversion )"
SINFO:0,9,1,6202,"Audio"
SINFO:0,9,2,5091,"Stereo"
SINFO:0,9,3,0,"eng"
SINFO:0,9,4,0,"English"
SINFO:0,9,5,0,"A_AC3"
SINFO:0,9,6,0,"DD"
SINFO:0,9,7,0,"Dolby Digital"
SINFO:0,9,13,0,"192 Kb/s"
SINFO:0,9,14,0,"2"
SINFO:0,9,17,0,"48000"
SINFO:0,9,22,0,"0"
SINFO:0,9,28,0,"eng"
SINFO:0,9,29,0,"English"
SINFO:0,9,30,0,"DD Stereo English"
SINFO:0,9,31,6121,"<b>Track information</b><br>"
SINFO:0,9,33,0,"90"
SINFO:0,9,38,0,""
SINFO:0,9,40,0,"stereo"
SINFO:0,9,42,5088,"( Lossless conversion )"
SINFO:0,10,1,6202,"Audio"
SINFO:0,10,2,5091,"Stereo"
SINFO:0,10,3,0,"eng"
SINFO:0,10,4,0,"English"
SINFO:0,10,5,0,"A_AC3"
SINFO:0,10,6,0,"DD"
SINFO:0,10,7,0,"Dolby Digital"
SINFO:0,10,13,0,"192 Kb/s"
SINFO:0,10,14,0,"2"
SINFO:0,10,17,0,"48000"
SINFO:0,10,22,0,"0"
SINFO:0,10,28,0,"eng"
SINFO:0,10,29,0,"English"
SINFO:0,10,30,0,"DD Stereo English"
SINFO:0,10,31,6121,"<b>Track information</b><br>"
SINFO:0,10,33,0,"90"
SINFO:0,10,38,0,""
SINFO:0,10,40,0,"stereo"
SINFO:0,10,42,5088,"( Lossless conversion )"
SINFO:0,11,1,6202,"Audio"
SINFO:0,11,2,0,"Surround 5.1"
SINFO:0,11,3,0,"eng"
SINFO:0,11,4,0,"English"
SINFO:0,11,5,0,"A_AC3"
SINFO:0,11,6,0,"DD"
SINFO:0,11,7,0,"Dolby Digital"
SINFO:0,11,13,0,"640 Kb/s"
SINFO:0,11,14,0,"6"
SINFO:0,11,17,0,"48000"
SINFO:0,11,22,0,"0"
SINFO:0,11,28,0,"eng"
SINFO:0,11,29,0,"English"
SINFO:0,11,30,0,"DD Surround 5.1 English"
SINFO:0,11,31,6121,"<b>Track information</b><br>"
SINFO:0,11,33,0,"90"
SINFO:0,11,38,0,""
SINFO:0,11,40,0,"5.1(side)"
SINFO:0,11,42,5088,"( Lossless conversion )"
SINFO:0,12,1,6203,"Subtitles"
SINFO:0,12,3,0,"eng"
SINFO:0,12,4,0,"English"
SINFO:0,12,5,0,"S_HDMV/PGS"
SINFO:0,12,6,0,"PGS"
SINFO:0,12,7,0,"HDMV PGS Subtitles"
SINFO:0,12,22,0,"0"
SINFO:0,12,28,0,"eng"
SINFO:0,12,29,0,"English"
SINFO:0,12,30,0,"PGS English"
SINFO:0,12,31,6121,"<b>Track information</b><br>"
SINFO:0,12,33,0,"90"
SINFO:0,12,38,0,""
SINFO:0,12,42,5088,"( Lossless conversion )"
SINFO:0,13,1,6203,"Subtitles"
SINFO:0,13,3,0,"eng"
SINFO:0,13,4,0,"English"
SINFO:0,13,5,0,"S_HDMV/PGS"
SINFO:0,13,6,0,"PGS"
SINFO:0,13,7,0,"HDMV PGS Subtitles"
SINFO:0,13,22,0,"6144"
SINFO:0,13,28,0,"eng"
SINFO:0,13,29,0,"English"
SINFO:0,13,30,0,"PGS English  (forced only)"
SINFO:0,13,31,6121,"<b>Track information</b><br>"
SINFO:0,13,33,0,"90"
SINFO:0,13,38,0,"d"
SINFO:0,13,39,0,"Default"
SINFO:0,13,42,5088,"( Lossless conversion )"
SINFO:0,14,1,6203,"Subtitles"
SINFO:0,14,3,0,"deu"
SINFO:0,14,4,0,"German"
SINFO:0,14,5,0,"S_HDMV/PGS"
SINFO:0,14,6,0,"PGS"
SINFO:0,14,7,0,"HDMV PGS Subtitles"
SINFO:0,14,22,0,"0"
SINFO:0,14,28,0,"eng"
SINFO:0,14,29,0,"English"
SINFO:0,14,30,0,"PGS German"
SINFO:0,14,31,6121,"<b>Track information</b><br>"
SINFO:0,14,33,0,"100"
SINFO:0,14,38,0,""
SINFO:0,14,42,5088,"( Lossless conversion )"
SINFO:0,15,1,6203,"Subtitles"
SINFO:0,15,3,0,"deu"
SINFO:0,15,4,0,"German"
SINFO:0,15,5,0,"S_HDMV/PGS"
SINFO:0,15,6,0,"PGS"
SINFO:0,15,7,0,"HDMV PGS Subtitles"
SINFO:0,15,22,0,"6144"
SINFO:0,15,28,0,"eng"
SINFO:0,15,29,0,"English"
SINFO:0,15,30,0,"PGS German  (forced only)"
SINFO:0,15,31,6121,"<b>Track information</b><br>"
SINFO:0,15,33,0,"100"
SINFO:0,15,38,0,""
SINFO:0,15,42,5088,"( Lossless conversion )"
SINFO:0,16,1,6203,"Subtitles"
SINFO:0,16,3,0,"spa"
SINFO:0,16,4,0,"Spanish"
SINFO:0,16,5,0,"S_HDMV/PGS"
SINFO:0,16,6,0,"PGS"
SINFO:0,16,7,0,"HDMV PGS Subtitles"
SINFO:0,16,22,0,"0"
SINFO:0,16,28,0,"eng"
SINFO:0,16,29,0,"English"
SINFO:0,16,30,0,"PGS Spanish"
SINFO:0,16,31,6121,"<b>Track information</b><br>"
SINFO:0,16,33,0,"100"
SINFO:0,16,38,0,""
SINFO:0,16,42,5088,"( Lossless conversion )"
SINFO:0,17,1,6203,"Subtitles"
SINFO:0,17,3,0,"spa"
SINFO:0,17,4,0,"Spanish"
SINFO:0,17,5,0,"S_HDMV/PGS"
SINFO:0,17,6,0,"PGS"
SINFO:0,17,7,0,"HDMV PGS Subtitles"
SINFO:0,17,22,0,"6144"
SINFO:0,17,28,0,"eng"
SINFO:0,17,29,0,"English"
SINFO:0,17,30,0,"PGS Spanish  (forced only)"
SINFO:0,17,31,6121,"<b>Track information</b><br>"
SINFO:0,17,33,0,"100"
