BDR 212V UHD Guide
raf_finals
Re: BDR 212V UHD Guide
Thank so much for the help @Coopervid
Keat1892
PM received and directions followed. Thank you very much!
Drive platform: RS8F01
Firmware version: 1.02/ID43
Unrestricted read speed: Yes-
Co393
Just snagged a 212v and also looking for instructions to get it reading UHD discs. Thanks.
I’ve decided to convert my entire UHD collection to mkv. I just received a 212v from Amazon. @Coopervid, would you be able to help me flash it appropriately?
PM sent.Co393 wrote: Mon Jan 06, 2025 5:44 pm Just snagged a 212v and also looking for instructions to get it reading UHD discs. Thanks.
caiparinha
I also snagged an Amazon BDR-212V with 1.02 FW. I would love to be able to rip UHD discs if the FW updater is still available.
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: ...
Firmware date: 2022-05-31
Bus encryption flags: 13
Thanks,
Chris
Revision: 1.02
Serial number: ...
Thanks,
Chris
PM sentcaiparinha wrote: Sun Jan 19, 2025 1:15 am I also snagged an Amazon BDR-212V with 1.02 FW. I would love to be able to rip UHD discs if the FW updater is still available.
Revision: 1.02
Serial number: ...
Thanks,
Chris
captainmidnight
Hi Coopervid, would you be able to send me the flasher for my BDR-212V as well? Below is my drive information.Coopervid wrote: Sun Jan 19, 2025 10:15 amPM sentcaiparinha wrote: Sun Jan 19, 2025 1:15 am I also snagged an Amazon BDR-212V with 1.02 FW. I would love to be able to rip UHD discs if the FW updater is still available.
Revision: 1.02
Serial number: ...
Thanks,
Chris
Revision: 1.02
Serial number: --
Highest AACS version: 77
Firmware version: ID06
Thank you
PM sent.captainmidnight wrote: Wed Jan 22, 2025 1:23 amHi Coopervid, would you be able to send me the flasher for my BDR-212V as well? Below is my drive information.Coopervid wrote: Sun Jan 19, 2025 10:15 amPM sentcaiparinha wrote: Sun Jan 19, 2025 1:15 am I also snagged an Amazon BDR-212V with 1.02 FW. I would love to be able to rip UHD discs if the FW updater is still available.
Revision: 1.02
Serial number: ...
Thanks,
Chris
Revision: 1.02
Serial number: --
Thank you
bird333
I just got this drive. @Coopervid could you help me flash this drive? The info is below. Thanks
OS device name: H:
Revision: 1.02
Serial number: REMOVED
Highest AACS version: 68
Firmware version: ID06-
PM sent.bird333 wrote: Thu Jan 23, 2025 7:49 pm I just got this drive. @Coopervid could you help me flash this drive? The info is below. Thanks
Drive Information OS device name: H: Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Serial number: REMOVED Firmware date: 2022-05-31 Bus encryption flags: 13 Highest AACS version: 68 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06
wildbomb
Hi Coopervid, I just got this drive, can you maybe help me?
Thanks in advance!
Revision: 1.02
Serial number: xxxxxx
Highest AACS version: 81
No disc inserted-
bird333
Thanks for the quick response.
eek24
Coopervid,
I just received my BDR-212V from Amazon this morning. I was hoping you would help me by sharing how to flash the drive to enable UHD read ability. Please note that I have never used PM so I may be blocked as a new user.
OS device name: F:
Revision: 1.02
Serial number: ...
OS device name: F:
Revision: 1.02
Serial number: ...
PM sent.wildbomb wrote: Fri Jan 24, 2025 7:36 pm Hi Coopervid, I just got this drive, can you maybe help me?Thanks in advance!Code: Select all
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Serial number: xxxxxx Firmware date: 2022-05-31 Bus encryption flags: 13 Highest AACS version: 81 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06 No disc inserted
