I am trying to load Modus season 1 on my computer.
Using the “Process monitor” method to find the right playlists to save, according to Process monitor I should use “00762.mpls”
But when I check in MakeMKV, the playlist is not there. When I look through the log, I do not find any “Title 00762.mpls is equal to title xxxxxx.mpls” so I do not know at all how to proceed then to find the right one. Disk 1 worked fine with the Process monitor method, but on Disk 2 this problem occurred.
Do you have any idea how to proceed?
Correct playlist wont show up
Re: Correct playlist wont show up
If you make a decrypted backup of the blu-ray (by clicking the icon of a yellow folder with a green arrow on the first screen) and then look at the <backup>/BDMV/PLAYLIST folder, you can see all the .mpls files on the disc to verify that 00762.mpls is there.
Assuming it is there and there are no messages about it being a duplicate… then I don't know. Maybe try temporarily deleting all the other .mpls files out of the PLAYLIST folder except for 00762 and try loading the backup into MakeMKV.
GrezZeR
I will try and have a decrypted backup and see if the playlist shows up. Thanks for the tips