SINFO:0,17,38,0,""
SINFO:0,17,42,5088,"( Lossless conversion )"
SINFO:0,18,1,6203,"Subtitles"
SINFO:0,18,3,0,"zho"
SINFO:0,18,4,0,"Chinese"
SINFO:0,18,5,0,"S_HDMV/PGS"
SINFO:0,18,6,0,"PGS"
SINFO:0,18,7,0,"HDMV PGS Subtitles"
SINFO:0,18,22,0,"0"
SINFO:0,18,28,0,"eng"
SINFO:0,18,29,0,"English"
SINFO:0,18,30,0,"PGS Chinese"
SINFO:0,18,31,6121,"<b>Track information</b><br>"
SINFO:0,18,33,0,"100"
SINFO:0,18,38,0,""
SINFO:0,18,42,5088,"( Lossless conversion )"
SINFO:0,19,1,6203,"Subtitles"
SINFO:0,19,3,0,"zho"
SINFO:0,19,4,0,"Chinese"
SINFO:0,19,5,0,"S_HDMV/PGS"
SINFO:0,19,6,0,"PGS"
SINFO:0,19,7,0,"HDMV PGS Subtitles"
SINFO:0,19,22,0,"6144"
SINFO:0,19,28,0,"eng"
SINFO:0,19,29,0,"English"
SINFO:0,19,30,0,"PGS Chinese  (forced only)"
SINFO:0,19,31,6121,"<b>Track information</b><br>"
SINFO:0,19,33,0,"100"
SINFO:0,19,38,0,""
SINFO:0,19,42,5088,"( Lossless conversion )"
SINFO:0,20,1,6203,"Subtitles"
SINFO:0,20,3,0,"kor"
SINFO:0,20,4,0,"Korean"
SINFO:0,20,5,0,"S_HDMV/PGS"
SINFO:0,20,6,0,"PGS"
SINFO:0,20,7,0,"HDMV PGS Subtitles"
SINFO:0,20,22,0,"0"
SINFO:0,20,28,0,"eng"
SINFO:0,20,29,0,"English"
SINFO:0,20,30,0,"PGS Korean"
SINFO:0,20,31,6121,"<b>Track information</b><br>"
SINFO:0,20,33,0,"100"
SINFO:0,20,38,0,""
SINFO:0,20,42,5088,"( Lossless conversion )"
SINFO:0,21,1,6203,"Subtitles"
SINFO:0,21,3,0,"kor"
SINFO:0,21,4,0,"Korean"
SINFO:0,21,5,0,"S_HDMV/PGS"
SINFO:0,21,6,0,"PGS"
SINFO:0,21,7,0,"HDMV PGS Subtitles"
SINFO:0,21,22,0,"6144"
SINFO:0,21,28,0,"eng"
SINFO:0,21,29,0,"English"
SINFO:0,21,30,0,"PGS Korean  (forced only)"
SINFO:0,21,31,6121,"<b>Track information</b><br>"
SINFO:0,21,33,0,"100"
SINFO:0,21,38,0,""
SINFO:0,21,42,5088,"( Lossless conversion )"
SINFO:0,22,1,6203,"Subtitles"
SINFO:0,22,3,0,"spa"
SINFO:0,22,4,0,"Spanish"
SINFO:0,22,5,0,"S_HDMV/PGS"
SINFO:0,22,6,0,"PGS"
SINFO:0,22,7,0,"HDMV PGS Subtitles"
SINFO:0,22,22,0,"0"
SINFO:0,22,28,0,"eng"
SINFO:0,22,29,0,"English"
SINFO:0,22,30,0,"PGS Spanish"
SINFO:0,22,31,6121,"<b>Track information</b><br>"
SINFO:0,22,33,0,"100"
SINFO:0,22,38,0,""
SINFO:0,22,42,5088,"( Lossless conversion )"
SINFO:0,23,1,6203,"Subtitles"
SINFO:0,23,3,0,"spa"
SINFO:0,23,4,0,"Spanish"
SINFO:0,23,5,0,"S_HDMV/PGS"
SINFO:0,23,6,0,"PGS"
SINFO:0,23,7,0,"HDMV PGS Subtitles"
SINFO:0,23,22,0,"6144"
SINFO:0,23,28,0,"eng"
SINFO:0,23,29,0,"English"
SINFO:0,23,30,0,"PGS Spanish  (forced only)"
SINFO:0,23,31,6121,"<b>Track information</b><br>"
SINFO:0,23,33,0,"100"
SINFO:0,23,38,0,""
SINFO:0,23,42,5088,"( Lossless conversion )"
SINFO:0,24,1,6203,"Subtitles"
SINFO:0,24,3,0,"por"
SINFO:0,24,4,0,"Portuguese"
SINFO:0,24,5,0,"S_HDMV/PGS"
SINFO:0,24,6,0,"PGS"
SINFO:0,24,7,0,"HDMV PGS Subtitles"
SINFO:0,24,22,0,"0"
SINFO:0,24,28,0,"eng"
SINFO:0,24,29,0,"English"
SINFO:0,24,30,0,"PGS Portuguese"
SINFO:0,24,31,6121,"<b>Track information</b><br>"
SINFO:0,24,33,0,"100"
SINFO:0,24,38,0,""
SINFO:0,24,42,5088,"( Lossless conversion )"
SINFO:0,25,1,6203,"Subtitles"
SINFO:0,25,3,0,"por"
SINFO:0,25,4,0,"Portuguese"
SINFO:0,25,5,0,"S_HDMV/PGS"
SINFO:0,25,6,0,"PGS"
SINFO:0,25,7,0,"HDMV PGS Subtitles"
SINFO:0,25,22,0,"6144"
SINFO:0,25,28,0,"eng"
SINFO:0,25,29,0,"English"
SINFO:0,25,30,0,"PGS Portuguese  (forced only)"
SINFO:0,25,31,6121,"<b>Track information</b><br>"
SINFO:0,25,33,0,"100"
SINFO:0,25,38,0,""
SINFO:0,25,42,5088,"( Lossless conversion )"
SINFO:0,26,1,6203,"Subtitles"
SINFO:0,26,3,0,"ell"
SINFO:0,26,4,0,"Greek, Moder"
SINFO:0,26,5,0,"S_HDMV/PGS"
SINFO:0,26,6,0,"PGS"
SINFO:0,26,7,0,"HDMV PGS Subtitles"
SINFO:0,26,22,0,"0"
SINFO:0,26,28,0,"eng"
SINFO:0,26,29,0,"English"
SINFO:0,26,30,0,"PGS Greek, Moder"
SINFO:0,26,31,6121,"<b>Track information</b><br>"
SINFO:0,26,33,0,"100"
SINFO:0,26,38,0,""
SINFO:0,26,42,5088,"( Lossless conversion )"
SINFO:0,27,1,6203,"Subtitles"
SINFO:0,27,3,0,"ell"
SINFO:0,27,4,0,"Greek, Moder"
SINFO:0,27,5,0,"S_HDMV/PGS"
SINFO:0,27,6,0,"PGS"
SINFO:0,27,7,0,"HDMV PGS Subtitles"
SINFO:0,27,22,0,"6144"
