Search on Amazon for Verbatim 43888. But beware it is power hungry and if you have issues with your laptop's ports buy a powered USB hub.FrancisBlack79 wrote: Tue Jul 09, 2024 1:05 pm Thanks for the reply Coopervid![]()
Fairly new to the 'UHD friendly drive' scene so still learning!
Basically I'm looking for a drive that I can rip CD's, Blu-Rays and UHD Discs for backup with a high success rate but struggling to find what would be best to buy here in the U.K. The drive itself would be connected to a HP Omen Laptop running Windows 11, any advice would be appreciated or if anyone could point me in the right direction that would be great.
Thanks again
ASUS BW-16D1X-U - Flashable?
Re: ASUS BW-16D1X-U - Flashable?
FrancisBlack79
Many thanks Coopervid for the advice.Coopervid wrote: Tue Jul 09, 2024 7:03 pmSearch on Amazon for Verbatim 43888. But beware it is power hungry and if you have issues with your laptop's ports buy a powered USB hub.FrancisBlack79 wrote: Tue Jul 09, 2024 1:05 pm Thanks for the reply Coopervid![]()
Thanks again
I have found a link to the drive on amazon, I assume this is the one you mean?
https://www.amazon.co.uk/Verbatim-Exter ... B07MTP9VKX
I take it this drive wouldn't need flashing and works out of the box?
My laptop does have issues occasionally with one of the usb ports, but I also have a usb c thunderbolt connection on my laptop if that could be used?
With regards to a powered USB hub would you recommend something like this off Amazon:-
https://www.amazon.co.uk/TP-LINK-UH700- ... 102&sr=8-3
Thanks again for all your help
Yes, that's the drive. It should come with a USB cable and USB-C adapter.FrancisBlack79 wrote: Tue Jul 09, 2024 8:43 pmMany thanks Coopervid for the advice.Coopervid wrote: Tue Jul 09, 2024 7:03 pmSearch on Amazon for Verbatim 43888. But beware it is power hungry and if you have issues with your laptop's ports buy a powered USB hub.FrancisBlack79 wrote: Tue Jul 09, 2024 1:05 pm Thanks for the reply Coopervid![]()
Thanks again
If you use a USB-C port you should be fine without a hub.
I'm not sure about that hub but it's been suggested previously that a high powered hub (minimum of 35w) be used.
FrancisBlack79
Thanks Marty!MartyMcNuts wrote: Wed Jul 10, 2024 1:44 amYes, that's the drive. It should come with a USB cable and USB-C adapter.FrancisBlack79 wrote: Tue Jul 09, 2024 8:43 pmMany thanks Coopervid for the advice.Coopervid wrote: Tue Jul 09, 2024 7:03 pm
I have ordered the drive today through Amazon so will try it with my USB C thunderbolt connection and see how I get on, if I have problems I will order me one of these powered usb hubs:-
https://www.amazon.co.uk/SABRENT-Multip ... C77&sr=8-5
Thank you both for your help, I will post here to let you know how I get on
ENDzZ
Hi, I have an ASUS BW-16D1H-U Pro Drive with RS8F00 Platform and PIONEER BDR-212T in it. May I ask is it UHD-Friendly, and if it is, how can I flash it? Thanks.
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: [redacted]
Firmware date: 2020-07-21
Highest AACS version: 76
Drive platform: RS8F00
Firmware version: E116/ID71
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
yeah it can do UHD email me for a flasher see belowENDzZ wrote: Mon Aug 19, 2024 5:59 pm Hi, I have an ASUS BW-16D1H-U Pro Drive with RS8F00 Platform and PIONEER BDR-212T in it. May I ask is it UHD-Friendly, and if it is, how can I flash it? Thanks.
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
gibsondj
I have the same drive as OP (at least as far as MakeMKV is concerned):
OS device name: /dev/rdisk4
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Firmware date: 2017-12-21
Highest AACS version: 72
Drive platform: RS8601
Firmware version: E111/ID76
I'm confident that I can do the process without an autoscript, but need to know which firmware will work with this device. It seems that this is typically answered via DM.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
You have a PM and need a Windows PC for it to work.gibsondj wrote: Mon Dec 09, 2024 1:33 am I have the same drive as OP (at least as far as MakeMKV is concerned):
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
snach
Hi
can you help me in making libredrive of this Asus. I sent you an email
Here is the data. Please provide any necessary instructions. Thank you very much for any guidance. I am running on platformie windows 11.
arnivska
Hey I have the same drive as above and I'm happy to use the CLI, could you also PM me the details.
I've looked around quite a bit but all I can find is for the MT1959 drives.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
Highest AACS version: 46
Firmware version: ID76
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
ralph
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Highest AACS version: 32
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Did you get help with your drive?snach wrote: Fri Dec 13, 2024 5:28 pm Hi
Here is the data. Please provide any necessary instructions. Thank you very much for any guidance. I am running on platformie windows 11. 1.jpg
PM sent.arnivska wrote: Sun Dec 29, 2024 12:20 pm Hey I have the same drive as above and I'm happy to use the CLI, could you also PM me the details.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
PM sent.ralph wrote: Mon Jan 06, 2025 6:18 pm Hi, I have an ASUS BW-16D1H-U Pro Drive with RS8F00 Platform and PIONEER BDR-212T in it. May I ask is it UHD-Friendly, and if it is, how can I flash it? Thanks.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