SINFO:0,27,28,0,"eng"
SINFO:0,27,29,0,"English"
SINFO:0,27,30,0,"PGS Greek, Moder  (forced only)"
SINFO:0,27,31,6121,"<b>Track information</b><br>"
SINFO:0,27,33,0,"100"
SINFO:0,27,38,0,""
SINFO:0,27,42,5088,"( Lossless conversion )"
SINFO:0,28,1,6203,"Subtitles"
SINFO:0,28,3,0,"heb"
SINFO:0,28,4,0,"Hebrew"
SINFO:0,28,5,0,"S_HDMV/PGS"
SINFO:0,28,6,0,"PGS"
SINFO:0,28,7,0,"HDMV PGS Subtitles"
SINFO:0,28,22,0,"0"
SINFO:0,28,28,0,"eng"
SINFO:0,28,29,0,"English"
SINFO:0,28,30,0,"PGS Hebrew"
SINFO:0,28,31,6121,"<b>Track information</b><br>"
SINFO:0,28,33,0,"100"
SINFO:0,28,38,0,""
SINFO:0,28,42,5088,"( Lossless conversion )"
SINFO:0,29,1,6203,"Subtitles"
SINFO:0,29,3,0,"heb"
SINFO:0,29,4,0,"Hebrew"
SINFO:0,29,5,0,"S_HDMV/PGS"
SINFO:0,29,6,0,"PGS"
SINFO:0,29,7,0,"HDMV PGS Subtitles"
SINFO:0,29,22,0,"6144"
SINFO:0,29,28,0,"eng"
SINFO:0,29,29,0,"English"
SINFO:0,29,30,0,"PGS Hebrew  (forced only)"
SINFO:0,29,31,6121,"<b>Track information</b><br>"
SINFO:0,29,33,0,"100"
SINFO:0,29,38,0,""
SINFO:0,29,42,5088,"( Lossless conversion )"
SINFO:0,30,1,6203,"Subtitles"
SINFO:0,30,3,0,"tha"
SINFO:0,30,4,0,"Thai"
SINFO:0,30,5,0,"S_HDMV/PGS"
SINFO:0,30,6,0,"PGS"
SINFO:0,30,7,0,"HDMV PGS Subtitles"
SINFO:0,30,22,0,"0"
SINFO:0,30,28,0,"eng"
SINFO:0,30,29,0,"English"
SINFO:0,30,30,0,"PGS Thai"
SINFO:0,30,31,6121,"<b>Track information</b><br>"
SINFO:0,30,33,0,"100"
SINFO:0,30,38,0,""
SINFO:0,30,42,5088,"( Lossless conversion )"
SINFO:0,31,1,6203,"Subtitles"
SINFO:0,31,3,0,"tha"
SINFO:0,31,4,0,"Thai"
SINFO:0,31,5,0,"S_HDMV/PGS"
SINFO:0,31,6,0,"PGS"
SINFO:0,31,7,0,"HDMV PGS Subtitles"
SINFO:0,31,22,0,"6144"
SINFO:0,31,28,0,"eng"
SINFO:0,31,29,0,"English"
SINFO:0,31,30,0,"PGS Thai  (forced only)"
SINFO:0,31,31,6121,"<b>Track information</b><br>"
SINFO:0,31,33,0,"100"
SINFO:0,31,38,0,""
SINFO:0,31,42,5088,"( Lossless conversion )"
SINFO:0,32,1,6203,"Subtitles"
SINFO:0,32,3,0,"tur"
SINFO:0,32,4,0,"Turkish"
SINFO:0,32,5,0,"S_HDMV/PGS"
SINFO:0,32,6,0,"PGS"
SINFO:0,32,7,0,"HDMV PGS Subtitles"
SINFO:0,32,22,0,"0"
SINFO:0,32,28,0,"eng"
SINFO:0,32,29,0,"English"
SINFO:0,32,30,0,"PGS Turkish"
SINFO:0,32,31,6121,"<b>Track information</b><br>"
SINFO:0,32,33,0,"100"
SINFO:0,32,38,0,""
SINFO:0,32,42,5088,"( Lossless conversion )"
SINFO:0,33,1,6203,"Subtitles"
SINFO:0,33,3,0,"tur"
SINFO:0,33,4,0,"Turkish"
SINFO:0,33,5,0,"S_HDMV/PGS"
SINFO:0,33,6,0,"PGS"
SINFO:0,33,7,0,"HDMV PGS Subtitles"
SINFO:0,33,22,0,"6144"
SINFO:0,33,28,0,"eng"
SINFO:0,33,29,0,"English"
SINFO:0,33,30,0,"PGS Turkish  (forced only)"
SINFO:0,33,31,6121,"<b>Track information</b><br>"
SINFO:0,33,33,0,"100"
SINFO:0,33,38,0,""
SINFO:0,33,42,5088,"( Lossless conversion )"
SINFO:0,34,1,6203,"Subtitles"
SINFO:0,34,3,0,"zho"
SINFO:0,34,4,0,"Chinese"
SINFO:0,34,5,0,"S_HDMV/PGS"
SINFO:0,34,6,0,"PGS"
SINFO:0,34,7,0,"HDMV PGS Subtitles"
SINFO:0,34,22,0,"0"
SINFO:0,34,28,0,"eng"
SINFO:0,34,29,0,"English"
SINFO:0,34,30,0,"PGS Chinese"
SINFO:0,34,31,6121,"<b>Track information</b><br>"
SINFO:0,34,33,0,"100"
SINFO:0,34,38,0,""
SINFO:0,34,42,5088,"( Lossless conversion )"
SINFO:0,35,1,6203,"Subtitles"
SINFO:0,35,3,0,"zho"
SINFO:0,35,4,0,"Chinese"
SINFO:0,35,5,0,"S_HDMV/PGS"
SINFO:0,35,6,0,"PGS"
SINFO:0,35,7,0,"HDMV PGS Subtitles"
SINFO:0,35,22,0,"6144"
SINFO:0,35,28,0,"eng"
SINFO:0,35,29,0,"English"
SINFO:0,35,30,0,"PGS Chinese  (forced only)"
SINFO:0,35,31,6121,"<b>Track information</b><br>"
SINFO:0,35,33,0,"100"
SINFO:0,35,38,0,""
SINFO:0,35,42,5088,"( Lossless conversion )"
SINFO:0,36,1,6203,"Subtitles"
SINFO:0,36,3,0,"kor"
SINFO:0,36,4,0,"Korean"
SINFO:0,36,5,0,"S_HDMV/PGS"
SINFO:0,36,6,0,"PGS"
SINFO:0,36,7,0,"HDMV PGS Subtitles"
SINFO:0,36,22,0,"0"
SINFO:0,36,28,0,"eng"
SINFO:0,36,29,0,"English"
SINFO:0,36,30,0,"PGS Korean"
SINFO:0,36,31,6121,"<b>Track information</b><br>"
SINFO:0,36,33,0,"100"
SINFO:0,36,38,0,""
SINFO:0,36,42,5088,"( Lossless conversion )"
SINFO:0,37,1,6203,"Subtitles"
SINFO:0,37,3,0,"kor"
SINFO:0,37,4,0,"Korean"
SINFO:0,37,5,0,"S_HDMV/PGS"
SINFO:0,37,6,0,"PGS"
SINFO:0,37,7,0,"HDMV PGS Subtitles"
SINFO:0,37,22,0,"6144"
SINFO:0,37,28,0,"eng"
SINFO:0,37,29,0,"English"
SINFO:0,37,30,0,"PGS Korean  (forced only)"
SINFO:0,37,31,6121,"<b>Track information</b><br>"
SINFO:0,37,33,0,"100"
SINFO:0,37,38,0,""
SINFO:0,37,42,5088,"( Lossless conversion )"
SINFO:0,38,1,6203,"Subtitles"
SINFO:0,38,3,0,"zho"
SINFO:0,38,4,0,"Chinese"
SINFO:0,38,5,0,"S_HDMV/PGS"
SINFO:0,38,6,0,"PGS"
SINFO:0,38,7,0,"HDMV PGS Subtitles"
SINFO:0,38,22,0,"0"
SINFO:0,38,28,0,"eng"
SINFO:0,38,29,0,"English"
SINFO:0,38,30,0,"PGS Chinese"
SINFO:0,38,31,6121,"<b>Track information</b><br>"
SINFO:0,38,33,0,"100"
SINFO:0,38,38,0,""
SINFO:0,38,42,5088,"( Lossless conversion )"
SINFO:0,39,1,6203,"Subtitles"
SINFO:0,39,3,0,"zho"
SINFO:0,39,4,0,"Chinese"
SINFO:0,39,5,0,"S_HDMV/PGS"
SINFO:0,39,6,0,"PGS"
SINFO:0,39,7,0,"HDMV PGS Subtitles"
SINFO:0,39,22,0,"6144"
SINFO:0,39,28,0,"eng"
SINFO:0,39,29,0,"English"
SINFO:0,39,30,0,"PGS Chinese  (forced only)"
SINFO:0,39,31,6121,"<b>Track information</b><br>"
SINFO:0,39,33,0,"100"
SINFO:0,39,38,0,""
SINFO:0,39,42,5088,"( Lossless conversion )"
SINFO:0,40,1,6203,"Subtitles"
SINFO:0,40,3,0,"kor"
SINFO:0,40,4,0,"Korean"
SINFO:0,40,5,0,"S_HDMV/PGS"
SINFO:0,40,6,0,"PGS"
SINFO:0,40,7,0,"HDMV PGS Subtitles"
SINFO:0,40,22,0,"0"
SINFO:0,40,28,0,"eng"
SINFO:0,40,29,0,"English"
SINFO:0,40,30,0,"PGS Korean"
SINFO:0,40,31,6121,"<b>Track information</b><br>"
SINFO:0,40,33,0,"100"
SINFO:0,40,38,0,""
SINFO:0,40,42,5088,"( Lossless conversion )"
SINFO:0,41,1,6203,"Subtitles"
SINFO:0,41,3,0,"kor"
SINFO:0,41,4,0,"Korean"
SINFO:0,41,5,0,"S_HDMV/PGS"
SINFO:0,41,6,0,"PGS"
SINFO:0,41,7,0,"HDMV PGS Subtitles"
SINFO:0,41,22,0,"6144"
SINFO:0,41,28,0,"eng"
SINFO:0,41,29,0,"English"
SINFO:0,41,30,0,"PGS Korean  (forced only)"
SINFO:0,41,31,6121,"<b>Track information</b><br>"
SINFO:0,41,33,0,"100"
SINFO:0,41,38,0,""
SINFO:0,41,42,5088,"( Lossless conversion )"
SINFO:0,42,1,6203,"Subtitles"
SINFO:0,42,3,0,"zho"
SINFO:0,42,4,0,"Chinese"
SINFO:0,42,5,0,"S_HDMV/PGS"
SINFO:0,42,6,0,"PGS"
SINFO:0,42,7,0,"HDMV PGS Subtitles"
SINFO:0,42,22,0,"0"
SINFO:0,42,28,0,"eng"
SINFO:0,42,29,0,"English"
SINFO:0,42,30,0,"PGS Chinese"
SINFO:0,42,31,6121,"<b>Track information</b><br>"
SINFO:0,42,33,0,"100"
SINFO:0,42,38,0,""
SINFO:0,42,42,5088,"( Lossless conversion )"
SINFO:0,43,1,6203,"Subtitles"
SINFO:0,43,3,0,"zho"
SINFO:0,43,4,0,"Chinese"
SINFO:0,43,5,0,"S_HDMV/PGS"
SINFO:0,43,6,0,"PGS"
SINFO:0,43,7,0,"HDMV PGS Subtitles"
SINFO:0,43,22,0,"6144"
SINFO:0,43,28,0,"eng"
SINFO:0,43,29,0,"English"
SINFO:0,43,30,0,"PGS Chinese  (forced only)"
SINFO:0,43,31,6121,"<b>Track information</b><br>"
SINFO:0,43,33,0,"100"
SINFO:0,43,38,0,""
SINFO:0,43,42,5088,"( Lossless conversion )"
SINFO:0,44,1,6203,"Subtitles"
SINFO:0,44,3,0,"kor"
SINFO:0,44,4,0,"Korean"
SINFO:0,44,5,0,"S_HDMV/PGS"
SINFO:0,44,6,0,"PGS"
SINFO:0,44,7,0,"HDMV PGS Subtitles"
SINFO:0,44,22,0,"0"
SINFO:0,44,28,0,"eng"
SINFO:0,44,29,0,"English"
SINFO:0,44,30,0,"PGS Korean"
SINFO:0,44,31,6121,"<b>Track information</b><br>"
SINFO:0,44,33,0,"100"
SINFO:0,44,38,0,""
SINFO:0,44,42,5088,"( Lossless conversion )"
SINFO:0,45,1,6203,"Subtitles"
SINFO:0,45,3,0,"kor"
SINFO:0,45,4,0,"Korean"
SINFO:0,45,5,0,"S_HDMV/PGS"
SINFO:0,45,6,0,"PGS"
SINFO:0,45,7,0,"HDMV PGS Subtitles"
SINFO:0,45,22,0,"6144"
SINFO:0,45,28,0,"eng"
SINFO:0,45,29,0,"English"
SINFO:0,45,30,0,"PGS Korean  (forced only)"
SINFO:0,45,31,6121,"<b>Track information</b><br>"
SINFO:0,45,33,0,"100"
SINFO:0,45,38,0,""
SINFO:0,45,42,5088,"( Lossless conversion )"
SINFO:0,46,1,6203,"Subtitles"
SINFO:0,46,3,0,"zho"
SINFO:0,46,4,0,"Chinese"
SINFO:0,46,5,0,"S_HDMV/PGS"
SINFO:0,46,6,0,"PGS"
SINFO:0,46,7,0,"HDMV PGS Subtitles"
SINFO:0,46,22,0,"0"
SINFO:0,46,28,0,"eng"
SINFO:0,46,29,0,"English"
SINFO:0,46,30,0,"PGS Chinese"
SINFO:0,46,31,6121,"<b>Track information</b><br>"
SINFO:0,46,33,0,"100"
SINFO:0,46,38,0,""
SINFO:0,46,42,5088,"( Lossless conversion )"
SINFO:0,47,1,6203,"Subtitles"
SINFO:0,47,3,0,"zho"
SINFO:0,47,4,0,"Chinese"
SINFO:0,47,5,0,"S_HDMV/PGS"
SINFO:0,47,6,0,"PGS"
SINFO:0,47,7,0,"HDMV PGS Subtitles"
SINFO:0,47,22,0,"6144"
SINFO:0,47,28,0,"eng"
SINFO:0,47,29,0,"English"
SINFO:0,47,30,0,"PGS Chinese  (forced only)"
SINFO:0,47,31,6121,"<b>Track information</b><br>"
SINFO:0,47,33,0,"100"
SINFO:0,47,38,0,""
SINFO:0,47,42,5088,"( Lossless conversion )"
SINFO:0,48,1,6203,"Subtitles"
SINFO:0,48,3,0,"kor"
SINFO:0,48,4,0,"Korean"
SINFO:0,48,5,0,"S_HDMV/PGS"
SINFO:0,48,6,0,"PGS"
SINFO:0,48,7,0,"HDMV PGS Subtitles"
SINFO:0,48,22,0,"0"
SINFO:0,48,28,0,"eng"
SINFO:0,48,29,0,"English"
SINFO:0,48,30,0,"PGS Korean"
SINFO:0,48,31,6121,"<b>Track information</b><br>"
SINFO:0,48,33,0,"100"
SINFO:0,48,38,0,""
SINFO:0,48,42,5088,"( Lossless conversion )"
SINFO:0,49,1,6203,"Subtitles"
SINFO:0,49,3,0,"kor"
SINFO:0,49,4,0,"Korean"
SINFO:0,49,5,0,"S_HDMV/PGS"
SINFO:0,49,6,0,"PGS"
SINFO:0,49,7,0,"HDMV PGS Subtitles"
SINFO:0,49,22,0,"6144"
SINFO:0,49,28,0,"eng"
SINFO:0,49,29,0,"English"
SINFO:0,49,30,0,"PGS Korean  (forced only)"
SINFO:0,49,31,6121,"<b>Track information</b><br>"
SINFO:0,49,33,0,"100"
SINFO:0,49,38,0,""
SINFO:0,49,42,5088,"( Lossless conversion )"
TINFO:1,2,0,"SE7EN"
TINFO:1,8,0,"37"
TINFO:1,9,0,"2:06:49"
TINFO:1,10,0,"34.1 GB"
TINFO:1,11,0,"36690302976"
TINFO:1,16,0,"00101.mpls"
TINFO:1,25,0,"1"
TINFO:1,26,0,"20"
TINFO:1,27,0,"SE7EN_t01.mkv"
TINFO:1,28,0,"eng"
TINFO:1,29,0,"English"
TINFO:1,30,0,"SE7EN - 37 chapter(s) , 34.1 GB"
TINFO:1,31,6120,"<b>Title information</b><br>"
TINFO:1,33,0,"0"
SINFO:1,0,1,6201,"Video"
SINFO:1,0,5,0,"V_VC1"
SINFO:1,0,6,0,"VC-1"
SINFO:1,0,7,0,"VC-1"
SINFO:1,0,19,0,"1920x1080"
SINFO:1,0,20,0,"16:9"
SINFO:1,0,21,0,"23.976 (24000/1001)"
SINFO:1,0,22,0,"0"
SINFO:1,0,28,0,"eng"
SINFO:1,0,29,0,"English"
SINFO:1,0,30,0,"VC-1"
SINFO:1,0,31,6121,"<b>Track information</b><br>"
SINFO:1,0,33,0,"0"
SINFO:1,0,38,0,""
SINFO:1,0,42,5088,"( Lossless conversion )"
SINFO:1,1,1,6202,"Audio"
SINFO:1,1,2,0,"Surround 7.1"
SINFO:1,1,3,0,"eng"
SINFO:1,1,4,0,"English"
SINFO:1,1,5,0,"A_DTS"
SINFO:1,1,6,0,"DTS-HD MA"
SINFO:1,1,7,0,"DTS-HD Master Audio"
SINFO:1,1,14,0,"8"
SINFO:1,1,17,0,"48000"
SINFO:1,1,18,0,"24"
SINFO:1,1,22,0,"1024"
SINFO:1,1,28,0,"eng"
SINFO:1,1,29,0,"English"
SINFO:1,1,30,0,"DTS-HD MA Surround 7.1 English"
SINFO:1,1,31,6121,"<b>Track information</b><br>"
SINFO:1,1,33,0,"90"
SINFO:1,1,38,0,""
SINFO:1,1,40,0,"7.1"
SINFO:1,1,42,5088,"( Lossless conversion )"
SINFO:1,2,1,6202,"Audio"
SINFO:1,2,2,0,"Surround 5.1"
SINFO:1,2,3,0,"eng"
SINFO:1,2,4,0,"English"
SINFO:1,2,5,0,"A_DTS"
SINFO:1,2,6,0,"DTS"
SINFO:1,2,7,0,"DTS"
SINFO:1,2,13,0,"1.5 Mb/s"
SINFO:1,2,14,0,"6"
SINFO:1,2,17,0,"48000"
SINFO:1,2,22,0,"2304"
SINFO:1,2,28,0,"eng"
SINFO:1,2,29,0,"English"
SINFO:1,2,30,0,"DTS Surround 5.1 English"
SINFO:1,2,31,6121,"<b>Track information</b><br>"
SINFO:1,2,33,0,"90"
SINFO:1,2,38,0,"d"
SINFO:1,2,39,0,"Default"
SINFO:1,2,40,0,"5.1(side)"
SINFO:1,2,42,5088,"( Lossless conversion )"
SINFO:1,3,1,6202,"Audio"
SINFO:1,3,2,5091,"Stereo"
SINFO:1,3,3,0,"jpn"
SINFO:1,3,4,0,"Japanese"
SINFO:1,3,5,0,"A_AC3"
SINFO:1,3,6,0,"DD"
SINFO:1,3,7,0,"Dolby Digital"
SINFO:1,3,13,0,"192 Kb/s"
SINFO:1,3,14,0,"2"
SINFO:1,3,17,0,"48000"
SINFO:1,3,22,0,"0"
SINFO:1,3,28,0,"eng"
SINFO:1,3,29,0,"English"
SINFO:1,3,30,0,"DD Stereo Japanese"
SINFO:1,3,31,6121,"<b>Track information</b><br>"
SINFO:1,3,33,0,"100"
SINFO:1,3,38,0,""
SINFO:1,3,40,0,"stereo"
SINFO:1,3,42,5088,"( Lossless conversion )"
SINFO:1,4,1,6202,"Audio"
SINFO:1,4,2,5090,"Mono"
SINFO:1,4,3,0,"jpn"
SINFO:1,4,4,0,"Japanese"
SINFO:1,4,5,0,"A_AC3"
SINFO:1,4,6,0,"DD"
SINFO:1,4,7,0,"Dolby Digital"
SINFO:1,4,13,0,"192 Kb/s"
SINFO:1,4,14,0,"1"
SINFO:1,4,17,0,"48000"
SINFO:1,4,22,0,"0"
SINFO:1,4,28,0,"eng"
SINFO:1,4,29,0,"English"
SINFO:1,4,30,0,"DD Mono Japanese"
SINFO:1,4,31,6121,"<b>Track information</b><br>"
SINFO:1,4,33,0,"100"
SINFO:1,4,38,0,""
SINFO:1,4,40,0,"mono"
SINFO:1,4,42,5088,"( Lossless conversion )"
SINFO:1,5,1,6202,"Audio"
SINFO:1,5,2,5090,"Mono"
SINFO:1,5,3,0,"jpn"
SINFO:1,5,4,0,"Japanese"
SINFO:1,5,5,0,"A_AC3"
SINFO:1,5,6,0,"DD"
SINFO:1,5,7,0,"Dolby Digital"
SINFO:1,5,13,0,"192 Kb/s"
SINFO:1,5,14,0,"1"
SINFO:1,5,17,0,"48000"
SINFO:1,5,22,0,"0"
SINFO:1,5,28,0,"eng"
SINFO:1,5,29,0,"English"
SINFO:1,5,30,0,"DD Mono Japanese"
SINFO:1,5,31,6121,"<b>Track information</b><br>"
SINFO:1,5,33,0,"100"
SINFO:1,5,38,0,""
SINFO:1,5,40,0,"mono"
SINFO:1,5,42,5088,"( Lossless conversion )"
SINFO:1,6,1,6202,"Audio"
SINFO:1,6,2,5090,"Mono"
SINFO:1,6,3,0,"jpn"
SINFO:1,6,4,0,"Japanese"
SINFO:1,6,5,0,"A_AC3"
SINFO:1,6,6,0,"DD"
SINFO:1,6,7,0,"Dolby Digital"
SINFO:1,6,13,0,"192 Kb/s"
SINFO:1,6,14,0,"1"
SINFO:1,6,17,0,"48000"
SINFO:1,6,22,0,"0"
SINFO:1,6,28,0,"eng"
SINFO:1,6,29,0,"English"
SINFO:1,6,30,0,"DD Mono Japanese"
SINFO:1,6,31,6121,"<b>Track information</b><br>"
SINFO:1,6,33,0,"100"
SINFO:1,6,38,0,""
SINFO:1,6,40,0,"mono"
SINFO:1,6,42,5088,"( Lossless conversion )"
SINFO:1,7,1,6202,"Audio"
SINFO:1,7,2,5091,"Stereo"
SINFO:1,7,3,0,"eng"
SINFO:1,7,4,0,"English"
SINFO:1,7,5,0,"A_AC3"
SINFO:1,7,6,0,"DD"
SINFO:1,7,7,0,"Dolby Digital"
SINFO:1,7,13,0,"192 Kb/s"
SINFO:1,7,14,0,"2"
SINFO:1,7,17,0,"48000"
SINFO:1,7,22,0,"0"
SINFO:1,7,28,0,"eng"
SINFO:1,7,29,0,"English"
SINFO:1,7,30,0,"DD Stereo English"
SINFO:1,7,31,6121,"<b>Track information</b><br>"
SINFO:1,7,33,0,"90"
SINFO:1,7,38,0,""
SINFO:1,7,40,0,"stereo"
SINFO:1,7,42,5088,"( Lossless conversion )"
SINFO:1,8,1,6202,"Audio"
SINFO:1,8,2,5091,"Stereo"
SINFO:1,8,3,0,"eng"
SINFO:1,8,4,0,"English"
SINFO:1,8,5,0,"A_AC3"
SINFO:1,8,6,0,"DD"
SINFO:1,8,7,0,"Dolby Digital"
SINFO:1,8,13,0,"192 Kb/s"
SINFO:1,8,14,0,"2"
SINFO:1,8,17,0,"48000"
SINFO:1,8,22,0,"0"
SINFO:1,8,28,0,"eng"
SINFO:1,8,29,0,"English"
SINFO:1,8,30,0,"DD Stereo English"
SINFO:1,8,31,6121,"<b>Track information</b><br>"
SINFO:1,8,33,0,"90"
SINFO:1,8,38,0,""
SINFO:1,8,40,0,"stereo"
SINFO:1,8,42,5088,"( Lossless conversion )"
SINFO:1,9,1,6202,"Audio"
SINFO:1,9,2,5091,"Stereo"
SINFO:1,9,3,0,"eng"
SINFO:1,9,4,0,"English"
SINFO:1,9,5,0,"A_AC3"
SINFO:1,9,6,0,"DD"
SINFO:1,9,7,0,"Dolby Digital"
SINFO:1,9,13,0,"192 Kb/s"
SINFO:1,9,14,0,"2"
SINFO:1,9,17,0,"48000"
SINFO:1,9,22,0,"0"
SINFO:1,9,28,0,"eng"
SINFO:1,9,29,0,"English"
SINFO:1,9,30,0,"DD Stereo English"
SINFO:1,9,31,6121,"<b>Track information</b><br>"
SINFO:1,9,33,0,"90"
SINFO:1,9,38,0,""
SINFO:1,9,40,0,"stereo"
SINFO:1,9,42,5088,"( Lossless conversion )"
SINFO:1,10,1,6202,"Audio"
SINFO:1,10,2,0,"Surround 5.1"
SINFO:1,10,3,0,"eng"
SINFO:1,10,4,0,"English"
SINFO:1,10,5,0,"A_AC3"
SINFO:1,10,6,0,"DD"
SINFO:1,10,7,0,"Dolby Digital"
SINFO:1,10,13,0,"640 Kb/s"
SINFO:1,10,14,0,"6"
SINFO:1,10,17,0,"48000"
SINFO:1,10,22,0,"0"
SINFO:1,10,28,0,"eng"
SINFO:1,10,29,0,"English"
SINFO:1,10,30,0,"DD Surround 5.1 English"
SINFO:1,10,31,6121,"<b>Track information</b><br>"
SINFO:1,10,33,0,"90"
SINFO:1,10,38,0,""
SINFO:1,10,40,0,"5.1(side)"
SINFO:1,10,42,5088,"( Lossless conversion )"
SINFO:1,11,1,6203,"Subtitles"
SINFO:1,11,3,0,"jpn"
SINFO:1,11,4,0,"Japanese"
SINFO:1,11,5,0,"S_HDMV/PGS"
SINFO:1,11,6,0,"PGS"
SINFO:1,11,7,0,"HDMV PGS Subtitles"
SINFO:1,11,22,0,"0"
SINFO:1,11,28,0,"eng"
SINFO:1,11,29,0,"English"
SINFO:1,11,30,0,"PGS Japanese"
SINFO:1,11,31,6121,"<b>Track information</b><br>"
SINFO:1,11,33,0,"100"
SINFO:1,11,38,0,""
SINFO:1,11,42,5088,"( Lossless conversion )"
SINFO:1,12,1,6203,"Subtitles"
SINFO:1,12,3,0,"jpn"
SINFO:1,12,4,0,"Japanese"
SINFO:1,12,5,0,"S_HDMV/PGS"
SINFO:1,12,6,0,"PGS"
SINFO:1,12,7,0,"HDMV PGS Subtitles"
SINFO:1,12,22,0,"6144"
SINFO:1,12,28,0,"eng"
SINFO:1,12,29,0,"English"
SINFO:1,12,30,0,"PGS Japanese  (forced only)"
SINFO:1,12,31,6121,"<b>Track information</b><br>"
SINFO:1,12,33,0,"100"
SINFO:1,12,38,0,""
SINFO:1,12,42,5088,"( Lossless conversion )"
SINFO:1,13,1,6203,"Subtitles"
SINFO:1,13,3,0,"eng"
SINFO:1,13,4,0,"English"
SINFO:1,13,5,0,"S_HDMV/PGS"
SINFO:1,13,6,0,"PGS"
SINFO:1,13,7,0,"HDMV PGS Subtitles"
SINFO:1,13,22,0,"0"
SINFO:1,13,28,0,"eng"
SINFO:1,13,29,0,"English"
SINFO:1,13,30,0,"PGS English"
SINFO:1,13,31,6121,"<b>Track information</b><br>"
SINFO:1,13,33,0,"90"
SINFO:1,13,38,0,""
SINFO:1,13,42,5088,"( Lossless conversion )"
SINFO:1,14,1,6203,"Subtitles"
SINFO:1,14,3,0,"eng"
SINFO:1,14,4,0,"English"
SINFO:1,14,5,0,"S_HDMV/PGS"
SINFO:1,14,6,0,"PGS"
SINFO:1,14,7,0,"HDMV PGS Subtitles"
SINFO:1,14,22,0,"6144"
SINFO:1,14,28,0,"eng"
SINFO:1,14,29,0,"English"
SINFO:1,14,30,0,"PGS English  (forced only)"
SINFO:1,14,31,6121,"<b>Track information</b><br>"
SINFO:1,14,33,0,"90"
SINFO:1,14,38,0,"d"
SINFO:1,14,39,0,"Default"
SINFO:1,14,42,5088,"( Lossless conversion )"
SINFO:1,15,1,6203,"Subtitles"
SINFO:1,15,3,0,"jpn"
SINFO:1,15,4,0,"Japanese"
SINFO:1,15,5,0,"S_HDMV/PGS"
SINFO:1,15,6,0,"PGS"
SINFO:1,15,7,0,"HDMV PGS Subtitles"
SINFO:1,15,22,0,"0"
SINFO:1,15,28,0,"eng"
SINFO:1,15,29,0,"English"
SINFO:1,15,30,0,"PGS Japanese"
SINFO:1,15,31,6121,"<b>Track information</b><br>"
SINFO:1,15,33,0,"100"
SINFO:1,15,38,0,""
SINFO:1,15,42,5088,"( Lossless conversion )"
SINFO:1,16,1,6203,"Subtitles"
SINFO:1,16,3,0,"jpn"
SINFO:1,16,4,0,"Japanese"
SINFO:1,16,5,0,"S_HDMV/PGS"
SINFO:1,16,6,0,"PGS"
SINFO:1,16,7,0,"HDMV PGS Subtitles"
SINFO:1,16,22,0,"6144"
SINFO:1,16,28,0,"eng"
SINFO:1,16,29,0,"English"
SINFO:1,16,30,0,"PGS Japanese  (forced only)"
SINFO:1,16,31,6121,"<b>Track information</b><br>"
SINFO:1,16,33,0,"100"
SINFO:1,16,38,0,""
SINFO:1,16,42,5088,"( Lossless conversion )"
SINFO:1,17,1,6203,"Subtitles"
SINFO:1,17,3,0,"jpn"
SINFO:1,17,4,0,"Japanese"
SINFO:1,17,5,0,"S_HDMV/PGS"
SINFO:1,17,6,0,"PGS"
SINFO:1,17,7,0,"HDMV PGS Subtitles"
SINFO:1,17,22,0,"0"
SINFO:1,17,28,0,"eng"
SINFO:1,17,29,0,"English"
SINFO:1,17,30,0,"PGS Japanese"
SINFO:1,17,31,6121,"<b>Track information</b><br>"
SINFO:1,17,33,0,"100"
SINFO:1,17,38,0,""
SINFO:1,17,42,5088,"( Lossless conversion )"
SINFO:1,18,1,6203,"Subtitles"
SINFO:1,18,3,0,"jpn"
SINFO:1,18,4,0,"Japanese"
SINFO:1,18,5,0,"S_HDMV/PGS"
SINFO:1,18,6,0,"PGS"
SINFO:1,18,7,0,"HDMV PGS Subtitles"
SINFO:1,18,22,0,"6144"
SINFO:1,18,28,0,"eng"
SINFO:1,18,29,0,"English"
SINFO:1,18,30,0,"PGS Japanese  (forced only)"
SINFO:1,18,31,6121,"<b>Track information</b><br>"
SINFO:1,18,33,0,"100"
SINFO:1,18,38,0,""
SINFO:1,18,42,5088,"( Lossless conversion )"
SINFO:1,19,1,6203,"Subtitles"
SINFO:1,19,3,0,"jpn"
SINFO:1,19,4,0,"Japanese"
SINFO:1,19,5,0,"S_HDMV/PGS"
SINFO:1,19,6,0,"PGS"
SINFO:1,19,7,0,"HDMV PGS Subtitles"
SINFO:1,19,22,0,"0"
SINFO:1,19,28,0,"eng"
SINFO:1,19,29,0,"English"
SINFO:1,19,30,0,"PGS Japanese"
SINFO:1,19,31,6121,"<b>Track information</b><br>"
SINFO:1,19,33,0,"100"
SINFO:1,19,38,0,""
SINFO:1,19,42,5088,"( Lossless conversion )"
SINFO:1,20,1,6203,"Subtitles"
SINFO:1,20,3,0,"jpn"
SINFO:1,20,4,0,"Japanese"
SINFO:1,20,5,0,"S_HDMV/PGS"
SINFO:1,20,6,0,"PGS"
SINFO:1,20,7,0,"HDMV PGS Subtitles"
SINFO:1,20,22,0,"6144"
SINFO:1,20,28,0,"eng"
SINFO:1,20,29,0,"English"
SINFO:1,20,30,0,"PGS Japanese  (forced only)"
SINFO:1,20,31,6121,"<b>Track information</b><br>"
SINFO:1,20,33,0,"100"
SINFO:1,20,38,0,""
SINFO:1,20,42,5088,"( Lossless conversion )"
SINFO:1,21,1,6203,"Subtitles"
SINFO:1,21,3,0,"jpn"
SINFO:1,21,4,0,"Japanese"
SINFO:1,21,5,0,"S_HDMV/PGS"
SINFO:1,21,6,0,"PGS"
SINFO:1,21,7,0,"HDMV PGS Subtitles"
SINFO:1,21,22,0,"0"
SINFO:1,21,28,0,"eng"
SINFO:1,21,29,0,"English"
SINFO:1,21,30,0,"PGS Japanese"
SINFO:1,21,31,6121,"<b>Track information</b><br>"
SINFO:1,21,33,0,"100"
SINFO:1,21,38,0,""
SINFO:1,21,42,5088,"( Lossless conversion )"
SINFO:1,22,1,6203,"Subtitles"
SINFO:1,22,3,0,"jpn"
SINFO:1,22,4,0,"Japanese"
SINFO:1,22,5,0,"S_HDMV/PGS"
SINFO:1,22,6,0,"PGS"
SINFO:1,22,7,0,"HDMV PGS Subtitles"
SINFO:1,22,22,0,"6144"
SINFO:1,22,28,0,"eng"
SINFO:1,22,29,0,"English"
SINFO:1,22,30,0,"PGS Japanese  (forced only)"
SINFO:1,22,31,6121,"<b>Track information</b><br>"
SINFO:1,22,33,0,"100"
SINFO:1,22,38,0,""
SINFO:1,22,42,5088,"( Lossless conversion )"
SINFO:1,23,1,6203,"Subtitles"
SINFO:1,23,3,0,"jpn"
SINFO:1,23,4,0,"Japanese"
SINFO:1,23,5,0,"S_HDMV/PGS"
SINFO:1,23,6,0,"PGS"
SINFO:1,23,7,0,"HDMV PGS Subtitles"
SINFO:1,23,22,0,"0"
SINFO:1,23,28,0,"eng"
SINFO:1,23,29,0,"English"
SINFO:1,23,30,0,"PGS Japanese"
SINFO:1,23,31,6121,"<b>Track information</b><br>"
SINFO:1,23,33,0,"100"
SINFO:1,23,38,0,""
SINFO:1,23,42,5088,"( Lossless conversion )"
SINFO:1,24,1,6203,"Subtitles"
SINFO:1,24,3,0,"jpn"
SINFO:1,24,4,0,"Japanese"
SINFO:1,24,5,0,"S_HDMV/PGS"
SINFO:1,24,6,0,"PGS"
SINFO:1,24,7,0,"HDMV PGS Subtitles"
SINFO:1,24,22,0,"6144"
SINFO:1,24,28,0,"eng"
SINFO:1,24,29,0,"English"
SINFO:1,24,30,0,"PGS Japanese  (forced only)"
SINFO:1,24,31,6121,"<b>Track information</b><br>"
SINFO:1,24,33,0,"100"
SINFO:1,24,38,0,""
SINFO:1,24,42,5088,"( Lossless conversion )"
SINFO:1,25,1,6203,"Subtitles"
SINFO:1,25,3,0,"jpn"
SINFO:1,25,4,0,"Japanese"
SINFO:1,25,5,0,"S_HDMV/PGS"
SINFO:1,25,6,0,"PGS"
SINFO:1,25,7,0,"HDMV PGS Subtitles"
SINFO:1,25,22,0,"0"
SINFO:1,25,28,0,"eng"
SINFO:1,25,29,0,"English"
SINFO:1,25,30,0,"PGS Japanese"
SINFO:1,25,31,6121,"<b>Track information</b><br>"
SINFO:1,25,33,0,"100"
SINFO:1,25,38,0,""
SINFO:1,25,42,5088,"( Lossless conversion )"
SINFO:1,26,1,6203,"Subtitles"
SINFO:1,26,3,0,"jpn"
SINFO:1,26,4,0,"Japanese"
SINFO:1,26,5,0,"S_HDMV/PGS"
SINFO:1,26,6,0,"PGS"
SINFO:1,26,7,0,"HDMV PGS Subtitles"
SINFO:1,26,22,0,"6144"
SINFO:1,26,28,0,"eng"
SINFO:1,26,29,0,"English"
SINFO:1,26,30,0,"PGS Japanese  (forced only)"
SINFO:1,26,31,6121,"<b>Track information</b><br>"
SINFO:1,26,33,0,"100"
SINFO:1,26,38,0,""
SINFO:1,26,42,5088,"( Lossless conversion )"
SINFO:1,27,1,6203,"Subtitles"
SINFO:1,27,3,0,"jpn"
SINFO:1,27,4,0,"Japanese"
SINFO:1,27,5,0,"S_HDMV/PGS"
SINFO:1,27,6,0,"PGS"
SINFO:1,27,7,0,"HDMV PGS Subtitles"
SINFO:1,27,22,0,"0"
SINFO:1,27,28,0,"eng"
SINFO:1,27,29,0,"English"
SINFO:1,27,30,0,"PGS Japanese"
SINFO:1,27,31,6121,"<b>Track information</b><br>"
SINFO:1,27,33,0,"100"
SINFO:1,27,38,0,""
SINFO:1,27,42,5088,"( Lossless conversion )"
SINFO:1,28,1,6203,"Subtitles"
SINFO:1,28,3,0,"jpn"
SINFO:1,28,4,0,"Japanese"
SINFO:1,28,5,0,"S_HDMV/PGS"
SINFO:1,28,6,0,"PGS"
SINFO:1,28,7,0,"HDMV PGS Subtitles"
SINFO:1,28,22,0,"6144"
SINFO:1,28,28,0,"eng"
SINFO:1,28,29,0,"English"
SINFO:1,28,30,0,"PGS Japanese  (forced only)"
SINFO:1,28,31,6121,"<b>Track information</b><br>"
SINFO:1,28,33,0,"100"
SINFO:1,28,38,0,""
SINFO:1,28,42,5088,"( Lossless conversion )"
SINFO:1,29,1,6203,"Subtitles"
SINFO:1,29,3,0,"jpn"
SINFO:1,29,4,0,"Japanese"
SINFO:1,29,5,0,"S_HDMV/PGS"
SINFO:1,29,6,0,"PGS"
SINFO:1,29,7,0,"HDMV PGS Subtitles"
SINFO:1,29,22,0,"0"
SINFO:1,29,28,0,"eng"
SINFO:1,29,29,0,"English"
SINFO:1,29,30,0,"PGS Japanese"
SINFO:1,29,31,6121,"<b>Track information</b><br>"
SINFO:1,29,33,0,"100"
SINFO:1,29,38,0,""
SINFO:1,29,42,5088,"( Lossless conversion )"
SINFO:1,30,1,6203,"Subtitles"
SINFO:1,30,3,0,"jpn"
SINFO:1,30,4,0,"Japanese"
SINFO:1,30,5,0,"S_HDMV/PGS"
SINFO:1,30,6,0,"PGS"
SINFO:1,30,7,0,"HDMV PGS Subtitles"
SINFO:1,30,22,0,"6144"
SINFO:1,30,28,0,"eng"
SINFO:1,30,29,0,"English"
SINFO:1,30,30,0,"PGS Japanese  (forced only)"
SINFO:1,30,31,6121,"<b>Track information</b><br>"
SINFO:1,30,33,0,"100"
SINFO:1,30,38,0,""
SINFO:1,30,42,5088,"( Lossless conversion )"
cpitchford
Re: Se7en steelbook Bluray causes hanging
Post by cpitchford » Thu Jan 09, 2025 4:20 pm
Ahhh my bad. It looks like it is trying to make an https connection out and it can’t connect (web server might be down) but it did eventually timeout and carry on
Figured it out using lsof to see it had opened a connection to a remote ip, and using strace to see it was waiting for that socket connection to do something
Seems to be ok after the connection times out
